XS-Dreadnaught
124»
    pitdogg2 Posts: 27,123
    edited March 2024
    The blade on pin/blade only comes into play on non-common ground amps to connect a ground through the negative binding post path. For the dreadnought you should use it like it does pass signal.
    No they do not pass SDA signal like to Blade/blade cable.
    xschop Posts: 5,221
    edited March 2024
    That would be the same as strapping the grounds on a non-common ground amp, No?
    xschop Posts: 5,221
    edited March 2024
    I'm asking these questions because I have an aftermarket 14 Ft Neutrik cable with both connectors live (+and-). I will cut in half and make 2ea 7 footers. Was not clear if I only need to use just one of the Neutrik's wire circuit connected to the pins of the X-overs, whether using the Dreadnaught or not.
    Thanks for you guys' input.
    xschop Posts: 5,221
    Ordered the Super-Q 15mH inductors as I found a thread or two where others did the same. Besides, my SDA's are Power-Ported :)
    xschop Posts: 5,221
    One done. Hopefully the SBD inductors show up before the weekend and I'll drop these in the XS-8TLs, and set them sideways...
    xschop Posts: 5,221
    edited March 2024
    XS-8TL's, soon to be SDA-XS-8TL's.
    These MW's have every mod done to them, including focus rings. I have a set of 6502's with phase plugs and focus rings to go in the SDA slots....
    msg Posts: 10,452
    Interesting project. Which driver will be the SDA? Will this reduce output?
    xschop Posts: 5,221
    edited March 2024
    msg wrote: »
    6502's for the SDA's will increase midrange clarity over the 6511's (BTDT). The 6516's are also better sounding that 6510's in stereo slots (also tested this myself). These won't need any help in the bass dept; especially with the Super Q's and no PR to drive. The soundstage width is big like that of the CRS+ due to MW driver spacing, minus the often experienced tweeter strangeness because the tweeter is much closer to the stereo driver. I had these hooked up a couple of summers ago at the shop on old CRS+ crossovers (think I sent them to VSAT afterwards), brought them home, did more mods and wiring upgrades to the factory 8TL crossovers. Now it's time to see what they can do on the dreadnaught with all the upgrades.
  • Gardenstater
    Gardenstater Posts: 4,785
    But how will you use the ball bearing isolators now? 😆 Looking forward to hearing your observations.
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
    Toolfan66 Posts: 18,108
    Cap the port, cut out holes on the sides and install PR’s.. 🤣
    xschop Posts: 5,221
    edited March 2024
    The CRS+'s need their PR's side-mounted. ;)
    Better yet, Power-Port your CRS's B)
    https://forum.polkaudio.com/discussion/184722/rta8-tl-mod/p2
    xschop Posts: 5,221
    edited March 2024
    VR3 wrote: »
    They do and they don't.
    The way the speakers work the signal is connected thru the negative speaker terminals, hence the requirements for a common ground amplifier
    Connecting the blade to ground is redundant but I still prefer to use it
    This actually was very helpful as I was able to add the Sub Bass Drive Inductor leads directly to the Neutrik terminals.
    VR3 Posts: 29,457
    That's what I do, makes it much cleaner on the crossover side
    xschop Posts: 5,221
    edited March 2024
    It also jogged my memory when I was experimenting on those ragged-out CRS years back. IIRC, removing the SBDI rendered the SDA driver inoperable, with NO SDA and diminished bass output. Adding a jumper brought back the SDA, but still diminished bass. All the magic happens (Bass output and SDA) with the SBDI installed, because of the shared cab volume of the MW drivers.
    ...And the new SBDI's showed up just in time to wait for another weekend to run them....
    xschop Posts: 5,221
    edited April 2024
    Was doing some cleaning and light touch up painting in the house and decided to try mineral spirits to remove the ball-bearing isolators. Luckily it does not damage the vinyl veneer. Takes a couple doses and the glue will rub right off...
    I thought about adding them under the amp and Dreadnaught, but wouldn't be able to turn the volume knob lol.
    One thing's for sure, these are not going back to the 8TL configuration. The immense soundstage, imaging and clarity on all my classic jazz recordings renders the factory MTM configuration obsolete...
    Here's a shot of the SBDI location...
    xschop Posts: 5,221
    edited April 2024
    Thanks to @Conradicles generous karma I'll be setting up a DAC next weekend and won't need to use my phone's DAC. My wife streamed HD amazon music the last couple weeks, but I can tell going thru the Fire tablet, it does not have quite the resolution the LG phone Quad-DAC does.
    As an aside, I wouldn't hesitate to run a set of 2Bs with this amp and Dreadnaught combo using a 42V 8 amp power supply. I still have the 36V 6 amp power supply on these and it does not even break a sweat at LOUD levels.
    Got a little more painting to do today and some tunes to enjoy on these.
    More importantly, a BIG thank you goes out to @DarqueKnight for developing this design. Class D and SDA is a beautifully detailed marriage.
    I have the tweeters distanced 64" apart on their centers. This seems to reproduce the best SDA for all recordings, old and newer.
    I'll have to machine 1/2" length stand-offs for the crossover mountings. The 3/4" lengths didn't provide enough bite for the 10-32 hurricane nuts...
    Post edited by xschop on
  • VSAT88
    VSAT88 Posts: 1,298
    Looks just the way I like it @XSChop
    xschop Posts: 5,221
    Thanks Vsat. I'm working on another one. The Silver Dragon's are sounding splendid. B)
  • VSAT88
    VSAT88 Posts: 1,298
    How could they not? Not surprised to see you using those at all. That coating on the outside is super looking. Bet it cuts RF interference to nil. I am really wanting that other case you built for the Dreadnaught... Mine has a small crack. Plastic ****.
    xschop Posts: 5,221
    I'll be keeping my dreadnaught for a summer project. 8TL's standing, I bolted the CRS+ X-overs back up with all 6502's in the slots and a 6502 set taped to the sides (looked like ****) but I'll be building a fresh set of cabs for this configuration. Only unknown is if I'll wind up using the 8TL's tweeter network, or keep the CRS+ network as is.
    xschop Posts: 5,221
    edited February 6
    You guys think the SDA soudstage width would be less if I moved the SDA driver closer to the MTM vertcal centerline?
    I could get a 14" width baffle this way and make them taller for tweeter height.
  • skipshot12
    skipshot12 Posts: 2,019
    Would doubt that would effect the sounstage as much as positioning.
    My thoughts would be so small as not to be noticed.
    xschop Posts: 5,221
    edited February 6
    I can live without the wider CRS+ soundstage but don't want less than a set of 2 B's or the 10B-SDA's.
    A sleeker set of SDA towers with MTM imaging and 2B soundstage would be endgame for now.
    Old School SDA...
    New School....
    xschop Posts: 5,221
    If I make the RDO tweeter plate circular, I can squeeze the SDA driver closer to centerline. All the old POLK white papers say that the MWs were placed a "head's width" apart for the IACC to work. By default they could only get them 6.630" center to center. My ear canals are 5.7" C2C and I"m a big guy. Must have been some Neanderthals at Gallagher Mansion.
    XS-3B's?
    VR3 Posts: 29,457
    edited February 6
    Interesting experiment would be to create an angled baffle 15 degrees like the new sda and that would also help with diffraction issues with such a wide flat baffle
    Ie stereo drivers on a straight flat baffle then the sda driver on the 15 degrees portion
