Got a pair of M10 Series 2, need to replace one of the SL2500 tweeter, SL2500 or RD0198?
Hi, just got my hand on a nice pair of M10 Series 2 and one of the tweeter is dead. I'm wondering if I should get a SL2500 to replace it or upgrade both tweeter with the direct fit-in replacement RD0198? Also, if you guys would have 1 SL2500 or 2 RD0198 that you want to part out, I'd be happy!
Also! Would you guys recap the crossovers? If yes, I would need to source the exact same caps or there are better ones? I'm in Canada by the way!
EDIT: My bad, RD0198 instead of RD0194
Post edited by mastergat on
Is there a fuse on the back?SDA SRS 2.3TL's
SDA 2B TL's -
Series Il will use the RDO198. Which is the replacement for the SL2500.Patriotism is the last refuge of a scoundrel…….Samuel Johnson
– Kevin Alfred Strom -
@michaeljhsda2 at the back of the tweeter, no, you can only see the magnet.
@motorhead43026 my bad, RD0198 indeed! -
I should have been more specific, are there any fuses at the binding-post cup? If there are try rotating the fuse in the socket, it could just be a bad connection.SDA SRS 2.3TL's
SDA 2B TL's -
michaeljhsda2 wrote: »I should have been more specific, are there any fuses at the binding-post cup? If there are try rotating the fuse in the socket, it could just be a bad connection.
Nothing behind the binding post cup, only the crossover
You can't buy a new SL2500, so you'll need the buy 2 new RD0198 tweeters.Political Correctness'.........defined
President of Club Polk -
198's are far better. Your ears will thank you. Yes on crossovers as they are old & tired. 10's are great speakers. Welcome to Polk forumRandy-Maine
2ch-RTA15tl crossover upgrade
by David WMG
Yamaha cr1000 cr2040
HT-Yamaha Parasound Acurus
boston1450 wrote: »198's are far better. Your ears will thank you. Yes on crossovers as they are old & tired. 10's are great speakers. Welcome to Polk forum
All right, I'll go this way! I read that there's a discount for members of this forum directly at Polk? How can I get this discount, do I need to send an email to someone to get a quote?
Thank you! -
call Polk & tell them your on Polk forum & they will discount you on orderRandy-Maine
by David WMG
Every Polk Monitor or SDA upgraded tweeter ive done there is a very noticeable difference. Well worth the price. Keep old ones for spares Or sell em off. Make sure you have the speaker model 100% correct & the correct tweeter for your upgrade. Post pictures here can be very helpfulRandy-Maine
by David WMG
boston1450 wrote: »Every Polk Monitor or SDA upgraded tweeter ive done there is a very noticeable difference. Well worth the price. Keep old ones for spares Or sell em off. Make sure you have the speaker model 100% correct & the correct tweeter for your upgrade. Post pictures here can be very helpful
Here are the tweeters, SL 2500, so I assume I need 2 RDA0198, right?
Yes the RD-0198 is the correct tweeter to replace those.
FYI and everyone, if you are in Canada, you can order them from a company in Ontario called Morgan Technology (http://www.morgantech.ca)! Got them at 40 CAD each which is cheaper than Polk Audio with the forum discount!
Installed my RD0198 and built the new crossovers! They are now rocking!
Nice. I think you'll like those tweets. Nice work. Enjoy breaking in those crossoversRandy-Maine
by David WMG
Did you remove the poly switches?Patriotism is the last refuge of a scoundrel…….Samuel Johnson
That binding post cup looks a little rough. Is it sealed back there? If not that will affect bass output.
Good eye pit.Patriotism is the last refuge of a scoundrel…….Samuel Johnson
motorhead43026 wrote: »Did you remove the poly switches?
I don't even know what it is
! Can you point it out on this pic and tell me what they do and why should I remove them?
If you are referring to this type of component, there was none on the board.
Yeah, this cup is damaged but it seals thightly! -
Folks new here. Looking to get my hands on a couple RD0198 tweeters. I am in Canada west coast & have not had much luck locally... Posting here as I noticed Mastergat mentioned Morgantech.ca, I have tried calling these guys as the web link does not work, and left multiple messages no response either.... any recommendations would be appreciated.
Buy directly from Polk. Midwest Speaker Repair (the link F1Nut sent) is good for US buyers but the shipping is pretty high. I paid $156 on the dot for two RD-0198 tweeters, that's in Canadian dollars and includes shipping to my doorstep.
Midwest will be $172.49 CAD without shipping. Make sure you tell Polk Audio you're a member of the forum for a discount.My gear:- TCL 75QM7K TV
- Onyko TX-NR656 AVR
- RT3000p Fronts
- CS1000p Center
- RT35 Side Surrounds
- RT35 Rear Surrounds
