what guage wire will amplifier accept in the hole in its binding post
gitesh
I am planning to bi wire my stereo 2 channel system with 12 gauge wire bare connection. So effectively on the amp side it would mean two 12 gauge wires in a single binding post . Will the hole in the binding post be able to accommodate such a thick wire with bare connections ? I am using a Harman Kardon 3380 stereo receiver
Regards
Gitesh
Best Answers
Your best bet (and safest for your gear) would be to get a banana clip and crimp or solder the wires into the banana clip, then insert the banana clip into the post.
Alternatively, you could use a spade if the binding posts are not compatible with banana.
Just get some shrink wrap and ensure that the clip is big enough to accommodate both incoming wires.
Regards
Gitesh
Run one pair of speaker cables to the binding posts labeled speaker 1 and another pair of speaker cables to the binding posts labeled speaker 2. Turn on speaker 1 and 2 in the receiver.
BTW, it's banana plug not clip. Banana clips are used by women in their hair.Political Correctness'.........defined
President of Club Polk -
It will not effect the amplifier in any way, it doesn't change the speaker's load at all. If you were connecting two pairs of speakers, one pair connected to speaker A and a second pair to speaker B, and ran them together the load would be changed. But, using this connection for a bi-wiring approach doesn't change the load.
Answers
Listen here, Mister....
Before my morning coffee? It's a clip.
After my morning coffee? Plug all day long.
Whoever invented early morning should be shot! That's all I have to say about that.
Dirty rated R thread title. Naughty!
Regards
Gitesh
Kinda like two roosters in one hole. Awkward at best.Gustard X26 Pro DAC
LMAOPolitical Correctness'.........defined
Regards
Gitesh
Marantz AV10-Emotiva ERC3-Denafrips Venus-Panasonic UB9000-AudioQuest Power Quest 707-Emotiva DR3, DR2, XPA2, XPA6-Focal Kanta No2, Sopra Center-PolkAudio RTiA9, RTiA3, LSiM 702F/X-Epik Empire-11.2 -
@ F1nut. That’s quite insightful. Currently , I have connected my two speaker to speaker 1 - left and right outlets .
While bi wiring . Just to clarify .
I will connect speaker 1 right channel and speaker 2 right channel in the hk 3380 receiver to the upper and lower (4 binding post) in my right speaker .
Similarly I will connect the speaker 1
and 2 left channels in hk 3380 to the left speaker -
Like this.
Ok got it . But will running from both 1 + 2 speakers simultaneously affect the amp and / or speakers adversely ? The amp is HK 3380 80 W per channel driven into both channels at 8 ohm and 100 watt per channel driven into both channels at 4 ohm . The speakers have nominal impedance of 8 ohm and minimum 4 ohm .
You are driving one pair of speakers not 2 completely different pairs of speakers, so no problem.Political Correctness'.........defined
