Repairing speakers
I have a pair of monitor 70s series 2. I had them in storage for a little bit and I've noticed that the screws that hold the woofers into the cabinet have rusted. Anyone know what kind of screws these are and where I can get some? TIA
Answers
    F1nut Posts: 52,406
    Remove one screw and post a few photos of it.
  • GramKracka
    pitdogg2 Posts: 27,921
    edited April 2024
    those do not look too bad, I've seen a lot worse. Clean them off with a wire brush.
  • GramKracka
    That was one of the better ones. There are some that are far worse
  • Gardenstater
    Gardenstater Posts: 4,991
    edited April 2024
    I see them on amazon but they seem to be in metric sizes. You will need to measure the ones you have with whatever means you have. A dial caliper would be ideal.
    https://www.amazon.com/Hexagon-Socket-Tapping-Stainless-Speaker(100/dp/B09M9WR756?th=1
    ^Good luck telling that China seller exactly what diameter you want. Seems to be no way I can see lol.
    Parts Express has some sizes:
    https://www.parts-express.com/search?keywords=cap head wood screws
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
    F1nut Posts: 52,406
    Those are self tapping socket cap screws. No idea what size you have, so you'll have measure one. Likely a metric size.
    Here are some examples.
    https://www.rtlfasteners.com/RC/mm.html
  • GramKracka
    Thank you for the link
  • Gardenstater
    edited April 2024
    This one has ability to specify exact size you want to order:
    https://www.amazon.com/dp/B0CR8M4TBV/ref=sspa_dk_detail_0
    M4 x 20 would be my "guess"
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • GramKracka
    The whole screw is an inch long and takes a 3mm allen wrench.
    F1nut Posts: 52,406
    One inch is 25mm. You need the measurement of the threaded area not including the head, so I'm guessing the threaded area is 20mm (3/4") long.
    Metric screw diameters are noted as M4, M6, M8, etc. Chances are yours are M4 or M6.
  • odcics2
    odcics2 Posts: 396
    Take it your local hardware store.
    F1nut Posts: 52,406
    odcics2 wrote: »
    Good luck with that...lol
  • GramKracka
    Yeah I've gone to 3 hardware stores with no luck
  • joebass3
    joebass3 Posts: 311
    I'd take them to the wire wheel, poke them through a piece of cardboard, dust a little black paint on the heads and call it a day.
    VR3 Posts: 29,763
    Do you have advice on where to buy black paint?
  • halo71
    halo71 Posts: 4,644
    VR3 wrote: »
    damnit....you beat me to saying that!
    --Gary--
  • michaeljhsda2
    michaeljhsda2 Posts: 2,224
    edited April 2024
    SDA SRS 2.3TL's
    SDA 2B TL's
    VR3 Posts: 29,763
    halo71 wrote: »
    VR3 wrote: »
    My advice to up your game is to have a baby and that way you don't sleep... Ever
    mhardy6647 Posts: 35,562
    Does it matter whose navel it comes from?
    Askin' for a friend. :|
  • odcics2
    odcics2 Posts: 396
    odcics2 wrote: »
    Mid-States Bolt and Screw can hook you up. Send them a pic and dimensions.
  • michaeljhsda2
    It's jelly from the Navy not from someone's navel.
    SDA SRS 2.3TL's
    SDA 2B TL's
    F1nut Posts: 52,406
    odcics2 wrote: »
    odcics2 wrote: »
    That's not a local hardware store. George and I already posted links to places to buy the screws.
  • odcics2
    odcics2 Posts: 396
    edited April 2024
    odcics2 wrote: »
    odcics2 wrote: »
    He said his local hardware stores were useless. I posted an alternative that helped me a lot restoring 60s vintage equipment.
    Trying to be helpful. That ok??
  • TennMan
    TennMan Posts: 1,266
    edited April 2024
    VR3 wrote: »
    I was going to suggest Sherwin-Williams but decided I had better call to make sure they had it in stock. I called and asked if they had black paint that would be good to use to paint the heads of screws. They told me the only way they could tell me for sure is if I could tell them the size of the screws. Go figure...
  • mrbigbluelight
    mrbigbluelight Posts: 9,878
    That makes sense as black paint comes in different sizes.
    msg Posts: 10,650
    Naval jelly will remove the rust.
    Yes, this, and dry them with Bellybutton Lint.
    Yeah, I agree, even if they're rustier. As long as it's just surface rust and not full-on corroded, cleaning them and then coating with 3-in-1, chain & cable lube, or maybe even 2WD.
    To me, that would be more enjoyable and less hassle than trying to find fasteners. Not to mention, keeps them original.
    Timely note about Naval Jelly @michaeljhsda2 - I've got another project that I'm curious to try that on now. I think I once tried it years ago, though, and it didn't do anything for rust.
    PS - I always read your name as MichaelJihad2. I'm sure MichaelJihad1 was taken.
