Those darn appliances
    pitdogg2 Posts: 27,348
    ChrisD06 wrote: »
    I rarely use my microwave at 100%. I do not mind waiting 10-15 at say 20-30%. My food doesn't come out rubbery or splatter like a nuclear holocaust... B)
    Wait- are you saying I can genuinely use low power and just wait 10 minutes without worrying about it exploding?
    Does it heat evenly or do I still need to stir?
    Yes that is what I'm saying.
    You still must stir during the heat up. The nature of a microwave is very uneven, just the nature of the beast.
    treitz3 Posts: 20,129
    ChrisD06 wrote: »
    WilliamM2 wrote: »
    And how exactly do you maintain a microwave Chris? Change the oil?
    Cleaning it. Like once per day.
    I rarely clean ours because I have taught the family to use wax wrap and cover whatever it is they are cooking. Especially anything that's greasy or likes to explode all over the microwave. It's cheap, easy to use and definitely helps with the cleanup.
    mhardy6647 Posts: 35,244
    ChrisD06 wrote: »
    Standing waves -- just like loudspeakers in a room! B)
  • ChrisD06
    ChrisD06 Posts: 929
    ChrisD06 wrote: »
    I'm going to try this out next time I need to use the microwave because this may very well be life changing.
    My gear:
    • TCL 75QM7K TV
    • Onyko TX-NR656 AVR
    • RT3000p Fronts
    • CS1000p Center
    • RT35 Side Surrounds
    • RT35 Rear Surrounds
  • ChrisD06
    ChrisD06 Posts: 929
    treitz3 wrote: »
    ChrisD06 wrote: »
    WilliamM2 wrote: »
    My mom will continue to do it her way even if everyone else follows suite!
    She still pre rinses before using the dishwasher and uses wayyy too much detergent even after I showed her video proof that it could tank the mist ridiculous things when doing it my way... oh well.
    Now our nice glasses are slowly getting etched :/
    My gear:
    • TCL 75QM7K TV
    • RT3000p Fronts
    • CS1000p Center
  • WilliamM2
    WilliamM2 Posts: 4,808
    edited June 2024
    ChrisD06 wrote: »
    Unless it's an inverter microwave (most Panasonic's) it's always at 100%. It just switches the power on and off depending on the setting.
    An inverter microwave actually lowers the power to the magnetron. With a Panasonic you can actually completely thaw food, without it cooking at all. I'll never own anything else.
    https://www.panasonic.com/nz/consumer/household-learn/technology/what_s-an-inverter.html
    billbillw Posts: 7,809
    WilliamM2 wrote: »
    ChrisD06 wrote: »
    I was about to post the exact same thing, but you got it first. 100% correct fellas.
    The solution is to cover the dang food.
  • ChrisD06
    ChrisD06 Posts: 929
    WilliamM2 wrote: »
    ChrisD06 wrote: »
    I just learned something new today.
    Unfortunately ours looks like one of the few models they sell without an inverter. I will experiment with lower power levels anyways.
    My gear:
    • TCL 75QM7K TV
    • RT3000p Fronts
    • CS1000p Center
  • machone
    machone Posts: 1,566
    treitz3 wrote: »
    ChrisD06 wrote: »
    WilliamM2 wrote: »
    A damp paper towel laying on top works for a lot of foods
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
  • Willow
    Willow Posts: 11,258
    Our DW is on the fritz. We will need a new one. This time looking at a Bosch. Our issue is we don't want to spend lots as we'll be re-doing the kitchen within 5-7 yrs at which point we'll get the DW that we really want to get. So looking at the 100 or 300 series Bosch. Our current LG (Laughable Garbage) is 9 yrs but has acted up since the 3rd year. Racks are rusted after 2 years replaced under warranty new ones rusted right through in some areas, drying agent dispenser stopped working after yr 3. Sometimes the only way to get the control panel to work is to go turn off and on the breaker. Door counter weights replaced 2x. UUGHHHH
    VR3 Posts: 29,554
    Laughable garbage.... Lol love it
    audioluvr Posts: 5,990
    My 5th wheel jas the original Amana RadaRange Microwave. Still works great.
  • rooftop59
    rooftop59 Posts: 8,120
    Willow wrote: »
    never loved our higher end bosch tbh. Our 3ish year old kitchend aid is much better, except the drain seems to get clogged too easily…eer never mind they all suck!
    Game Room 5.1.4:
    Bedroom 2.1
    Viking64 Posts: 7,632
    Bosch or Bruegel. I like them both.
    VR3 Posts: 29,554
    Your drain is clogging?
    On your drain line does it leave the main drain going down or up?
    I run mine up and it does a complete circle beside the sink strapped to the wall. Never had an issue
    Knock on wood
  • ChrisD06
    ChrisD06 Posts: 929
    rooftop59 wrote: »
    Willow wrote: »
    Scrape your dishes clean before putting them in, use a detergent with enzymes (the Great Value powder is the best detergent you can get), and clean your filter.
    My gear:
    • TCL 75QM7K TV
    • RT3000p Fronts
    • CS1000p Center
