Good Grief...what have I done! Man oh man I've opened a can of worms with this one.
13»
    treitz3 Posts: 19,942
    I read that thread right up to the point to where sales (RA) is a leading marker for performance. I had to stop there.
    Do these people even listen?
  • invalid
    invalid Posts: 1,439
    Ralph also says that if your equipment follows the aes 48 balanced standard that cables don't make a difference, even though quite a few people who own his gear have said they hear a difference with better cables. He is in sales mode.
    VR3 Posts: 29,383
    I use a Boxem class D for my office rig and it sounds really good in that use.
    I tried a larger Boxem Class D amp on the big rig and it just.... it just doesnt sound anywhere close...to a class a/ab amp or a tube amp in any capacity
    They have their place. No doubt.
    That said...
  • Jazzhead
    Jazzhead Posts: 526
    The above Steve Hoffman link had interesting discussion of Class D amplification, which seems to stir controversy like few other topics. Keeping in mind that my rig is modest at best, here goes. My D-Sonic monos sound very nice, and I'm a big fan of the tube rig sound. Dennis Deacon, the D-Sonic designer, did a great job with his design (he uses Pascal modules). I gather some other Class D designs don't measure up. I've been around live music, both performing and listening most of my life and I hear little lacking in well-designed, latest generation Class D. It's a different presentation in very subtle ways relative to tube and Class A/B. It's difficult to describe. The sound is extremely neutral, coming from a "deep space" quiet background and is lacking the pleasing harmonics that one may hear with tubes and A/B (the question is: are those harmonics real or added?). However, they are monsters in regard to power (load handling), realism, attack, dynamics, layering in space of instruments and voice, and iron fist control of prodigious low bass. Some folks on the Hoffman forum mentioned a thin sound(?). I get none of that. I hear no "digititis", glare, or harshness some folks reported in earlier Class D offerings. Add the appealing facts that they are energy efficient, small and light, do not get hot, and are relative affordable. I do think it is very important to pair them with a good preamp, and they benefit from isolation, clean power and firehose power cables. That all said, I understand the allure of tube harmonics etc. It's sort of like how one fine bourbon appeals more to your sensibilities than the other fine bourbon that your friend prefers...
    heiney9 Posts: 25,395
    invalid wrote: »
    I don't understand how the noise floor can be so high with some tube gear, if a tube phono preamp can be made to have a low noise floor then a preamp or DAC should be very silent.
    It's all in the gain. I have found overall (not every time) that the older tubes (early-mid 50's) seem to be a tad nosier. The later tubes tend to have less noise. Also depends on the tube, 12AX7's are much higher gain than 12AU7.
  • motorstereo
    motorstereo Posts: 2,317
    edited December 2023
    I just thought it was strange that someone with his background in the tube field including several patented designs would turn his back so to speak with his bread and butter. His remarks on tube gear aren't exactly the most flattering.
    To those in the know is Class D really that good? I haven't heard one since the early days of it maybe 15 years ago and I wasn't impressed. No doubt things have changed a lot since then. His comment about the semi conductors that didn't exist 30 years ago but they do now is food for thought.
  • invalid
    A guy on audiogon bought a class D amp from Ralph and said it sounded very good, but he still liked his 300B set amp better.
  • GlennDog
    GlennDog Posts: 3,149
    I did not read the entire Hoffman article. But I do agree with post #204 from that thread (page 9, I think)
    Soo logical
    "If money, space and temp didn't matter I'd have all tube gear. It's a myth that tube gear cant be accurate. It's also a myth that measurements trump other aspects of sound and it's a myth that well measuring gear always sounds better. Do we really want no distortion??? Electric guitar players thrive on distortion - how many great guitar amps are tube amps? In fact, I think the best systems are colored in a way that suits their owner. I personally own both tube and SS gear, but the best system I've ever had was an all tube system.
    The real issue, is that most of us don't have audio shops. If we could all go listen to varied gear we wouldn't need to debate SS vs Tubes. We rely on the internet for info ... and it's skewed. Plus, you have the moronic ASR crowd boiling everything down to SINAD. We need to support local audio retailers or support online retailers that have generous return policies. I firmly believe that perfectly measuring gear is not what we really want and pleasing sound is often had with tube gear (though SS is a lot more convenient)."
