Got a pair of M10 Series 2, need to replace one of the SL2500 tweeter, SL2500 or RD0198?
mastergat
mastergat Posts: 8
edited January 2019 in Speakers
Hi, just got my hand on a nice pair of M10 Series 2 and one of the tweeter is dead. I'm wondering if I should get a SL2500 to replace it or upgrade both tweeter with the direct fit-in replacement RD0198? Also, if you guys would have 1 SL2500 or 2 RD0198 that you want to part out, I'd be happy!
Also! Would you guys recap the crossovers? If yes, I would need to source the exact same caps or there are better ones? I'm in Canada by the way!
EDIT: My bad, RD0198 instead of RD0194
Post edited by mastergat on
  • Is there a fuse on the back?
    SDA SRS 2.3TL's
    SDA 2B TL's
  • motorhead43026
    motorhead43026 Posts: 3,992
    edited January 2019
    Series Il will use the RDO198. Which is the replacement for the SL2500.
    – Kevin Alfred Strom
  • @michaeljhsda2 at the back of the tweeter, no, you can only see the magnet.
    @motorhead43026 my bad, RD0198 indeed!
  • I should have been more specific, are there any fuses at the binding-post cup? If there are try rotating the fuse in the socket, it could just be a bad connection.
    SDA SRS 2.3TL's
    SDA 2B TL's
    Nothing behind the binding post cup, only the crossover :(!
    F1nut Posts: 51,662
    You can't buy a new SL2500, so you'll need the buy 2 new RD0198 tweeters.
  • boston1450
    boston1450 Posts: 7,758
    198's are far better. Your ears will thank you. Yes on crossovers as they are old & tired. 10's are great speakers. Welcome to Polk forum
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
  • boston1450 wrote: »
    All right, I'll go this way! I read that there's a discount for members of this forum directly at Polk? How can I get this discount, do I need to send an email to someone to get a quote?
    Thank you!
  • boston1450
    call Polk & tell them your on Polk forum & they will discount you on order
    Randy-Maine
    by David WMG
  • boston1450
    Every Polk Monitor or SDA upgraded tweeter ive done there is a very noticeable difference. Well worth the price. Keep old ones for spares Or sell em off. Make sure you have the speaker model 100% correct & the correct tweeter for your upgrade. Post pictures here can be very helpful
    Randy-Maine
    by David WMG
  • mastergat
    mastergat Posts: 8
    edited January 2019
    boston1450 wrote: »
    Here are the tweeters, SL 2500, so I assume I need 2 RDA0198, right?
    pitdogg2 Posts: 26,919
    Yes the RD-0198 is the correct tweeter to replace those.
  • FYI and everyone, if you are in Canada, you can order them from a company in Ontario called Morgan Technology (http://www.morgantech.ca)! Got them at 40 CAD each which is cheaper than Polk Audio with the forum discount!
  • Installed my RD0198 and built the new crossovers! They are now rocking!
  • boston1450
    edited January 2019
    Nice. I think you'll like those tweets. Nice work. Enjoy breaking in those crossovers
    Randy-Maine
    by David WMG
  • Did you remove the poly switches?
    That binding post cup looks a little rough. Is it sealed back there? If not that will affect bass output.
  • Good eye pit.
  • mastergat
    mastergat Posts: 8
    edited January 2019
    I don't even know what it is :open_mouth: ! Can you point it out on this pic and tell me what they do and why should I remove them?
    If you are referring to this type of component, there was none on the board.
    Yeah, this cup is damaged but it seals thightly!
  • EBERE
    EBERE Posts: 3
    edited November 2023
    Folks new here. Looking to get my hands on a couple RD0198 tweeters. I am in Canada west coast & have not had much luck locally... Posting here as I noticed Mastergat mentioned Morgantech.ca, I have tried calling these guys as the web link does not work, and left multiple messages no response either.... any recommendations would be appreciated.
    F1nut Posts: 51,662
  • ChrisD06
    ChrisD06 Posts: 912
    EBERE wrote: »
    Buy directly from Polk. Midwest Speaker Repair (the link F1Nut sent) is good for US buyers but the shipping is pretty high. I paid $156 on the dot for two RD-0198 tweeters, that's in Canadian dollars and includes shipping to my doorstep.
    Midwest will be $172.49 CAD without shipping. Make sure you tell Polk Audio you're a member of the forum for a discount.
    My gear:
    • Onyko TX-NR656
    • RT3000p L&R
    • CS1000p Center
    • RT35 Side
    • RT35 Rear
