what guage wire will amplifier accept in the hole in its binding post
I am planning to bi wire my stereo 2 channel system with 12 gauge wire bare connection. So effectively on the amp side it would mean two 12 gauge wires in a single binding post . Will the hole in the binding post be able to accommodate such a thick wire with bare connections ? I am using a Harman Kardon 3380 stereo receiver
Regards
Gitesh
Best Answers
    treitz3 Posts: 20,360
    Answer ✓
    Your best bet (and safest for your gear) would be to get a banana clip and crimp or solder the wires into the banana clip, then insert the banana clip into the post.
    Alternatively, you could use a spade if the binding posts are not compatible with banana.
    Just get some shrink wrap and ensure that the clip is big enough to accommodate both incoming wires.
    F1nut Posts: 52,406
    Answer ✓
    gitesh wrote: »
    Regards
    Gitesh
    Run one pair of speaker cables to the binding posts labeled speaker 1 and another pair of speaker cables to the binding posts labeled speaker 2. Turn on speaker 1 and 2 in the receiver.
    BTW, it's banana plug not clip. Banana clips are used by women in their hair.
  • SeleniumFalcon
    SeleniumFalcon Posts: 4,386
    Answer ✓
    It will not effect the amplifier in any way, it doesn't change the speaker's load at all. If you were connecting two pairs of speakers, one pair connected to speaker A and a second pair to speaker B, and ran them together the load would be changed. But, using this connection for a bi-wiring approach doesn't change the load.
Answers
    Listen here, Mister....
    Before my morning coffee? It's a clip.
    After my morning coffee? Plug all day long.
    Whoever invented early morning should be shot! That's all I have to say about that.
    Clipdat Posts: 13,104
    Dirty rated R thread title. Naughty!
    audioluvr Posts: 6,079
    gitesh wrote: »
    Regards
    Gitesh
    Kinda like two roosters in one hole. Awkward at best.
    F1nut Posts: 52,406
    LMAO
  • Geoff4rfc
    Geoff4rfc Posts: 3,053
    audioluvr wrote: »
    gitesh wrote: »
    Regards
    Gitesh
    Marantz AV10-Emotiva ERC3-Denafrips Venus-Panasonic UB820-AudioQuest Power Quest 707-Emotiva DR3, DR2, XPA2, XPA6-Focal Kanta No2, Sopra Center-PolkAudio RTiA9, RTiA3, LSiM 702F/X-Epik Empire-SVS SB5000-11.3
  • gitesh
    gitesh Posts: 4
    @ F1nut. That’s quite insightful. Currently , I have connected my two speaker to speaker 1 - left and right outlets .
    While bi wiring . Just to clarify .
    I will connect speaker 1 right channel and speaker 2 right channel in the hk 3380 receiver to the upper and lower (4 binding post) in my right speaker .
    Similarly I will connect the speaker 1
    and 2 left channels in hk 3380 to the left speaker
    F1nut Posts: 52,406
    Like this.
  • gitesh
    gitesh Posts: 4
    Ok got it . But will running from both 1 + 2 speakers simultaneously affect the amp and / or speakers adversely ? The amp is HK 3380 80 W per channel driven into both channels at 8 ohm and 100 watt per channel driven into both channels at 4 ohm . The speakers have nominal impedance of 8 ohm and minimum 4 ohm .
    F1nut Posts: 52,406
    You are driving one pair of speakers not 2 completely different pairs of speakers, so no problem.
