Those darn appliances
I rarely use my microwave at 100%. I do not mind waiting 10-15 at say 20-30%. My food doesn't come out rubbery or splatter like a nuclear holocaust...
Wait- are you saying I can genuinely use low power and just wait 10 minutes without worrying about it exploding?
Does it heat evenly or do I still need to stir?
Yes that is what I'm saying.
You still must stir during the heat up. The nature of a microwave is very uneven, just the nature of the beast. -
I rarely clean ours because I have taught the family to use wax wrap and cover whatever it is they are cooking. Especially anything that's greasy or likes to explode all over the microwave. It's cheap, easy to use and definitely helps with the cleanup.
Standing waves -- just like loudspeakers in a room!
I'm going to try this out next time I need to use the microwave because this may very well be life changing.My gear:- TCL 75QM7K TV
- Onyko TX-NR656 AVR
- RT3000p Fronts
- CS1000p Center
- RT35 Side Surrounds
- RT35 Rear Surrounds
My mom will continue to do it her way even if everyone else follows suite!
She still pre rinses before using the dishwasher and uses wayyy too much detergent even after I showed her video proof that it could tank the mist ridiculous things when doing it my way... oh well.
Now our nice glasses are slowly getting etched
- RT3000p Fronts
- CS1000p Center
Unless it's an inverter microwave (most Panasonic's) it's always at 100%. It just switches the power on and off depending on the setting.
An inverter microwave actually lowers the power to the magnetron. With a Panasonic you can actually completely thaw food, without it cooking at all. I'll never own anything else.
https://www.panasonic.com/nz/consumer/household-learn/technology/what_s-an-inverter.html
I was about to post the exact same thing, but you got it first. 100% correct fellas.
The solution is to cover the dang food. -
I just learned something new today.
Unfortunately ours looks like one of the few models they sell without an inverter. I will experiment with lower power levels anyways.My gear:- TCL 75QM7K TV
- RT3000p Fronts
- CS1000p Center
A damp paper towel laying on top works for a lot of foodsMojo Audio Illuminati v3>>Quantum Byte w/LMS>>Rpi/PiCoreplayer>> Starlight 7 USB >> Mojo Audio Mystique v2 SE>>ModWright SWL 9.0 SE Signature>>Hafler DH-500 Amp+ (Musical Concepts Fully Modded)>>
1KVA Dreadnought
Marantz SA 8005
Sony PS4
"All THAT IS LOST FROM THE SOURCE IS LOST FOREVER" -
Our DW is on the fritz. We will need a new one. This time looking at a Bosch. Our issue is we don't want to spend lots as we'll be re-doing the kitchen within 5-7 yrs at which point we'll get the DW that we really want to get. So looking at the 100 or 300 series Bosch. Our current LG (Laughable Garbage) is 9 yrs but has acted up since the 3rd year. Racks are rusted after 2 years replaced under warranty new ones rusted right through in some areas, drying agent dispenser stopped working after yr 3. Sometimes the only way to get the control panel to work is to go turn off and on the breaker. Door counter weights replaced 2x. UUGHHHH
Laughable garbage.... Lol love it- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
My 5th wheel jas the original Amana RadaRange Microwave. Still works great.Gustard X26 Pro DAC
never loved our higher end bosch tbh. Our 3ish year old kitchend aid is much better, except the drain seems to get clogged too easily…eer never mind they all suck!Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
Bosch or Bruegel. I like them both.
Your drain is clogging?
On your drain line does it leave the main drain going down or up?
I run mine up and it does a complete circle beside the sink strapped to the wall. Never had an issue
Knock on wood- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Scrape your dishes clean before putting them in, use a detergent with enzymes (the Great Value powder is the best detergent you can get), and clean your filter.My gear:- TCL 75QM7K TV
- RT3000p Fronts
- CS1000p Center
