7C Beef Up help
  • inanortherntown
    inanortherntown Posts: 32
    edited February 2024
    xschop wrote: »
    Forum first right there. Great job.
    Thanks—I had some help, natch. Currently giving John Prine at the Other End a listen, and the acoustic-ness of the recording is really showing me I did the right thing. VR3 xover is next…can’t wait.
    xschop Posts: 5,932
    On your model, where is the rear terminal cup positioned in relation to the midwoofer?
  • inanortherntown
    Not sure I’m tracking. The rear terminal cup that holds the xover is where I’d expect it to be…lower end of the cabinet, about 10” diagonally from the midwoofer
  • odcics2
    odcics2 Posts: 396
    pic?
  • inanortherntown
    First one is the terminal cup. It’s. 7c speaker so I’d say it’s about just below the halfway point on the speaker.
    Viking64 Posts: 7,836
    If you're not going to eat that piece of pizza on the floor there, I wouldn't mind polishing it off before the dog comes inside.
  • inanortherntown
    Viking64 wrote: »
    Ha. That the corner of my rug runner thing. For when I obsessively pace back and forth before hacking into my speakers.
    xschop Posts: 5,932
    I was just curious if a dowel can be placed between the MW and PR extending straight to the back panel?
  • inanortherntown
    xschop wrote: »
    What diameter dowel? I need to pull things to put the xovers in when they arrive so I'd be willing to try?
    xschop Posts: 5,932
    3/4 to 7/8" wood dowel should be plenty strong.
  • inanortherntown
    Wow ok. So like just a single dowel running between the space between the MW and PR? Tried to take a pic. Have to cut it to size and lightly tap it into place?qrmp11sis3x1.jpeg
    xschop Posts: 5,932
    Exactly. You can use Liquid Nails or PowerGrab and let dry overnight. That and hurricane nut fasteners will be your best solution for cleaning up the mid-bass on those.
    F1nut Posts: 52,406
    No dowel needed.
    xschop Posts: 5,932
    No dowel needed.
    He asked for beef-up mods, not vegan soy-boy mods.
  • joebass3
    joebass3 Posts: 311
    xschop wrote: »
    xschop wrote: »
    Definitely consider this! I've done it on my Monitor 7's and 10's. Cheap and easy mod with very noticeable gains!
  • inanortherntown
    Yep hurricane nuts forthcoming
  • inanortherntown
    I did learn through my disassembly that my 7's have the same birth day (not year) as my wife, so that's something
  • inanortherntown
    Oh and check out what the fill in one of my speakers looked like. Cigar burn?
    VR3 Posts: 29,763
    Burnt resistor
  • Gardenstater
    I'd really be interested in your crossover if you could check the values and maybe post a picture or two. Also, what MW# (6502?). Late 7B and early 7C both had the SL1000 tweeter and both had recessed passive and not recessed MW. Maybe the only main difference was the MW was changed from MW6500 to MW6502 and crossover values.
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • inanortherntown
    Hi yes the MW are MW6502
    Here are the crossovers.
    xschop Posts: 5,932
    6502's are better drivers.
    pitdogg2 Posts: 27,921
    There is your dacron burner... that sucker got HOT!!! Looking at the discoloration on the board I'd say it's toast.
  • inanortherntown
    Yep. As luck would have it everythings getting swapped out
  • Gardenstater
    Gardenstater Posts: 4,991
    Did you or previous owner have a shorted out tweeter? That resistor still works?
    This is close to your schematic only you have the previous one (that we don't have) with the 2.7ohm resistor and fuse instead of polyswitch:
    https://us.v-cdn.net/5021930/uploads/attachments/4/6/7/2/8/18772.pdf
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • inanortherntown
    Previous owner did, although he didn't tell me. Both tweeters were warranty repairs it looks like. I saw that when I pull them to replace them.
  • inanortherntown
    Rehab complete. XOvers arrived and they’re beauts, Clark
    Hooked up everything
    Mounted the xovers
    Finally secured the drivers. That was kind of nerve wracking, and two of the hurricane nuts didn’t cooperate, but overall it was a 98% success, thanks entirely to you all.
    Already the soundstage is waaaay open and lower range is felt and really just experienced.
    Thanks again for all the input. Consider me a fan.
  • inanortherntown
    Oh and special shout out to Treynfor crafting a rainman-level awesome crossover set. Truly almost too pretty to put inside the cabinets.
    VR3 Posts: 29,763
    Thank you Anthony! Was a pleasure to work with you! Rock on!
    Clipdat Posts: 13,107
    Simply gorgeous crossovers, it's no wonder they have dramatically raised the performance level of the speakers. Enjoy!!
