Interest check? Power cable beta test
VR3
VR3 Posts: 29,549
So working on designing an entry level power cable
14 awg, silver plated copper
Heavy duty ends, copper
Heavily shielded and damped, black flex exterior
Ferrite core
Overall diameter expected to be right under one inch thick and be reasonably flexible. Would consider this a component cable versus a power amp cable.
15 Amp ends
4 ft length
Estimating price would be $150 to $175 to purchase. Only cost to demo would be shipping to the next person
Any interest in trying this out and providing feedback /review?
«134
  • maxward
    maxward Posts: 1,718
    Toolfan66 Posts: 18,182
    If you're doing this in pairs I'm interested..
    Clipdat Posts: 13,100
    All power cable sound same
    VR3 Posts: 29,549
    Pairs? Like two power cables?
    VR3 Posts: 29,549
    edited April 2024
    So this will be a small run.
    It will be 6 cables, approximately 3.5 ft in length.
    Viborg, pure copper male and female ends (standard IEC, 15 amp)
    10 awg tin plated copper wiring, 600v rated, internally damped
    black flex finish, overall metal mesh shield with additional dampening - around .85" overall diameter
    dual ferrite rings
    finished with heavy duty 3:1 heat shrink over ends and ferrite rings
    Will be $140 shipped
    Depending on the feedback of those 6 in the demo rounds, I will make adjustments.
    Should be ready to send out end of May. I can send a pair of cables as well if that makes the demo make more sense for folks! :)
  • Geoff4rfc
    Geoff4rfc Posts: 2,957
    edited April 2024
    VR3 wrote: »
    This sounds pretty cool. I'm down with Viborg products. I've been recently using Viborg pure copper and silver-plated copper banana plugs in my set up.
    I may be interested in your demo offer as well! It sounds like you're putting together a pretty decent cable.
    VR3 Posts: 29,549
    I think it will perform really well curious to hear the results and hear everyone's feedback!
    heiney9 Posts: 25,497
    Sure as long I'm in the new house and in the new dedicated room.
    VR3 wrote: »
    Yes sir..
    VR3 Posts: 29,549
    edited April 2024
    Sure that shouldn't be a problem at all.
    Just wanted to add this will be for established members only.
  • GlennDog
    GlennDog Posts: 3,158
    my interest is piqued . . . would deff be WAAY Mo Betta than the stock cable provided by EVS
    Pre Cary SLP-05
    Power Rogue M180 Dark monos
    Mains Salk HT2-TL
    Rythmik F12
  • muncybob
    muncybob Posts: 3,267
    I'm interested. I've only bought fairly inexpensive power cables and can't say I've heard much(if any) of a difference vs. stock. Maybe my hearing has gotten to the point that I just can't tell?
    These cables will help me to learn if I indeed can hear any difference in high end cables and if I should go down that rabbit hole.
    Yep, my name really is Bob.
  • JCL
    JCL Posts: 170
    I would be interested in comparing cables. Just finishing my two Chanel set up. Picking up a new musical fidelity preamp today to replace an older NAD.
    L600 (front), R200 (rear), R200 (rear surround), L400 (center), Sunfire HRS-10 (2)Marantz AV7706Sunfire Cinema Grand, Marantz M8077, Music Hall Stealth, Ortofon bronze cartridge, Parasound Zphono XRM, Sony UBP-X800
  • skipshot12
    skipshot12 Posts: 2,092
    Any interest in doing 6’ cables in the near future…. Interested.
    Skip
  • Joey_V
    Joey_V Posts: 8,603
    I’m in
    VR3 Posts: 29,549
    edited May 2024
    Ok, so I am still waiting on stuff but I have decided the test will Include 3 cords.
    Level 1 shielding
    Level 2 shielding
    Level 3 sheilding
    Level 1 cable assembled
    VR3 Posts: 29,549
    edited May 2024
    skipshot12 wrote: »
    Skip
    For right now, I will only be making 3 ft... Ish cables but depending on the feedback, 6 ft would become an option. Just not for a demo program but I could maybe send you one in the future to give a go!
    EndersShadow Posts: 17,722
    edited May 2024
    Im gonna wait for the feedback but I will prob be a customer at the end of it all.
    Always good to have some extra power cords in the stable.
    VR3 Posts: 29,549
    For right now it's more of like a test run/fun thing to see what different techniques translate to and if someone wants to buy anything that's fine to. I think at the price point they should perform really well.
  • erniejade
    erniejade Posts: 6,321
    They look thick. How flexible are they? Any issues with weight and the plug? I had an issue with some power cords weighing too much and the cords slipping out of components or vibrating loose.
    VR3 Posts: 29,549
    edited May 2024
    Their bend and weight is in line with what I am currently using in my system. You would need maybe 6 inches off the wall to do the first 90 from the component
    I have plans for a smaller cable but want to see how this test run goes on this thicker cable and the different shielding methods.
  • skipshot12
    edited May 2024
    VR3 wrote: »
    skipshot12 wrote: »
    Skip
    Gotcha……
    Thank you.
  • CH46E
    CH46E Posts: 3,595
    edited May 2024
    I'm guessing this is for IEC not C19?
    I can send you one of these to try out, use and demo to other people if you like.
    Viborg VF523G Hi End Power Connector Pure Red Copper Gold Plated IEC C19 Power Plug, 20Amp Female Audio Mains Plug for Power Cable DIY (VF523G, Gold Plated) https://a.co/d/a8Ma16d
    treitz3 Posts: 20,116
    Correct.
    VR3 Posts: 29,549
    edited May 2024
    For right now I want to keep everything the same as each cable sent will be a little different, different techniques etc to see feedback differences.
    Based on that feedback can then start doing longer cables, different connectors etc.
    I think this is kind of fun trying different things 😁
  • muncybob
    I recently read in another forum of a member who bought an expensive PC for his power amp and could not tell any difference vs stock cable. Another member said you would be more likely to hear a difference putting the PC upstream...,DAC, cd player, etc. Is that the general consensus here too?
    VR3 Posts: 29,549
    It will be system dependent for sure
    Like Trey said it varies and it’s possible there are better improvements to make before one.
    For example, if you DO NOT have a dedicated 15 amp circuit for your gear THAT would be what I would do over a powercable (assuming you are able to wire one).
    edited May 2024
    muncybob wrote: »
    Expensive does not necessarily equate to better sonics. I learned that the hard way.
    I heard a HUGE difference in the amp (with a specific amplifier cable) and also with a RAL umbilical.
    That said, I heard an even bigger difference when I upgraded the PC to the pre and the sources.
    Like Trey stated.....it is completely system dependent. Too many variables to tell you what would work 100%.
  • bcwsrt
    bcwsrt Posts: 2,509
    edited May 2024
    I saw the thread you’re referring to. I agree with @VR3 and @treitz3. I swapped my stock PC back in to my Rogue Audio tube integrated amp after a couple months of listening to it with a Nordost Red Dawn PC just for grins. I think that lasted about two songs.
    Brian
