XS-Dreadnaught
0.005 finish pass...
Don't take experimental gene therapies from known eugenicists. -
Lid time with a hand tap. Not chancing a machine tap on this guy...
You have been busy!!!
Been at the shop all day. Test fitted the top and placed my cell phone in it and gave it a ring a couple times... Not a peep
Will take it home and assemble, then decide how I want to mount the Neutriks.Don't take experimental gene therapies from known eugenicists. -
Beautiful!
The suspense is starting to get to me!
How soft is that material, anyway? I was wondering about the section you're tapping, and whether there's potential for thread damage from the bolt?
I gather that the thread pitch is coarse enough and the material strong enough that it won't be an issue? Not to mention won't really see frequent disassembly.
I guess I'm just looking for a reason for you to put in a Timesert just for added industriality
Will it be polished in the end? @[Deleted User] is good at polishing metal. Real meticulous. Word is he's acid burned his fingerprints off. Can't grip anything anymore, but all his shiny metal things are pristine.
I disabled signatures. -
Side question - bolt vs screw. What're you using here, and what defines each?
Readyyy, GO!
Nowadays a bolt costs less than 10 bucks. At over 20 bucks you're getting a "screw".Don't take experimental gene therapies from known eugenicists.
Readyyy, GO!
Screws tend to be sharp, pointy, and without lubrication. That's why people bolt for the Cayman's when the IRS comes knocking.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
Headed to the Ponderosa...
SAE or Metric?
Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
Beautiful!
Assembles or Disassembles in less than 5 minutes with a single 3/16 hex wrench.
The Neutriks I got are not full bodied like I remember, but same diameter, so wouldn't chuck up on lathe. I'll have to grind off square tabs and glue in with my favorite alloy adhesive.
Why not counter-sink them in the side and offset them at 10 and 2?The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
What size tires fit on that rim?
nooshinjohn wrote: »
No exposed hardware/fasteners was a goal.Don't take experimental gene therapies from known eugenicists. -
Going to be pretty cool, and heavy as hell..
When I ship one, it'll fit in a large flat rate Priority box. Can't wait till they ask me what's in the box.
Tell the shipper that you have no clue what it is, but you knew a guy that worked at Los Alamos until all his hair started falling out and his fingernails glowed in the dark... and you got this from him!
Man, it's kind of a shame it's covered up with that spider locked away - that's a sweet piece of the build! I'd want to have a way to showcase that. I like that beefy, edgy, industrial look, and the transformer behind the spider makes for an interesting combination. Hard to characterize - it's almost like Steampunk Nouveau.Headed to the Ponderosa...
Is this designed to be oriented vertically? Or on its side with a couple of, cough, arc-matched cradles? Buell did something similar with their underslung exhaust brackets. Could be a version of the Dreadnought case brackets Brian made for Larry a long time ago, only maybe splayed outward to boldly constrain against rolling.
How To Win Friends And Get Helicoptered To Cuba, 2nd Ed., by Ivan P. Now with bonus appendices, including, How To Enjoy Being Waterboarded, and How To Toughen Your Feet For Getting Midnight Run'd.I disabled signatures. -
It sets flat and ain't topplin' nowheres.Don't take experimental gene therapies from known eugenicists. -
You could have the connectors come from the bottom and make a super cool spiked base to put it onThe Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
360÷5= 72 degress between adjacent spokes, is where they'll
mount.Don't take experimental gene therapies from known eugenicists. -
Ok @msg, back on it today... 29/32" is perfect for a Neutrik slip-fit...
Took another .080" off lock-down spoke so the lid bottom clears without touching...
Went back and put a 1/64" chamfer on the lid. Next will grind off Neutrik square tabs and install with soldered fast-ons....
Beautiful.
Are you thinking about making these? Definitely looks like a lot of time.I disabled signatures. -
Thanks. I have enough materials to build an identical one. May be awhile before I can do another. Very time consuming.Don't take experimental gene therapies from known eugenicists.
Working on the XS-Dreadnaught's companion boards. Will mount externally to the XS-8TL's when done....
Measuring the Neutriks depth, Ill have to machine 1" dia alloys that are 0.75" long so the wiring will clear....
