Schiit Tyr monoblocks common ground according to Schiit, anyone running these on the bigger SDA’s?
Thinking about purchasing a pair of these Schiit Tyr’s. Emailed Schiit to see if they were common ground and according to them they are. Was wondering if anyone else was running these in their current system on 1.2’s, 2.3’s, 3.1’s. I myself have a pair of 2.3 TL‘s.
Answers
    xschop Posts: 5,901
    How do you pronounce that?
  • mthebull
    Exactly like the💩
  • Emlyn
    Emlyn Posts: 4,920
    A monoblock amplifier is a single channel amp in a single case. There is no common ground by design which is partly why people buy them.
    It takes two of the Tyr model for a stereo system.
  • mthebull
    Yes I know what a monoblock is and that I would need two however, I don’t quite fully understand the whole common ground thing. I guess my question is then are there any mono blocks that could possibly be common ground so as that I wouldn’t need the dreadnaught. I specifically inquired about that when I emailed Shiit even telling them what type of speakers I had and the technician said they were common ground. Maybe he misunderstood me?
  • Gardenstater
    Gardenstater Posts: 4,985
    edited January 2024
    I think in this day and age we shouldn't expect competence, we should be surprised by it.
    I think I've heard that some monoblocks can be common grounded together but you have to get the ok from an engineer who really is familiar with their design and knows what he/she is talking about.
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • mthebull
    Are you saying I’m incompetent?
    Viking64 Posts: 7,827
  • Gardenstater
    mthebull wrote: »
    No sorry I didn't mean you, I meant the technician that "helped" you.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
    F1nut Posts: 52,406
    Mono block amps by the very nature of being two entirely separate amplifiers cannot have a common ground.
    As noted, some mono blocks can be strapped together at the negative binding posts creating a common ground situation, but only after consulting the manufacturer to check if that is ok to do.
    audioluvr Posts: 6,079
    Where's @lightman1 to clarify this??? IMHO monoblocks being of identical architecture, plugged into the same circuit and having a signal received by a common ground preamp should have a common ground output.
    Well at least mine do.
  • Astrl55
    Astrl55 Posts: 68
    edited January 2024
  • HzTweaker
    HzTweaker Posts: 1,136
    audioluvr wrote: »
    I was just wondering if both mono amps were pugged into the same outlet that would be enough to make them common ground??(discloser I have no experience with monoblocks)
    2ch rig: Speakers: LSi9s with VR3's Fortress mods Preamplifier: Parasound P5 DAC: Fiio K13 Amplifier: Parasound A23 CDP: Pioneer DV-563A Cables: Wireworld Equinox 7 XLR ICs, Wireworld Ultraviolet 7 USB, AudioQuest Q2s, AudioQuest NRG X(preamp)
    Standby: Magnepan LRS w/Magna Riser stands
  • Gardenstater
    edited January 2024
    I think we are confusing the power supply ground with the signal ground. Are they always the same? Seems to me that some have resistors between neg. binding post and the chassis. I'm out of my league with electronics.
    https://forum.polkaudio.com/discussion/185424/sdas-and-common-ground-amps
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
    mhardy6647 Posts: 35,562
    Signal ground is not necessarily the same as the P/S ground.
    Ground loops. They're a thing.
    https://www.analogictips.com/faq-ground-rules-earth-chassis-signal-ground-faq/
  • Gardenstater
    The manual says the Schitt Tyr is a differential amplifier which means both terminals are hot. Seems like there's no way it could be common ground, even if you used balanced XLR inputs from a common ground preamplifier. https://www.schiit.com/public/upload/PDF/tyr manual 1_1.pdf
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • invalid
    invalid Posts: 1,560
    These amplifiers are not common ground, do to the fact they are differential balanced and monoblocks.
  • mthebull
    I appreciate everyone’s knowledge
    Put an ohm meter to the grounds to verify.
    invalid wrote: »
    There's no such thing as a differentially balanced monoblock.
  • invalid
    audioluvr wrote: »
    invalid wrote: »
    You are incorrect
  • Schurkey
    Schurkey Posts: 2,130
    edited January 2024
    audioluvr wrote: »
    Yours, apparently, are not balanced/bridged. Same with the old Adcom '565 monoblocks. Cram a jumper wire into the negative terminals of the two chassis, good-to-go. There are additional examples. Get it wrong, with amps that don't have the negative terminals tied into chassis ground, and you'll let the smoke out with the jumper wire.
    audioluvr wrote: »
    invalid wrote: »
    Of course there is. I own a pair. There are many brands/models of monoblock (single-channel per chassis) amps that are of the bridged/balanced design. Some are...some aren't.
    edited January 2024
    How do you bridge a true monoblock??? I think everyone is getting confused and using the term "balanced differential" loosely. I'm not talking about a stereo amp that's designed to be run as a mono. That's not a true monoblock. Sorry. Nice try.
  • lightman1
    lightman1 Posts: 10,803
    audioluvr wrote: »
    Not necessarily. "Ground" isolation happens after the power supply in most cases. "Grounding" is what you're thinking of. Terminology is a twisted thing.
    lightman1 wrote: »
    Are you saying I’m incontinent?
  • invalid
    audioluvr wrote: »
    There are all kinds of examples of differential monoblocks pass Labs Dan D'Agostino even the one this thread is about.
  • Schurkey
    edited January 2024
    audioluvr wrote: »
    A "stereo" amplifier designed to be run as a "mono" isn't a "stereo" amplifier.
    A single amplifier chassis with two amplifiers inside, using essentially the same signal but with one running inverted-polarity from the other by design, intended for single-channel use via output terminals where neither one is referenced to chassis ground (directly or through a resistor) isn't a monoblock amp?
    You need to contact the FTC to complain. Heaps of companies are selling just that, advertised as monoblock or similar terminology.
    Schurkey wrote: »
    A single amplifier chassis with two amplifiers inside, using essentially the same signal but with one running inverted-polarity from the other by design, intended for single-channel use via output terminals where neither one is referenced to chassis ground (directly or through a resistor) isn't a true monoblock amp?
    Nope.
  • Schurkey
    A bunch of manufacturers and I disagree with you. But we'll all live happily ever after even so.
    treitz3 Posts: 20,366
    Well, Schiit.
  • skipshot12
    skipshot12 Posts: 2,168
    edited January 2024
    May be the same reason I haven’t bi-amped vertically with my sda srs blade/blades, yet?
    Hook ‘em up and let me know if you hear beautiful music or if you created a mosquito fogger……
  • invalid
    audioluvr wrote: »
    A differential balanced amp doesn't have to be bridged to be differential balanced, that's the cheap way to do it.