    Pre Cary SLP-05
    Power Rogue M180 Dark monos
    Mains Salk HT2-TL
    Rythmik F12
    pitdogg2 Posts: 26,918
    Speaking of tubes, I see Tung-Sol upped the game once again with a KT170 power tube.
    Wow 85 watts of power from each tube. I couldn't imagine what Bob Carvers silver seven could with a set of KT170's, yikes you would need some serious cables coming into your panel.
  • invalid
    It would definitely be a cold weather amplifier. I'm still waiting for someone to build a push pull amplifier using gm100 tubes, 150 watts from each tube and almost 2kv on the plate.
  • gyosa
    gyosa Posts: 769
    Class D ?
    What’s not to love ?
    If ya don’t like the way it looks , you can get it in nicer casework , or mono/dual mono versions .
    Class D is the future.
    https://audiosciencereview.com/forum/index.php?threads/apollon-ncx500st-stereo-amplifier-review.47701/
    Bk
    PS Audio S300 , WiiM Ultra , Yamaha wxc-50 , Salk SuperCharged Songtowers , Kimber Kable 4TC, Sony 48” - BEDROOM
    B&K EX-442 ( it will go in my casket when I die ... ) , PS Audio 4.6 preamp ( old school , but it still jams on ... ) , Eversolo DMP-A6 , Boston Acoustic voyager 7’s - POOL
    Parasound A21, Eversolo DMP-A8 , Kimber Kable 4vs , Ascend Acoustics ELX Ribbon Towers , Sony XBR-A8F 65” OLED - DEN , MAIN system
    Onkyo TX-nr609 , Polk atrium 7 , Boston acoustic sound ware (4) , Boston acoustic sub , B&W center , Sony 65” TV - PATIO
    audioluvr Posts: 5,861
    And then there's the fact that everyone's perception of great varies with your ears ability to transform sound to a unique brain and what those two, combined, considers pleasant. Some prefer an accurate, crisp, ear piercing clarity. Others prefer a more warm, smooth, syrupy sound or something in between the two.
    With a couple newer exceptions class D is terrible to listen to.
    Warm and smooth don't equate to syrupy.
    An amp can be crisp, accurate and have tons of clarity, be smooth and have a hint of warmth, transparency, etc.
    I am at the stage in the hobby when gear has to move me emotionally, which allows greater involvement in the music which allows hours and hours more enjoyment. I am pretty much there but still need a few tweaks.
    The XA-25 is the final piece of the puzzle for me. It is a stunning amplifier. It draws you into the recording like no other piece of gear I've heard, timbre, tonality, 3D imaging, image palpability and density. Bass lines that can rock the foundation.
    I let the tube pre (by rolling tubes) fine tune a few things. The L600's sound stunning with this combo, I am actually pretty in awe. My room sucks for fidelity, but holy crap does the XA-25 and L600's sound spectacular.
  • erniejade
    erniejade Posts: 6,321
    "Never underestimate the power of a rectifier"
    So, i have been testing out a set of Klipsch The Nines powered speakers. ( doesn't laugh, they actually sound better then I thought they would). Using my Innuos usb out to the Nines internal Dac sounds ok but, to my ears, looses some body. The Innuos going to the Boarder Patrol se-i that has a tube rectifier adds quite of musicality or soul back vs the Nines internal dac. Yes I know I am using more money's worth of streaming gear then the Nines cost, ( SBOOSTER power supply to the router, EtherREGEN, TeraDak to power the EtherREGEN, RAL umbilical to the EtherREGEN, RAL Ethernet cable and USB cable to the Boarder Patrol se-i) but the Nines actually let the sound of the better streaming setup shine though vs it's internal dac.
    On my main rig, yes the Tri-Vista has a tube in it but, if I turn the tube off on the BoarderPatrol dac, I can hear the difference. It looses something that I just cannot put into words to describe. It's just better with it engaged.
    All that said, I have heard systems without tubes that I wasn't missing a tube like Norma but, it seems thoes are more one off vs the majority.
    VR3 Posts: 29,383
    Going back to an earlier post... my reference for music is my almost one decade of working in a music store and being around musical instruments day in and out.
