XS-Dreadnaught
    xschop Posts: 5,812
    Thank you! If you could measure from the blue/violet pair to the grey/brown pair of wires. And then from the black/orange pair to the red/yellow pair of wires.
    Had to find the alligator clips...
    xschop Posts: 5,812
    Made some thicker and wider 6.5" insulating pads. I'll have rubber side facing all metals...
  • SeleniumFalcon
    Thank you, I appreciate the effort.
    xschop Posts: 5,812
    Gonna make a DIY torroidal?
    Inquiring minds want to know.😎
    xschop Posts: 5,812
    Back on it...
    xschop Posts: 5,812
    0.005 finish pass...
    xschop Posts: 5,812
    xschop Posts: 5,812
    edited February 2024
    xschop Posts: 5,812
    Lid time with a hand tap. Not chancing a machine tap on this guy...
    xschop Posts: 5,812
    Toolfan66 wrote: »
    You have been busy!!!
    Been at the shop all day. Test fitted the top and placed my cell phone in it and gave it a ring a couple times... Not a peep B)
    Will take it home and assemble, then decide how I want to mount the Neutriks.
    msg Posts: 10,646
    Beautiful!
    The suspense is starting to get to me!
    How soft is that material, anyway? I was wondering about the section you're tapping, and whether there's potential for thread damage from the bolt?
    I gather that the thread pitch is coarse enough and the material strong enough that it won't be an issue? Not to mention won't really see frequent disassembly.
    I guess I'm just looking for a reason for you to put in a Timesert just for added industriality :DB)
    Will it be polished in the end? @bcwsrt is good at polishing metal. Real meticulous. Word is he's acid burned his fingerprints off. Can't grip anything anymore, but all his shiny metal things are pristine.
    msg Posts: 10,646
    Side question - bolt vs screw. What're you using here, and what defines each?
    Readyyy, GO!
    xschop Posts: 5,812
    Nowadays a bolt costs less than 10 bucks. At over 20 bucks you're getting a "screw".
    xschop Posts: 5,812
    Headed to the Ponderosa...
    SCompRacer Posts: 9,395
    SAE or Metric? :D
    xschop Posts: 5,812
    msg wrote: »
    Beautiful!
    Assembles or Disassembles in less than 5 minutes with a single 3/16 hex wrench.
    The Neutriks I got are not full bodied like I remember, but same diameter, so wouldn't chuck up on lathe. I'll have to grind off square tabs and glue in with my favorite alloy adhesive.
    Viking64 Posts: 7,810
    What size tires fit on that rim?
    xschop Posts: 5,812
    xschop wrote: »
    Why not counter-sink them in the side and offset them at 10 and 2?
    No exposed hardware/fasteners was a goal.
    xschop Posts: 5,812
    Toolfan66 wrote: »
    Going to be pretty cool, and heavy as hell..
    When I ship one, it'll fit in a large flat rate Priority box. Can't wait till they ask me what's in the box. B)
    msg Posts: 10,646
    xschop wrote: »
    Man, it's kind of a shame it's covered up with that spider locked away - that's a sweet piece of the build! I'd want to have a way to showcase that. I like that beefy, edgy, industrial look, and the transformer behind the spider makes for an interesting combination. Hard to characterize - it's almost like Steampunk Nouveau.
    Is this designed to be oriented vertically? Or on its side with a couple of, cough, arc-matched cradles? Buell did something similar with their underslung exhaust brackets. Could be a version of the Dreadnought case brackets Brian made for Larry a long time ago, only maybe splayed outward to boldly constrain against rolling.
    msg Posts: 10,646
    xschop wrote: »
    Toolfan66 wrote: »
    Bomb parts...... they love that comment....
    How To Win Friends And Get Helicoptered To Cuba, 2nd Ed., by Ivan P. Now with bonus appendices, including, How To Enjoy Being Waterboarded, and How To Toughen Your Feet For Getting Midnight Run'd.
    xschop Posts: 5,812
    msg wrote: »
    xschop wrote: »
    It sets flat and ain't topplin' nowheres.
    xschop Posts: 5,812
    360÷5= 72 degress between adjacent spokes, is where they'll
    mount.
