12au7 Tubes
Full disclosure here - I’m fairly inexperienced when it comes to tubes!
I have a Triode TRV-88ser integrated that I purchased from Skip about a year or so ago. Unfortunately it hasn’t seen much use in the time I’ve had it. A few months ago, I switched speakers back and forth comparing two different pairs and noticed that the sound was muddy in one speaker. I did the usual - reconnect cables, swap L/R speakers, etc., and could not resolve. So, I reached out to Skip and he said it’s likely a bad tube or two. I finally got around to trying some of his suggestions. At first the music sounded pretty good, but as things warmed up, I definitely noticed the sound was more pronounced from the right speaker. The first thing I did was switch the preamp tubes and sure enough, the problem followed the tubes - now the left speaker is louder.
This amp has the original stock tubes. So, I’d like to upgrade while addressing the issue. Looking for a recommendation on a matched pair of 12au7 tubes. I could also use a single 12ax7 for the input. Eventually, I’ll be looking to upgrade the Quad set of KT88 tubes, but can’t swing that right now.
I know there are some tubes in the FM. Any other options? Anyone have some good tubes they’re willing to part with that you think would be a good choice to try? Or, I’m open to recommendations on what to look for.
Thanks - Al
