CSW Henry Kloss Tower II - no audio in bottom 2 speakers
haasenstein
Hello,
I have the jumpers, but no sound is coming out of the bottom two speakers in only one of the towers. The other tower is working fine. I've tried removing jumpers and having both sets of speaker wires connected. I've tried with and without banana plugs. I took off the plug panel and made sure the wires matched the one that's working. The jumpers work because regardless of which set (top or bottom) connectors are used, only the same top two higher range speakers activate. Any ideas?
Answers
You could take out woofers & test them. OR. You could try swapping the woofers that are not working with into the other cabinet & see if it follows. This would show you if the woofers are ok & it would narrow it down some.. I would suggest while your in there to look at all wires & look at capacitors on the crossover. If you have ways to check values with a meter & compare to good cabinet. I don't know the speaker-maybe someone else will chime in. Good luckRandy-Maine
2ch-RTA15tl crossover upgrade
by David WMG
Yamaha cr1000 cr2040
HT-Yamaha Parasound Acurus
Thanks! I appreciate what you said...totally makes sense. I unscrewed one of the speakers but can't get it out and don't want to cause damage. I have never tested/repaired speakers (or anything in an audio chain) before.
Understand that. Looks like only access is at lower woofers too.Randy-Maine
by David WMG
Gotcha, thanks. Maybe I can reach in and push it out via connector/plug port in back...
Try the other woofer. Never knowRandy-Maine
by David WMG
I'm not a fan of those jumper plates. I always change them out with good speaker wireRandy-Maine
by David WMG
Also. It is odd that both are not working. Something is probably unplugged or crossover issue or speaker wire connectRandy-Maine
by David WMG
If the two woofers are connected in series and one of them has an open voice coil neither woofer will work. The only way to tell is to remove them and try playing them directly.
^^^^ thisRandy-Maine
by David WMG
SeleniumFalcon wrote: »If the two woofers are connected in series and one of them has an open voice coil neither woofer will work. The only way to tell is to remove them and try playing them directly.
Not sure if these are "open voice coil"
Do you have a vm meter- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Actually if you read "OL" (open lead) you have an open voice coil, if there's a "0" the voice coil is shorted. You should read around 4 or 8 ohms, most likely.
Pretty sure they're both junked. First pic is baseline without a connection (unit displays "1"). That makes me wonder - what caused it and if the tower itself is otherwise okay and won't damage replacements, where can I find 2.
It looks like you just need one, the second one you posted. If the first one doesn't make any scratching noises when you press in on the cone then it is probably okay. As to finding the replacement, I would look on eBay or maybe there's a vintage Cambridge Soundworks group? In the meantime if you wanted to continue using the speaker find a 3.0 ohm 5 watt resistor (Digikey or Mouser) solder it across the two terminals of the open woofer. Then reinstall the woofers and you should be able to use the speaker while you source a new one.
