SDA 2.3 No bass
  • Gardenstater
    Gardenstater Posts: 4,921
    edited July 2024
    Black Terminal and Red Terminal are referring to the binding posts. Black is negative and is the one on the right, and Red is positive and the one on the left. Have you looked at the schematic. Even if you are a novice at schematic reading it might be of some help.
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • JCL
    JCL Posts: 174
    I would take the measurements from the back of the speaker at the binding posts and the SDA connection. That’s where I took them and I believe that’s where they were intended to be checked.
    L600 (front), R200 (rear), R200 (rear surround), L400 (center), Sunfire HRS-10 (2)Marantz AV7706Sunfire Cinema Grand, Marantz M8077, Music Hall Stealth, Ortofon bronze cartridge, Parasound Zphono XRM, Sony UBP-X800
  • tragusa3
    tragusa3 Posts: 48
    Measured at the binding posts, everything measures spot on.
    George, the schematic is a foreign language to me, but I'm trying.
    SDASRS2.3, SDA1C, Monitor 10, Monitor 7b
    Klipschorns, LaScalas, Heresy
    JBL8330a
    Infinity Kappa6
    Danley DTS10
  • Gardenstater
    tragusa3 wrote: »
    Now, what do you get for R5 when you have first disconnected the sub-bass donut drivers? Is it the same? Just curious if those drivers are not getting proper current due to bad connections or an open circuit sub-bass inductor, etc..
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • tragusa3
    tragusa3 Posts: 48
    With both donuts disconnected, R5 (black to red at the terminal) changed from 4.1ohm to 3.8ohm
    Seems minimal?
    JBL8330a
    Infinity Kappa6
    Danley DTS10
  • Gardenstater
    edited July 2024
    tragusa3 wrote: »
    Seems minimal?
    It is. May or may not be normal. If there were no change whatsoever that would've meant there is an open circuit on the supply or return side through the sub-bass inductors. When you said they are moving maybe 50% I thought there could be a possibility it was entirely due to back wave energizing them. 20dB down from flat at 40Hz is huge and can't be entirely due to some room acoustic anomaly. I don't know where you measured though; what distance from the speakers etc..
    Next step would be to remove that faston on the white wire where it connects to the sub-bass inductor and clean it (the male side) with something like some 0000 steel wool or maybe 1500 or finer grit sandpaper or DeOxit if you have some (on male and female). Make sure the connection is tight and if not crimp the female faston slightly tighter. Then see what it measures when everything re-connected. See if the 4.1 ohms changes and listen. Basically you just want to clean all connections and make sure they are tight, with all the midwoofers circuits but especially the sub-bass and stereo ones.
    I would also proceed with making sure the cabinet is sealed up as tightly as it should be.
    PS: Have you made certain that your red binding post nuts (+) are on the left on both speakers? If they were swapped on one of them, and you were wiring your amplifier to them according to color only, you could get huge bass cancellation effect.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
    F1nut Posts: 52,381
    Wow, just wow
  • skipshot12
    skipshot12 Posts: 2,141
    edited July 2024
    If it’s not a really good sealed cabinet you wouldn’t get the tightness in the bass region, bass would sound boomy. But, the bass will still be there.
    Something else is going on.
    Grab a schematic and trace all connections to be wired correctly along with continuity.Yes it’s a pain in the **** but you need to start eliminating what isn’t wrong.
    There’s no way slight air leaks would cause a 30db drop in bass…
    Tony M Posts: 12,001
    How about the speaker wire polarity hooked up to the amp?
    I know it sounds unlikely but I've made the mistake once or twice in my old age. :s
  • skipshot12
    Don’t get frustrated.
    Take your time.
    You’ll learn as you go…..
    A lot of knowledge on this forum. These folks have been there done that.
    There are no stupid questions.
    F1nut Posts: 52,381
    skipshot12 wrote: »
    The air pressure from mid-drivers drive the PR, so if there is an air leak like the OP has there will be no bass, boomy or otherwise.
  • tragusa3
    tragusa3 Posts: 48
    George, thanks. I will get to cleaning all fastons.
    F1, I have yet to put the adhesive inside the cabinets. I have tightened the nuts. I've looked very closely at all surrounds and found two small locations where I added some glue. You may be right about airleaks causing it, but it's hard to sell me on that with such a HUGE discrepancy.
    Tony, thanks. I just checked again. Yes, I've done it before...
    Skipshot12, thanks for the encouragement. I'm keeping faith. I am not afraid to ask questions. My wife says that I'm humble to a fault when it comes to knowledge. She claims I'm an expert at most things. :smiley:
    JBL8330a
    Infinity Kappa6
    Danley DTS10
  • Gardenstater
    Are the Red binding post nuts on the left side for both speakers?
