Post a picture... any picture
1104810491051105310541098
    mhardy6647 Posts: 33,139
    edited February 19
    Trouble brewin'.
    Not to be confused with trouble bruin.
    Viking64 Posts: 6,721
    We had that puzzle!!!
  • BlueBirdMusic
    BlueBirdMusic Posts: 2,093
    Harry / Marietta GA
    msg Posts: 9,569
    This is one of those times that requires a "FTTT! FTTT!"
    The cat version of getting yelled at by your dad when he'd catch you doing something you knew you shouldn't be.
    treitz3 Posts: 18,457
    Is that a B&O speaker hung up on the wall?
    we miss our little hooligans, too -- most of the time, at any rate.
    Zappa (the one in the photo that's black and white grey on the average) did some hifi component damage in his time -- including popping a reel to reel tape as it played on myRT-909 in the living room. I had foolishly gone to another room... and, suddenly, there was silence. :#
    The other one, Timmy, came close.
    I think I've told the story here before. When I brought home my (beautiful) pair of Altec 604E Duplexes, acquired from a friend & hifi fellow traveler in southwestern Vermont, I put them in the basement to await the cabinets that were being built for them. Given that they're, in some respects, quite fragile, and relatively hard (and not inexpensive) to repair or to replace, I draped a couple of towels over the baskets with the goal of protecting the back side of the woofer cones.
    Later that same evening I had a bad feeling about their well being, so I went downstairs to check on them.
    Timmy had, apparently beat me to it.
    I think I found a couple of large boxes for them immediately after defusing the situation.
    You know the cat motto: If I fits, I sits. :|
  • Kex
    Kex Posts: 4,943
    Well you can’t be all bad then… cats know! 😜
    Alea jacta est!
  • soundfreak1
    soundfreak1 Posts: 3,389
    Ya if a cat will put up with your a$$ you ain't too bad.
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
  • SeleniumFalcon
    In my hometown, when I was a kid, there was a restaurant called Coney Island Lunch that served delicious hot dogs that the counter guy would line up on his arm. Everyone called them "sweats" and the choice one was the one he placed in the crook of his arm. The legend was that it absorbed the most amount of flavor.
  • soundfreak1
    That look exactly like the Conney Island in St.Pete,Fla. Especially the staff.
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
  • soundfreak1
    2 Chille dogs Burnt no onion please also van. Milkshake thank you.
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
  • SeleniumFalcon
    SeleniumFalcon Posts: 3,530
    edited February 20
    We would just ask for "the works" and a cherry (smash) coke, the slightly rancid chopped onions added to the total flavor. I've never seen onions chopped so fine, they were like confetti. The dogs were thin, skinny with a tough skin, my Aunt Ella knew somebody who worked there and they would sell her a dozen uncooked versions and she would bring them to picnics.
    Toolfan66 Posts: 16,964
    Now I'm hungry..
    edited February 20
    Ann's Dari-Creme in Glen Burnie, MD. Magnificent foot longs.
    My father reverse-engineered their chili, to excellent effect.
    meanwhile...
    Whaddya mean, you can't get the wheelbarrow?
    oh.
    I reverse-engineered some chili once.
    I'll leave the part about magnificent footlongs out of it as we are in the middle of family hour.
    msg Posts: 9,569
    oh.
    Is this If I fits, I sits?
    msg wrote: »
    oh.
    Yes, sir.
    If I fits, I sits. Extreme edition.
    B)
    pitdogg2 Posts: 24,652
    meanwhile...
    Just think if they tossed in a big gaylord cardboard box......them cats would be in heaven.
    F1nut Posts: 49,880
    Got that, go ahead I dare you look.
    Makes ya' wonder which meal he was eying...LOL
    treitz3 wrote: »
    Dinner and dessert! :)
    meanwhile -- didn't see this soon enough for this year, but here's a handy tip for next February 14.
    B)
    Which of those guys are you referring to? Or do you mean all 3? :o
    Mrs. H is birding.
    Dr. H is playing with SDR. :#
