Has anyone tried two pairs of front speakers? Does it produce a fuller sound stage?
blueskies
blueskies Posts: 33
Anyone tried it?
    Clipdat Posts: 13,095
    It sounds good, but not as good as four pairs of fronts.
  • blueskies
    blueskies Posts: 33
    Clipdat wrote: »
    pics?
    treitz3 Posts: 20,007
    He's joking. You might experience a bigger sound but at the expense of lobing.
    VR3 Posts: 29,440
    16 for the win
    Two high quality speakers trumps anything additional
    F1nut Posts: 51,789
    One pair of speakers stacked on another pair of speakers stacked a pair of subs is da bomb.
  • HzTweaker
    HzTweaker Posts: 959
    Stacks on stacks on stacks.lol
    nooshinjohn Posts: 25,930
    edited May 2024
    Why stop there… just build a wall of sound, and crank it to 11.
  • maxward
    maxward Posts: 1,699
    Back in the very early days, Harry Pearson (HP) had good things to say about double Advent speakers.
    BITD, we tried something like that with 3 sets of speakers. This was the last day of one of the very early Carverfest's . We took a pair of ALIII's, a pair of Platinum's and a pair of Amazing's and put them all on one system.
    We always did crazy stuff up on the mountain, just for fun. We called this one, "The Wall of Sound". It sounded like crap but it was definitely an experience. It reminded me of being at a concert. I believe it was the next year, we took 2 sets of 1.2TL's and stacked one pair up on top of the other, then went to listen to it up on the 2nd story loft. I can't seem to find a photo of that one, as the forum it was originally posted on has since closed up shop.
    One of the funniest things we did was fool people with a pair of Apogees. We disabled the ribbon portion of the speaker and placed a pair of bookies (I believe that they were DCM Time Windows) in their place, but placed behind the grill cloth and on top of the woofer assembly of the Apogee's. We locked the front sliding door, so people couldn't really see what we had done. When they came in, we sat them down and asked them how they liked the Apogee's.
    I think it took about 4 or 5 hours of listening like this before someone figured out what we had done. 😀 Good times! (It actually didn't sound that bad)
    pitdogg2 Posts: 27,064
    I couldn't fathom the load those put on what ever amp you used..... BUT I'm sure it was low :smiley:
    I believe that was Gary's (@TNRabbit....RIP, buddy) Sunfire 600x7 amp. The rest of the system was cobbled together from all of the attendees of the event.
    Yes, the load was very demanding. That said, it did handle it without breaking a sweat.
  • motorstereo
    motorstereo Posts: 2,343
    Stacked fronts? I've had a few. Here's a Mcintosh ml1c sitting atop a Bozak Concert Grand. Sadly or maybe just as well I can't find the pic of my old 2.3s sitting atop a pair klh 12's.
  • blueskies
    blueskies Posts: 33
    I'm basically looking to put two lsi15's on each side of the tv.
    VR3 Posts: 29,440
    It's probably fine as long as you don't critically listen
    VR3 Posts: 29,440
    I believe the Lsi15 is 4 ohm nominal so I would run them in series
  • blueskies
    blueskies Posts: 33
    VR3 wrote: »
    what does running them in series mean?
    VR3 Posts: 29,440
    VR3 Posts: 29,440
    If you run parallel it will be 2 ohm nominal and not many amps can pull that off
    Here's a better idea, don't do it at all.
    VR3 Posts: 29,440
    I mean sure but atleast this way he won't blow anything up haha
  • Emlyn
    Emlyn Posts: 4,719
    edited May 2024
    Yamaha receivers used to have a setting for "width" speakers up front, before height speakers became a thing, but those weren't intended to be full range.
    They may still have that option in new models but I haven't kept track of them for a while. I understand Dolby Atmos processing also has settings for front width satellite speakers but again they don't need to be full range and the processor handles setup to minimize audible interference.
    I'd much rather use the extra space up front for dual subwoofers. Seems to me that having two sets of main speakers up front would mainly be correcting for a single set of main speakers not performing very well to begin with. Stereo speakers should produce a good impression of width if they're properly set up.
    Post edited by Emlyn on
  • boston1450
    boston1450 Posts: 7,758
    Those look massive. Beautiful speakers
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
    F1nut Posts: 51,789
    blueskies wrote: »
    No, just NO!
    You might like it at first but mark my words. The initial romance period will not last long and you will not like the sound after a while.
    Comb filtering and acoustical lobing will make the sound almost unbearable in the long term.
    Imaging will be non-existent and smearing of images will be really exagerrated. Even spatial locationality cues will shift, when they are not supposed too.
    This is just the plain, honest truth of what you will eventually learn, if you do this.
  • SDA1C
    SDA1C Posts: 2,072
    bi anp and subs on sub freq out. way better sound and stability.
    Too much **** to list....
  • invalid
    invalid Posts: 1,457
    edited May 2024
    Some people used to stack apogee speakers
    mhardy6647 Posts: 35,042
    OK.
    ahem.
    maxward wrote: »
    Yes, yes he did.
    In the 1970s, it was kind of a thing.
    The OLAs were/are, at least IMO, deeply flawed loudspeakers.
    So there's that.
    HzTweaker wrote: »
    Sounds like turtles. Turtles all the way down. B)
    https://en.wikipedia.org/wiki/Turtles_all_the_way_down
    Indeed.
    Go big or go home.
    Stacked Ohm Walsh F. Sort of like MBLs, but more likely to do major damage when they topple. Cheaper, though. :#
    Mark Levinson's HQD loudspeakers. Looks like two stacked pairs of Quad ESL-57s? Bingo.
    B)
    Oh, where were we?
    "Two pairs of front loudspeakers...?"
    Two words, Benjamin.
    Just.
    Don't.
    Any Questions?
