Assembling a pair of Legends
    nooshinjohn Posts: 25,162
    Finally got a tracking number for the 4 woofers. The replacement tweeters are on the way as well
    Here is a look at the drivers for the L 600. The magnet structures are pretty large and heavy compared to Polk Audio products in the past. The baskets, however, are still made relatively thin, although they do have indentations in the structure to provide extra strength and support. I can easily see how some Dyna mat could improve the performance of the speakers by eliminating ringing within that structure. 0qh153j92egv.jpg
    edited April 10
    This speaker has been prepped and ready for driver installation. This is a picture of the speaker before I begin doing that.ooclxxy3e3gn.jpg
    All drivers placed in position and ready to be secured. One thing about installing the drivers in the speakers is that they have to be oriented in such a way as to allow the pins on the beauty rings to clip in place. If you secure the driver in the wrong position, you will cover those holes and making it nearly impossible to fit the trim rings in place.
    The legend series uses different size connectors for positive and negative. This makes it idiot proof for making certain that you’ve got the right connections.
    One note about the tweeter around the outside of the bezel. It has a piece of 3M double-sided tape, which is used to secure the trim ring around it. I find using that tape to be redundant because the plate also has magnetic coupling, so just sliding into place in allowing the magnets to grip it makes it easier if you have to remove the driver later.7aa4e6q8jyag.jpg
    pitdogg2 Posts: 24,659
    This little piggie went to market....... :D:D
  • Kex
    Kex Posts: 4,943
    Lovely pinky toes for such a grumpy old geezer! 😜
    Alea jacta est!
  • gyosa
    gyosa Posts: 716
    Kinda surprised Polk is using stamped steel baskets for speakers in this price point .
    How about the L800’s ?
    Bk
    PS Audio S300 , Yamaha wxc-50 , Salk SuperCharged Songtowers , Kimber Kable 4TC, Sony 42” - BEDROOM
    B&K EX-442 ( it will go in my casket when I die ... ) , PS Audio 4.6 preamp ( old school , but it still jams on ... ) , Eversolo DMP-A6 , Boston Acoustic voyager 7’s - POOL
    Parasound A21, Eversolo DMP-A8 , Kimber Kable 4vs , Ascend Acoustics ELX Ribbon Towers , Sony XBR-A8F 65” OLED - DEN , MAIN system
    Onkyo TX-nr609 , Polk atrium 7 , Boston acoustic sound ware (4) , Boston acoustic sub , B&W center , Sharp 65” TV - PATIO
    gyosa wrote: »
    Bk
    Stamped steel in there as well
    VR3 Posts: 28,148
    It's an engineering over correction... Lsim cast baskets were breaking so they reverted all the way to stamp steel.
    Kind of like when Janet Jackson revealed herself at the super bowl the next year was Paul McCartney playing piano for 15 minutes
  • muncybob
    muncybob Posts: 2,979
    So, not applying Dynamat to the baskets while they are open?
    Yep, my name really is Bob.
  • JayCee
    JayCee Posts: 1,488
    edited April 12
    muncybob wrote: »
    I'd do so and will at some point when I go into my L800's. Surprisingly, John called his 1.2tl's fully modded at one point but didn't Dynamat. He later corrected his statement to say 'fully modded' but short of Dynamat 'cause he didn't have the time. Not sure where he lands re. this...?
    Speakers: Polk1.2tl's (Uber Mods) Pre/Amp/DAC: PS Audio BHK Signature & 250, DirectStream Cables/IC's: MIT S1Bi-Wire/S1 Balanced +Avel Lindberg 1000VA "Dreadnought" Power Conditioner: PS Audio P15 Power Plant Power Cords: Core Power Technologies Gold, DH Labs Power Plus DIY w/Neotech NC-P301 & P311ends Streaming: Roon ROCK on wifi'd NUC, TP-Link WAP, & Uptone EtherREGEN, AfterDark, Emperor Double Crown Clock, Black Modernize LPS, PS Audio AirLens⟿Ω☯☥☮⟿🔊♩♪♫♬♩♪♫♬♩♪♫♬
    heiney9 Posts: 25,097
    gyosa wrote: »
    Bk
    Same drivers for all Legend speakers and I wouldn't be surprised if the same drivers are used in the Reserve series.
    Main differences are cabinet structure, material and more sophisticated x-overs L vs. R.
    **UPDATE on this project? Are they complete?
    edited May 4
    heiney9 wrote: »
    They are complete minus the trim rings around the drivers and binding post plates. I do have the CAD drawings for for the rings but no way of putting them to use at the moment.
