XS-Dreadnaught
245
    xschop Posts: 5,499
    Thank you! If you could measure from the blue/violet pair to the grey/brown pair of wires. And then from the black/orange pair to the red/yellow pair of wires.
    Had to find the alligator clips...
    xschop Posts: 5,499
    Made some thicker and wider 6.5" insulating pads. I'll have rubber side facing all metals...
  • Thank you, I appreciate the effort.
    xschop Posts: 5,499
    Gonna make a DIY torroidal?
    Inquiring minds want to know.😎
    xschop Posts: 5,499
    Back on it...
    xschop Posts: 5,499
    0.005 finish pass...
    xschop Posts: 5,499
    xschop Posts: 5,499
    edited February 2024
    Post edited by xschop on
    Toolfan66 Posts: 18,242
    You have been busy!!!
    xschop Posts: 5,499
    Lid time with a hand tap. Not chancing a machine tap on this guy...
    xschop Posts: 5,499
    Toolfan66 wrote: »
    Been at the shop all day. Test fitted the top and placed my cell phone in it and gave it a ring a couple times... Not a peep B)
    Will take it home and assemble, then decide how I want to mount the Neutriks.
    msg Posts: 10,501
    Beautiful!
    The suspense is starting to get to me!
    How soft is that material, anyway? I was wondering about the section you're tapping, and whether there's potential for thread damage from the bolt?
    I gather that the thread pitch is coarse enough and the material strong enough that it won't be an issue? Not to mention won't really see frequent disassembly.
    I guess I'm just looking for a reason for you to put in a Timesert just for added industriality :DB)
    Will it be polished in the end? @bcwsrt is good at polishing metal. Real meticulous. Word is he's acid burned his fingerprints off. Can't grip anything anymore, but all his shiny metal things are pristine.
    msg Posts: 10,501
    Side question - bolt vs screw. What're you using here, and what defines each?
    Readyyy, GO!
    xschop Posts: 5,499
    Nowadays a bolt costs less than 10 bucks. At over 20 bucks you're getting a "screw".
    nooshinjohn Posts: 26,023
    msg wrote: »
    Readyyy, GO!
    Screws tend to be sharp, pointy, and without lubrication. That's why people bolt for the Cayman's when the IRS comes knocking.
    xschop Posts: 5,499
    Headed to the Ponderosa...
    SCompRacer Posts: 9,130
    SAE or Metric? :D
    xschop Posts: 5,499
    msg wrote: »
    Beautiful!
    Assembles or Disassembles in less than 5 minutes with a single 3/16 hex wrench.
    The Neutriks I got are not full bodied like I remember, but same diameter, so wouldn't chuck up on lathe. I'll have to grind off square tabs and glue in with my favorite alloy adhesive.
    xschop wrote: »
    Why not counter-sink them in the side and offset them at 10 and 2?
    Viking64 Posts: 7,658
    What size tires fit on that rim?
    xschop Posts: 5,499
    xschop wrote: »
    No exposed hardware/fasteners was a goal.
    Going to be pretty cool, and heavy as hell..
    xschop Posts: 5,499
    Toolfan66 wrote: »
    When I ship one, it'll fit in a large flat rate Priority box. Can't wait till they ask me what's in the box. B)
    pitdogg2 Posts: 27,448
    xschop wrote: »
    Toolfan66 wrote: »
    Bomb parts...... they love that comment....
    xschop wrote: »
    Toolfan66 wrote: »
    Tell the shipper that you have no clue what it is, but you knew a guy that worked at Los Alamos until all his hair started falling out and his fingernails glowed in the dark... and you got this from him! >:)
    msg Posts: 10,501
    xschop wrote: »
    Man, it's kind of a shame it's covered up with that spider locked away - that's a sweet piece of the build! I'd want to have a way to showcase that. I like that beefy, edgy, industrial look, and the transformer behind the spider makes for an interesting combination. Hard to characterize - it's almost like Steampunk Nouveau.
    Is this designed to be oriented vertically? Or on its side with a couple of, cough, arc-matched cradles? Buell did something similar with their underslung exhaust brackets. Could be a version of the Dreadnought case brackets Brian made for Larry a long time ago, only maybe splayed outward to boldly constrain against rolling.
    msg Posts: 10,501
    xschop wrote: »
    Toolfan66 wrote: »
    How To Win Friends And Get Helicoptered To Cuba, 2nd Ed., by Ivan P. Now with bonus appendices, including, How To Enjoy Being Waterboarded, and How To Toughen Your Feet For Getting Midnight Run'd.
    xschop Posts: 5,499
    msg wrote: »
    xschop wrote: »
    It sets flat and ain't topplin' nowheres.
    You could have the connectors come from the bottom and make a super cool spiked base to put it on
    xschop Posts: 5,499
    360÷5= 72 degress between adjacent spokes, is where they'll
    mount.
