Phase Plug design for MW65xx
That surround looks twice as big as the old, is it or is that a photo misnomer?
Do you have a microgram balance? Just wondering about how the weights compare and also of course stiffness if you have any idea.George / NJ
Onkyo A-8017 integrated
iFi nano iDSD DAC
iPurifier3
iDefender w/ iPower PS
Just meaured a CF surround and the fold-over is 0.50' wide on the CF, as compared to 0.40" wide on the factory. Th CF surround does feel a little more weighty however.
No uG balance here, but interestingly the CF cone and heavier surround feel about same weight as old one I cut out, so the CF cone itself must be lighter?. The CF is MUCH stiffer than the factory paper cone and was very hard to cut with a new scalpel. It did not fray as that was my worry cutting it.
Later, I plan on building a set of omnidirectional drivers using these CF cones, so was good practice working with them....
Don't take experimental gene therapies from known eugenicists. -
Bottom/center dry. Now have the surround glued and weighted down...
Cleaned up edges and used a 10mm leather punch for the bolt head clearances...
Ill do a comparo after dinner...
It is the phase-plug thread ya know...
Loctite already set, so gave them the same wintergreen oil solution as I do the factory surrounds...
Sad Old Red up first...
Mick, Sade, and Sting all passed the the test with flying colors.
I wouldn't hesitate to do this repair again. The cone holds it shape at very high volume, zero distortion and hard to tell a difference between the plugged 6502 with damped paper cone.Don't take experimental gene therapies from known eugenicists. -
Pet Shop Boys midrange was crystal clear with high volume accompanying bass...
https://youtu.be/wz4pQGxK25Y?si=x2P2f6nYeGwTJ7UC Don't take experimental gene therapies from known eugenicists. -
Nicely done!!George / NJ
iFi nano iDSD DAC
iPurifier3
Definitely keepers. Here's the carbon Wuhans I used...I'll be ordering a few more.
Time to go listen to the SDA's.
https://www.ebay.com/itm/193941704625?var=494136088548Don't take experimental gene therapies from known eugenicists. -
Recent Danny Richie video where he describes the midwoofers @6:25:
"We did an 8 ohm and a 16 ohm version and the 8 ohm version you see here in the NX Studio Monitor, and we went all out with the design on it; polymer chassis, lightweight paper cone, copper shorting rings in the motor structure, all copper coated motor structure, I mean we did everything on this thing, venting through the front, solid aluminum pole piece copper coated *, the works, and the result was one of the best sounding woofers there is on the market to this day."
* I looked the driver up on his website and, yes he did mean solid aluminum phase plug attached to pole piece
https://gr-research.com/product/m-165nq/
https://www.youtube.com/watch?v=7h72KXd8Q3c George / NJ
iFi nano iDSD DAC
iPurifier3
Yet another example with a metallic phase plug, aluminum shorting ring, and copper capped pole piece:
http://nedlab.com/wp/wp-content/uploads/2014/06/Peerless-850467-woofer.pdf
George / NJ
iFi nano iDSD DAC
iPurifier3
George / NJ
iFi nano iDSD DAC
iPurifier3
I think we talked about it before but most drivers with a plug are very deep cones. The Polk cones are not very deep in comparison which is why I think you see mixed results.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
I do remember someone presenting that "opinion" without any in depth rationalization, in a thread that got nuked by admin due to lack of civility. Doesn't have any bearing on the elimination of the resonant cavity under the dust cap, the greater cooling of the voice coil resulting in less power compression, or the reduction in distortion due to reduction of change in inductance and impedance with displacement of the coil.
I presented information above somewhere that the highs tend to be produced near the center of the cone, ie. near the phase plug. The cone tends to act as a waveguide in this case. The phase plug tends to make the driver behave more as a point source of sound for the highs, which is desireable. But does this look all that much different from the depth of the Polk MWs?
