Repairing speakers
GramKracka
I have a pair of monitor 70s series 2. I had them in storage for a little bit and I've noticed that the screws that hold the woofers into the cabinet have rusted. Anyone know what kind of screws these are and where I can get some? TIA
Answers
Remove one screw and post a few photos of it.Political Correctness'.........defined
President of Club Polk -
Here are some pictures
those do not look too bad, I've seen a lot worse. Clean them off with a wire brush.
That was one of the better ones. There are some that are far worse
I see them on amazon but they seem to be in metric sizes. You will need to measure the ones you have with whatever means you have. A dial caliper would be ideal.
https://www.amazon.com/Hexagon-Socket-Tapping-Stainless-Speaker(100/dp/B09M9WR756?th=1
^Good luck telling that China seller exactly what diameter you want. Seems to be no way I can see lol.
Parts Express has some sizes:
https://www.parts-express.com/search?keywords=cap head wood screwsGeorge / NJ
Onkyo A-8017 integrated
iFi nano iDSD DAC
iPurifier3
iDefender w/ iPower PS
Those are self tapping socket cap screws. No idea what size you have, so you'll have measure one. Likely a metric size.
Here are some examples.
https://www.rtlfasteners.com/RC/mm.htmlPolitical Correctness'.........defined
Thank you for the link
This one has ability to specify exact size you want to order:
https://www.amazon.com/dp/B0CR8M4TBV/ref=sspa_dk_detail_0
M4 x 20 would be my "guess"George / NJ
iFi nano iDSD DAC
iPurifier3
The whole screw is an inch long and takes a 3mm allen wrench.
One inch is 25mm. You need the measurement of the threaded area not including the head, so I'm guessing the threaded area is 20mm (3/4") long.
Metric screw diameters are noted as M4, M6, M8, etc. Chances are yours are M4 or M6.Political Correctness'.........defined
Take it your local hardware store.
Yeah I've gone to 3 hardware stores with no luck
I'd take them to the wire wheel, poke them through a piece of cardboard, dust a little black paint on the heads and call it a day.
Do you have advice on where to buy black paint?- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
--Gary--
Naval jelly will remove the rust.
https://www.homedepot.com/p/reviews/Loctite-Naval-Jelly-16-fl-oz-Rust-Dissolver-553472/203009241/1
SDA SRS 2.3TL's
SDA 2B TL's -
My advice to up your game is to have a baby and that way you don't sleep... Ever
😅👀- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
If you're replacing all the screws, they don't necessarily need to be a socket head screw as long as the thread is the same, and the head has a good base..
michaeljhsda2 wrote: »Naval jelly will remove the rust.
Does it matter whose navel it comes from?
Askin' for a friend.
mhardy6647 wrote: »michaeljhsda2 wrote: »Naval jelly will remove the rust.
It's jelly from the Navy not from someone's navel.SDA SRS 2.3TL's
SDA 2B TL's -
That's not a local hardware store. George and I already posted links to places to buy the screws.Political Correctness'.........defined
He said his local hardware stores were useless. I posted an alternative that helped me a lot restoring 60s vintage equipment.
Trying to be helpful. That ok??Post edited by odcics2 on -
I was going to suggest Sherwin-Williams but decided I had better call to make sure they had it in stock. I called and asked if they had black paint that would be good to use to paint the heads of screws. They told me the only way they could tell me for sure is if I could tell them the size of the screws. Go figure...Do you have advice on where to buy black paint?Post edited by TennMan on- SDA 2BTL · Sonicaps · Mills resistors · RDO-198s · New gaskets · H-nuts · Erse inductors · BH5 · Dynamat
- Crossover upgrades by westmassguy
- Marantz 1504 AVR (front speaker pre-outs to Adcom 555)
- Adcom GFA-555 amp · Upgrades & speaker protection added by OldmanSRS
- Pioneer DV-610AV DVD/CD player
- SDA CRS+ · Hidden away in the closet
Yes, this, and dry them with Bellybutton Lint.michaeljhsda2 wrote: »Naval jelly will remove the rust.
Yeah, I agree, even if they're rustier. As long as it's just surface rust and not full-on corroded, cleaning them and then coating with 3-in-1, chain & cable lube, or maybe even 2WD.
To me, that would be more enjoyable and less hassle than trying to find fasteners. Not to mention, keeps them original.
Timely note about Naval Jelly @michaeljhsda2 - I've got another project that I'm curious to try that on now. I think I once tried it years ago, though, and it didn't do anything for rust.
PS - I always read your name as MichaelJihad2. I'm sure MichaelJihad1 was taken.
