Assembling a pair of Legends
«13
    xschop Posts: 5,166
    edited April 2024
    Hey John, when you send the L800 plates, I'll need these dimensions to make a matching set of plates for those L600's....
    Looking at pics, the L800 plates are alum. alloy...
    heiney9 Posts: 25,432
    You assembled the cabinets? There's no context to your post. What's happening? What's the plan? Where are the drivers?
  • gyosa
    gyosa Posts: 770
    heiney9 wrote: »
    Kinda what I was thinking …. What’s going on here …
    Interesting, nonetheless….
    Bk
    PS Audio S300 , WiiM Ultra , Yamaha wxc-50 , Salk SuperCharged Songtowers , Kimber Kable 4TC, Sony 48” - BEDROOM
    B&K EX-442 ( it will go in my casket when I die ... ) , PS Audio 4.6 preamp ( old school , but it still jams on ... ) , Eversolo DMP-A6 , Boston Acoustic voyager 7’s - POOL
    Parasound A21, Eversolo DMP-A8 , Kimber Kable 4vs , Ascend Acoustics ELX Ribbon Towers , Sony XBR-A8F 65” OLED - DEN , MAIN system
    Onkyo TX-nr609 , Polk atrium 7 , Boston acoustic sound ware (4) , Boston acoustic sub , B&W center , Sony 65” TV - PATIO
    msg Posts: 10,452
    John got a job at Polk. These photos are from training.
    Toolfan66 Posts: 18,056
    Installing Phase Plugs, and foaming the baskets?? B)
    nooshinjohn Posts: 25,922
    edited April 2024
    Pictured are the crossover components of the L 600 prior to installation. The component on the left is the ATMOS module plug-in. In the center is the main crossover which feeds the tweeter in mid range of drivers, and to the right is the base module for controlling the woofers.
    More detailed shots of the crossover…
    What I am most impressed with is the quality of the PCB board. It’s pretty thick and the traces on this board are very very wide, nothing thin or cheap about it.
    edited April 2024
    More images of the wires being installed in the cabinets to their locations. The first image is of the Atmos cable and its enclosure.4cqdadl5h7ji.jpg
    The crossover installed in the back of the cabinet. The crossover is screwed directly to the cabinet, so there’s no chance of rattling or being knocked around. Once the installation is completed, there is a fiberfill matting that will go in front of the crossover.
    Polk was not kind enough to pre-drill the holes and counter-sinks in place for the bass-modules in one of the cabinets, so I am left to figure out how to get a drill inside to create a mounting spot for one of them. There is so much bracing inside that it makes for tight quarters in there. Also, the MDF these are constructed with is incredibly dense. I will just take my time on this and not rush. Rome was not built in a day, and getting these going won't happen in a day either...
    Post edited by nooshinjohn on
    edited April 2024
    xschop wrote: »
    Thanks... The measurements to the centers of each binding post are accurate on the L800 plate. The difference being that the plates are wider by 1/2 inch to either side of the plate's centerline.
    edited April 2024
    All of the wiring is in place just waiting for the drivers to show up at this time. I will post more when I get them.t3nodns9q81g.jpg
    ...And yes, one of my pilot holes went too deep due to being distracted by my two-year old while running the Dremel... pisses me off, but at least it's on the back. I will be able to get a decent blend to fill it and it will be hardly noticed after that.
    msg Posts: 10,452
    Wow what a project. Pretty cool. Where does something like this fall percentage-wise compared to buying a pair outright?
    VR3 Posts: 29,427
    Back when definitive was bought by sound united they sold diy kits from the parts warehouse on ebay... Super fun at great prices
    I know buying parts from Polk msrp is super expensive
    VR3 wrote: »
    I think this is kind of fun actually… there is a bit of pride of knowing you put them together, and a better understanding of how they work.
    VR3 Posts: 29,427
    Absolutely, I really enjoyed the definitive kits... I'm not sure why manufactures don't offer more products like a kit
    msg Posts: 10,452
    Returns and poor reviews after weak assembly practices? Maybe I'm losing faith in people.
    Ok, I thought maybe that's what was going on. I know you were pricing all the components and I appreciate the PM on the cost of replacement x-overs.
    I decided at this time buying an extra set of L600 crossover to repopulate with upgraded parts will be too expensive at this time. Too bad I can't get a couple of blank pcb's. I am afraid of botching the originals, so I'd rather work on a 2nd pair. $238 per cross over.
    Yes, document away B)
    P.s. I just heard from a dealer that the Legend line is being discontinued. I hope parts are available for a while.
    heiney9 wrote: »
    I have wondered about this for a while now, and I would love to have a set of L200's..
  • Emlyn
    Emlyn Posts: 4,705
    Polk website says the L200s are now only available "in store" rather than direct. It appears Masimo is handling the wind down of this line better than Sound United did with the LSiM line.
    edited April 2024
    heiney9 wrote: »
    I have my doubts on the parts. Trim rings are no longer available and were never stocked to begin with. Binding plates/posts are also not available. That is why I am trying like hell to get as many spares as I can, especially as Masimo is looking to dump the CA division once again. LSIM parts dried up quickly the last time Polk changed hands, and they were not able to fill warranty needs a year after they stopped making them. It might happen that way again, and I have too much tied up in the Legend series to be schitt outta luck.
    Even tho I have never had any issues with my LSiM speakers, if they do the same thing with the Reserve/Legend lines, I would probably be done purchasing any more Polk Audio Products..
    msg Posts: 10,452
    Yeah, mixed feelings on the parts availability, and I don't wanna jinx myself by making any statements, but...
    How many times have responsible owners experienced component failure from general, or even spirited use, vs. damage from abuse or party accidents/cats/kids?
    I've read here that the LSiM tweeters were failing. I wonder if that was across the entire production run, or just toward the end. I remember seeing that the binding posts were different on some of the later produced speakers.
  • JCL
    JCL Posts: 169
    Are the tweeters in the legends a different model than those in the reserve series and are all of the drivers different versions also?
    L600 (front), R200 (rear), R200 (rear surround), L400 (center), Sunfire HRS-10 (2)Marantz AV7706Sunfire Cinema Grand, Marantz M8077, Music Hall Stealth, Ortofon bronze cartridge, Parasound Zphono XRM, Sony UBP-X800
    JCL wrote: »
    The tweeters and mids are supposedly the same part.
  • Emlyn
    Emlyn Posts: 4,705
    Not sure if this has been posted before but I just noticed it. An FAQ from Polk on how to properly remove a Legend tweeter if someone wants to look around inside and compare to a Reserve tweeter:
    https://support.polkaudio.com/app/answers/detail/a_id/7215/~/polk-legend-series-tweeter-removal
    edited April 2024
    JCL wrote: »
    I had heard like John, same parts (as well as the mid driver), different x-over and in the early Legend line a different bass port. I thought I had read recently that the later Legends had the same style/function port as the Reserve series.
    It does do the brand a huge disservice to discontinue parts as soon as the line is discontinued. One of Polks long standing character was parts availability long after a line was discontinued.
    Sorry, for taking this of topic. I'll start a new thread so we don't muck this one up any more. It should stay on topic since it's of interest to many people.
    New thread for Legend discontinuation
    https://forum.polkaudio.com/discussion/200177/legend-line-being-discontinued/p1?new=1
    msg Posts: 10,452
    JCL wrote: »
    They're not even the same size, John. One is for tweeter holes.
    mhardy6647 Posts: 35,013
    msg wrote: »
    JCL wrote: »
    Oh. It's humor. Hahahahaha...
    The bezels for the tweets are different, the actual parts of the tweeter are the same, IIRC.