George / NJ
iFi nano iDSD DAC
iPurifier3
To refine my view point. A plug shaped like the original dust cap would most likely be better received by the collective- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Maybe based upon keeping the looks more traditional, especially if it was black.
But I would hate to lose the benefit I got in my 7Bs where the harmonics are much better dispersed to the point where I can listen just fine way off axis.George / NJ
iFi nano iDSD DAC
iPurifier3
If I recall Ray liked them in the traditional models but not the sda?
Either way, this hobby is all about fun and if you like it that's all that matters!
I just think it's more invasive than most folks want to go- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Ray didn't test in anything other than his SDA CRS+, but the driver that he supplied Rob with had a sagging suspension and off centered voice coil. Rob didn't modify the existing driver, it was ones that Ray had in storage somewhere and they weren't listened to prior to Rob's modification.
I miss his posts.George / NJ
iFi nano iDSD DAC
iPurifier3
And oh yeah, I continue to be happy with this mod. Remembering back, the first thing I noticed is that hi hat cymbals sounded so much more natural (you know that tssss sound), probably due to less constructive and destructive interference of those higher harmonics which are close to the crossover point of the midwoofer. It is those frequencies that I think the phase plug has acoustical influence on the wavefront due to it's size relative to the wavelength.George / NJ
iFi nano iDSD DAC
iPurifier3
Glad work has been going on behind the scenes."Sometimes you have to look to the past to understand where you are going in the future"Harry / Marietta GA
Good news. 360 Brass is non-magnetic...
Tested a neodymium on a 1" stock and a plate for a couple RDO plate copies....
Is there anything you can't do xschop? I have missed a lot in 5 years, you have made so many people happy ,including myself, thanks mate!VR3 SDA SRS 1.2TL Duelund Monoliths+VR31000va Dreadnaught +VR3 MM2 SDA cable,
,Lumin u2x ,<-sfp fibre <-LHYas8 Pro+ Switch,Transparent Reference MM2 xlr,power and speaker cables.FTA Sinope SE usb.40 Amp power line for amp with earth stake&Faraday shield ,20 Amp power line for digital equipment ->shunyata 8 venom power board...Working on it! -
I can't do turkey bacon.
Philippians 4:13Don't take experimental gene therapies from known eugenicists. -
When I get a chance, I'll mod a set of 6502's with these copper shorting rings I made and the aluminum phase plugs. I'll see if I hear a difference or see the same low frequency control behavior as with the focus rings.
Should be a fun experiment...
0.995 OD (Matches Pole Piece)
0.890 ID
0.330 Width
^^ I can't wait for this Rob! Will there be a small gap between the inside of the shorting ring and the pole piece like I seem to see in all the patent drawings or do you think maybe it doesn't matter and they just drew it that way? Drawings I have seen of the focus ring seemed to have that same gap, incidentally, between the focus ring and the magnet. Whether that matters I also don't know.
Also, I can't help but wonder what the effect would be to machine away a small amount of an aluminum phase plug at the base and put a shorter copper ring on there, maybe electrically insulated from the aluminum?George / NJ
iFi nano iDSD DAC
iPurifier3
To your 2nd paragraph, not sure it will benefit. The alum alloy can corrode quickly being anodic to copper.
Guess I could recess the pole piece area under the ring since it wont be in the gap. To me that removes more steele mass from the flux equation. Will it be a benefit or detriment?Don't take experimental gene therapies from known eugenicists. -
I think that, if a small copper ring was tried at the base of the aluminum phase plugs it could be a slip fit; maybe a loose one, and ample loctite could be used between the ring and the phase plug. That would solve the problem of dissimilar metal corrosion and should give electrical isolation to keep it as a clean high-conductivity shorted turn whose resistance and frequency behavior are predictable and not diluted by parallel paths through the aluminum. Aluminum is about 61% of the conductivity of copper.George / NJ
iFi nano iDSD DAC
iPurifier3
