Schiit Tyr monoblocks common ground according to Schiit, anyone running these on the bigger SDA’s?
Answers
  • crcolby
    crcolby Posts: 18
    I use two Schiit Vidars for my 1C’s. I emailed customer service to ask if I could make them common ground by running a wire from one to the other. I got back a response from Jason saying it was a bad idea. “Like BOOM! “ That’s how he put it. So I got a 625 VA A-G transformer and is connected the two speakers through it.
    audioluvr Posts: 5,982
    Correct. Running stereo amps in mono can not be made common ground. Using a dreadnought is the only way that will work going into SDA's
    F1nut Posts: 51,918
    edited January 2024
    crcolby wrote: »
    You should get the tried and true Avel model Y236906 800 VA transformer.