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • tragusa3
    tragusa3 Posts: 48
    Sorry, meant to respond to that. Yes they are and I've verified the wiring from the crossover to the binding posts.
    JBL8330a
    Infinity Kappa6
    Danley DTS10
  • Gardenstater
    tragusa3 wrote: »
    Okay. Well I was hoping for your sake that it was that simple 🤣
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
    SCompRacer Posts: 9,385
    edited July 2024
    What are the dimensions and type of room they are in? The reason I ask, if you cannot find anything terribly wrong with the speakers, the room could be a contributing factor.
    Once upon a time I experienced a room at a friend's house where a better pair of speakers capable of deeper bass than the ones they replaced actually had less bass than the ones they replaced. Leaving the room, the best bass was found outside the door to the room in the hallway. I found it hard to believe but I had experienced it.
  • michaeljhsda2
    michaeljhsda2 Posts: 2,207
    edited July 2024
    I don't see where this has been mentioned but are the jumper wires to the upper and lower binding posts in place?
    SDA SRS 2.3TL's
    SDA 2B TL's
  • skipshot12
    skipshot12 wrote: »
    ^ Respectively disagree with this.
    Not an SDA expert here by no means but, playing my SDA SRS’s for the first time they had plenty of low end bass…. Before starting on my mods.
    End caps were so loose I took them off with my fingers, as were all the drivers along with the passive.
    Bass was still there.
    There’s something else causing the 30 decibel drop.
  • tragusa3
    tragusa3 Posts: 48
    Hey Michael, welcome to the show. Jumpers are in, good catch.
    Scompracer, welcome. The room I'm currently in is too small for them (14'x12'). I've placed them in a dozen spots and walked the entire first floor of the house to see if the bass was anywhere. I'm quite familiar with integrating subs in a room, as I have a theater with multiple subs that I have spent years dialing in with placement, REW and a parametric eq. There is something in this cabinet that is cutting me off at the knees. When I bought my SDA1C's, I had a similar issue and DID find a polarity issue on some drivers. Hasn't been that easy this time. I'm not saying bass is weak or thin...it is not being produced.
    JBL8330a
    Infinity Kappa6
    Danley DTS10
    Clipdat Posts: 13,104
    As a side note, welcome to the forum. Hopefully after you get this mystery solved you'll stick around and talk music and gear with us.
  • tragusa3
    tragusa3 Posts: 48
    Is there a way to measure voltage making it to each driver? Would that tell me if the driver is getting what it should? If I played a test tone and measured voltage at every driver? I wouldn't know what the voltage is supposed to be, but I would see if something was a standout anomaly. Helpful?
    I'm glueing interior seams in the cabinet right now and while drivers are out, glueing the magnets too. :wink: I have to do something to feel productive.
    JBL8330a
    Infinity Kappa6
    Danley DTS10
  • gmcman
    gmcman Posts: 1,868
    tragusa3 wrote: »
    construction adhesive on the inside seams.
    Someone can correct me if I'm wrong, but I would use a sealant and not construction adhesive. If you need to remove/replaced the end caps in the future, the construction adhesive could damage the cabinets upon removal.
  • gmcman
    gmcman Posts: 1,868
    What are you driving the speakers with, an AVR maybe? Just something to check, if using an AVR, make sure you don't have speakers set to small or have the sub selected and a cutoff at maybe 80HZ.
    Great suggestion!
  • tragusa3
    tragusa3 Posts: 48
    gmcman wrote: »
    tragusa3 wrote: »
    It's on there now! I don't think I put it anywhere that I would ever take apart?
    JBL8330a
    Infinity Kappa6
    Danley DTS10
  • tragusa3
    tragusa3 Posts: 48
    gmcman wrote: »
    Ya'll are good at catching the obvious little things. For once, I've addressed most of them. They are connected to an Emotiva XPA amp putting bwtween 4-500 watts per channel to them. No processor. Bluetooth dongle directly to amp. In the last month, I've had 6 +/- other speakers connected to this and they all sounded great. Thanks.
    JBL8330a
    Infinity Kappa6
    Danley DTS10
  • tragusa3
    tragusa3 Posts: 48
    Clipdat wrote: »
    Thanks brother! I like a little bit of troubleshooting, but I do enjoy the music more!
    JBL8330a
    Infinity Kappa6
    Danley DTS10
    Bluetooth dongle? :#
    Well, assuming no software EQ in play on your phone/app then I guess it's not that.
  • tragusa3
    tragusa3 Posts: 48
    For your viewing pleasure.
    JBL8330a
    Infinity Kappa6
    Danley DTS10
    My uneducated **** says it's something wrong with the crossover.