    The HIFI sound of the last twenty years sounds absolutely nothing like an instrument sounds in real life. Not even in the ballpark in my opinion. To me, it as if a computer analyzed what an instrument was supposed to sound like, and it spit out its own version of it. Instruments have natural distortions, decays, etc. that sometimes get lost in the recording. You talk to any musician, they are usually seeking a certain tone or something in their instruments that are usually found on really worn in instruments or instruments that are very old that have aged. From a recording engineer perspective it is very hard to translate that to a finished product.
    Tubes almost put what's lost back. Sounds strange but that's what tubes are to me. It captures the essence, the soul of the instrument and singer that is lost in the recording process, I cant tell you how it does it, but it just has that sound that makes music...music.
    A recording is never going to be the same as the live event. The recording process has flaws too, just like the playback and playback room.
    I am a believer in tubes, I will probably always run them. I like the nostalgia, glow and warmth (in addition to how they perform) But there are SS designs that give 97% of the tube sound.
  • jbreezy5
    jbreezy5 Posts: 1,141
    What doesn’t make sense to me is how much the industry has tried to make tubes sound like solid-state and vice-versa; almost as if trying to make them indistinguishable.
    Why not cooperate with the innate sonic characteristics each technology offers naturally?
    I like the warm, syrupy, colorful tubey sounds sometimes. Other times I want the neutrality that solid-state offers.
    Preserving these differences would enhance the hobby, imo.
    txcoastal1 Posts: 13,499
    jbreezy5 wrote: »
    Tell that to some of the greatest artist of blues and jazz. SRV has so many amps tuned for style and attitude for his guitars it would make your head spin....
    Plus the guitars....OMG lets not get started
    Merry Christmas @jbreezy5 :)
    Just things that make you go HMMMM!!!
  • jbreezy5
    txcoastal1 wrote: »
    jbreezy5 wrote: »
    Late Merry Christmas @ txcoastal1
    jbreezy5 wrote: »
    What do you mean? Old stock tubes knew nothing about transistors as they hadn't been invented. I listen to Old stock tubes and they are not overly warm or syrupy.
    So you must be talking about today's manufactured tubes, which I'm not sure they are intentionally making to sound like SS, it's just that the old methods of tube making and the materials are no longer able to be done or found. So, there is no way to really "recreate" the tube sound of the past.
  • jbreezy5
    heiney9 wrote: »
    jbreezy5 wrote: »
    I’m not claiming the tubes themselves have different sonic characteristics than they ever did.
    Modern tube designs (amplification circuits, whether pre or power amp circuits) have been aimed to sound more like solid-state.
    This isn’t a new claim I’m making. Many professional reviewers have discussed this since the early 2000s. They claim modern tube designs sound less tubey, syrupy, fat, etc. than old tube amp designs.
    That is entirely possible.
    VR3 Posts: 29,383
    I have ran some newer tube gear... Musical paradise? I think it was. It truly sounded nothing like tubes. I've experienced some other newer gear with tubes and again very little tube sound.
    mhardy6647 Posts: 34,905
    heiney9 wrote: »
    jbreezy5 wrote: »
    What doesn’t make sense to me is how much the industry has tried to make tubes sound like solid-state and vice-versa; almost as if trying to make them indistinguishable...
    What do you mean? Old stock tubes knew nothing about transistors as they hadn't been invented...
    Only the ones made before 1948 ;)
    In all (well... some) seriousness, the earliest well-known commercial solid state hifi component was a Fisher phono preamp, announced in 1956.
    source: https://www.worldradiohistory.com/Archive-All-Audio/Archive-Audio/50s/Audio-1956-May.pdf pg. 68 of the magazine
    SCompRacer Posts: 9,077
    You could say vacuum tubes are a more linear conductor than Solid (or is it soiled as doc hardy says? :D ) State so they can maintain signal integrity better than transistors. Then again, components and the circuit matter.
    I fondly remember Paul Grzybek of Bizzy Bee Audio (RIP). He was local to me. He would buy these nice-looking Chinese tube amps that sounded poorly to some. Paul swapped a few components with some circuit changes and transformed them into nice sounding gear.
  • RamZet
    RamZet Posts: 792
    Nothing is permanent.
    I just re-arranged my configuration tonight.
    I bounce from from Classé sigma pre/amp, to just a Sonos amp, to a Sonos port + rotel dac and amp combo. Last year I was using vintage McIntosh stuff.
    It’s fun and all setups have something unique to play with.
    Just setup your system to fit your mood.
    B&W CM9Classé Sigma
