Interest check? Power cable beta test
VR3
So working on designing an entry level power cable
14 awg, silver plated copper
Heavy duty ends, copper
Heavily shielded and damped, black flex exterior
Ferrite core
Overall diameter expected to be right under one inch thick and be reasonably flexible. Would consider this a component cable versus a power amp cable.
15 Amp ends
4 ft length
Estimating price would be $150 to $175 to purchase. Only cost to demo would be shipping to the next person
Any interest in trying this out and providing feedback /review?
Ferrite core
15 Amp ends
4 ft length
I’ll bite.
If you're doing this in pairs I'm interested..
All power cable sound same
Pairs? Like two power cables?- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
So this will be a small run.
It will be 6 cables, approximately 3.5 ft in length.
Viborg, pure copper male and female ends (standard IEC, 15 amp)
10 awg tin plated copper wiring, 600v rated, internally damped
black flex finish, overall metal mesh shield with additional dampening - around .85" overall diameter
dual ferrite rings
finished with heavy duty 3:1 heat shrink over ends and ferrite rings
Will be $140 shipped
Depending on the feedback of those 6 in the demo rounds, I will make adjustments.
Should be ready to send out end of May. I can send a pair of cables as well if that makes the demo make more sense for folks!
- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
This sounds pretty cool. I'm down with Viborg products. I've been recently using Viborg pure copper and silver-plated copper banana plugs in my set up.
I may be interested in your demo offer as well! It sounds like you're putting together a pretty decent cable.Set up: 11.2 HT + 2ch
When I was young, I was Superman but now that old age has gotten the best of me I'm only Batman -
I think it will perform really well curious to hear the results and hear everyone's feedback!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Sure as long I'm in the new house and in the new dedicated room.
Sure that shouldn't be a problem at all.
Just wanted to add this will be for established members only.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
my interest is piqued . . . would deff be WAAY Mo Betta than the stock cable provided by EVSAC Regenerator PS Audio PerfectWave Power Plant 10
Pre Cary SLP-05
Power Rogue M180 Dark monos
Mains Salk HT2-TL
Rythmik F12 -
I'm interested. I've only bought fairly inexpensive power cables and can't say I've heard much(if any) of a difference vs. stock. Maybe my hearing has gotten to the point that I just can't tell?
These cables will help me to learn if I indeed can hear any difference in high end cables and if I should go down that rabbit hole.Yep, my name really is Bob.
Parasound HCA1500A(indoor sound) and HCA1000(outdoor sound), Dynaco PAS4, Denon DP1200 w/Shure V15 Type V and Jico SAS stylus, Marantz UD7007, Polk L600, Rythmik L12 sub. -
I would be interested in comparing cables. Just finishing my two Chanel set up. Picking up a new musical fidelity preamp today to replace an older NAD.L600 (front), R200 (rear), R200 (rear surround), L400 (center), Sunfire HRS-10 (2)Marantz AV7706Sunfire Cinema Grand, Marantz M8077, Music Hall Stealth, Ortofon bronze cartridge, Parasound Zphono XRM, Sony UBP-X800
Any interest in doing 6’ cables in the near future…. Interested.
Skip -
I’m inMagico M2, JL113v2x2, EMM, ARC Ref 10 Line, ARC Ref 10 Phono, VPIx2, Lyra Etna, Airtight Opus1, Boulder, AQ Wel&Wild, SRA Scuttle Rack, BlueSound+LPS, Thorens 124DD+124SPU, Sennheiser, Metaxas R2R
Ok, so I am still waiting on stuff but I have decided the test will Include 3 cords.
Level 1 shielding
Level 2 shielding
Level 3 sheilding
Level 1 cable assembled
skipshot12 wrote: »Any interest in doing 6’ cables in the near future…. Interested.
Skip
For right now, I will only be making 3 ft... Ish cables but depending on the feedback, 6 ft would become an option. Just not for a demo program but I could maybe send you one in the future to give a go!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Im gonna wait for the feedback but I will prob be a customer at the end of it all.
Always good to have some extra power cords in the stable."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
For right now it's more of like a test run/fun thing to see what different techniques translate to and if someone wants to buy anything that's fine to. I think at the price point they should perform really well.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
They look thick. How flexible are they? Any issues with weight and the plug? I had an issue with some power cords weighing too much and the cords slipping out of components or vibrating loose.Klipsch The Nines, Audioquest Thunderbird Interconnect, Innuos Zen MK3 W4S recovery, Revolution Audio Labs USB & Ethernet, Border Patrol SE-I, Audioquest Niagara 5000 & Thunder, Cullen Crossover II PC's.
Their bend and weight is in line with what I am currently using in my system. You would need maybe 6 inches off the wall to do the first 90 from the component
I have plans for a smaller cable but want to see how this test run goes on this thicker cable and the different shielding methods.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Skip
Gotcha……
Thank you. -
I'm guessing this is for IEC not C19?
I can send you one of these to try out, use and demo to other people if you like.
Viborg VF523G Hi End Power Connector Pure Red Copper Gold Plated IEC C19 Power Plug, 20Amp Female Audio Mains Plug for Power Cable DIY (VF523G, Gold Plated) https://a.co/d/a8Ma16d -
Correct.
For right now I want to keep everything the same as each cable sent will be a little different, different techniques etc to see feedback differences.
Based on that feedback can then start doing longer cables, different connectors etc.
I think this is kind of fun trying different things 😁- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
I recently read in another forum of a member who bought an expensive PC for his power amp and could not tell any difference vs stock cable. Another member said you would be more likely to hear a difference putting the PC upstream...,DAC, cd player, etc. Is that the general consensus here too?Yep, my name really is Bob.
It will be system dependent for sure- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Like Trey said it varies and it’s possible there are better improvements to make before one.
For example, if you DO NOT have a dedicated 15 amp circuit for your gear THAT would be what I would do over a powercable (assuming you are able to wire one)."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
Expensive does not necessarily equate to better sonics. I learned that the hard way.
I heard a HUGE difference in the amp (with a specific amplifier cable) and also with a RAL umbilical.
That said, I heard an even bigger difference when I upgraded the PC to the pre and the sources.
Like Trey stated.....it is completely system dependent. Too many variables to tell you what would work 100%.
Tom~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
