Feel the hate thread
1181920212224»
    mhardy6647 Posts: 35,241
    I believe this was posted in the 'post a photo' thread at some point, but it seems apropos here, too.
    B)
  • ChrisD06
    ChrisD06 Posts: 929
    I hate painting a room and realizing I forgot to remove the lint from the roller, and now I have to individually pick the lint off of the wall which dried in (the stuff I didn't pick off while painting) before applying the second coat. And then I realized that I did 3 walls perfectly but the fourth was a little too thin.
    My gear:
    • TCL 75QM7K TV
    • Onyko TX-NR656 AVR
    • RT3000p Fronts
    • CS1000p Center
    • RT35 Side Surrounds
    • RT35 Rear Surrounds
    xschop Posts: 5,413
    I hate the search feature here.
  • I hate being told I must be a bot in my first posts here. But at least I'm not a post ****.
    Clipdat Posts: 13,100
    Good to know that you're still salty about that.
    xschop wrote: »
    It is miserable -- so I usually just use google to search this forum. :blush:
    treitz3 Posts: 20,121
    Yup. Me too. Much easier.
  • ChrisD06
    ChrisD06 Posts: 929
    ChrisD06 wrote: »
    Okay the second coat seems to have made the wall look essentially flawless though there are still minor imperfections.
    Ironically, it looks better than the paint job done by the contracted painters in '08 when they built the house. So I'll take that one with pride
    My gear:
    • TCL 75QM7K TV
    • RT3000p Fronts
    • CS1000p Center
  • ChrisD06
    ChrisD06 Posts: 929
    Now I hate uneven subfloor seams
    My gear:
    • TCL 75QM7K TV
    • RT3000p Fronts
    • CS1000p Center
    nooshinjohn Posts: 26,002
    LisaBen wrote: »
    Searching for snarky reply that will not get me banned.... nope, I got nuthin'.
    edited January 2024
    ChrisD06 wrote: »
    https://youtu.be/Be886Ezi30g?t=18
    Hammer time!
  • ChrisD06
    ChrisD06 Posts: 929
    treitz3 wrote: »
    ChrisD06 wrote: »
    Hammer time!
    Yeah I've been going to town but I think it's just swelling on the edges or the OSB so it should be a quick and easy fix. Thankfully it doesn't look like I'll need underlayment.
    My gear:
    • TCL 75QM7K TV
    • RT3000p Fronts
    • CS1000p Center
  • invalid
    invalid Posts: 1,529
    ChrisD06 wrote: »
    treitz3 wrote: »
    ChrisD06 wrote: »
    Hammer time!
    I would use underlayment if I were doing that job, it's not that expensive and it will be a better job.
  • ChrisD06
    ChrisD06 Posts: 929
    invalid wrote: »
    ChrisD06 wrote: »
    treitz3 wrote: »
    ChrisD06 wrote: »
    Hammer time!
    I was going to but I managed to flatten it in about an hour with a sander, some screws, and sinking the protruding nails. Half the floor is installed and it's perfectly flat. Starting on the other half very soon.
    My gear:
    • TCL 75QM7K TV
    • RT3000p Fronts
    • CS1000p Center
  • soundfreak1
    soundfreak1 Posts: 3,414
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
    xschop Posts: 5,413
    xschop wrote: »
    I also hate the auto-correct here too. I think it taunts you.
  • bcwsrt
    bcwsrt Posts: 2,513
    It was you, wasn’t it?
    Brian
    msg Posts: 10,472
    NOOOO! :D
    pitdogg2 Posts: 27,333
    Thank god they weren't wrong time bass port exhaust expellers
  • aprazer402
    aprazer402 Posts: 3,407
    msg wrote: »
    They called this guy into the boss's office afterward and Schiit-canned him for it.
    I was not aware you worked there. Can you get us a discount?
