You’re doing it wrong…
11516182021109
    treitz3 Posts: 19,958
    edited November 2023
    How in the.....does that dude take a right? My word.
  • boston1450
    boston1450 Posts: 7,758
    Makes you wonder how high it is lmao
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
  • sucks2beme
    sucks2beme Posts: 5,681
    I used to see guys like that hauling pallets all the time in Dallas.
    I guess a trailer was just too easy?
    mhardy6647 Posts: 34,935
    sucks2beme wrote: »
    They probably didn't like maneuvering a trailer. ;)
    audioluvr Posts: 5,885
    Too bad there isn't a video of them stacking those.
  • smglbrth
    smglbrth Posts: 1,496
    sucks2beme wrote: »
    There must not be much wind in Dallas. Heck, I'm sure there is but this guy evidently had zero wind that day. Talk about a high profile vehicle!
  • sucks2beme
    Highway debris was pretty common in North Texas. You should see all the
    Old trucks hauling around construction waste or old roofing. They were always
    overloaded. I had more flat tires than you could imagine. I got good at
    patching holes. I moved, but I still make sure to have full size spares in
    the trunk.
    msg Posts: 10,452
    I wish I could get a deal like that on pallets. I need a bunch to build better block jumps to the roof for my goats. That guy probly has goats.
  • sucks2beme
    They are generally independent contractors that pick up pallets from
    end locations to be reused. These guys are poor as dirt. They are about
    One step below roofers.
  • boston1450
    ^^^^ correct. I've actually giving away pallets at truck stops because if I was picking up loads I'd need the room, empty trailer. I've bought pallets as well. The blue Chet pallets were worth $$$ as the shipper charged deposit for them.. NEPW will take all the pallets you have if they are a certain size as well
    Randy-Maine
    by David WMG
  • daddyjt
    daddyjt Posts: 3,039
    ― Aleksandr Solzhenitsyn
  • daddyjt
  • daddyjt
  • Willow
    Willow Posts: 11,220
    daddyjt wrote: »
    At least the ladder is secure.... somewhat
  • maxward
    maxward Posts: 1,677
    I’m guessing that “her” second passenger isn’t too comfortable in the back.
    msg Posts: 10,452
    daddyjt wrote: »
    There. Easily fixed with a a few 1x2 furring strips to shore up the structure over to that green thing on the left.
    Wow! What a waste of lumber!
    Sometimes, ya' gotta wonder about people.
  • ChrisD06
    ChrisD06 Posts: 924
    I embarrassingly cannot tell the issue with this. Someone help me out please 💀
    My gear:
    • Onyko TX-NR656
    • RT3000p L&R
    • CS1000p Center
    • RT35 Side
    • RT35 Rear
  • motorstereo
    motorstereo Posts: 2,318
    ChrisD06 wrote: »
    Surely you jest..........it's easier to say what's been done correctly. Edit; I don't see anything that is built even close to correctly.
    ChrisD06 wrote: »
    The funniest thing is that whoever crafted that worked really hard. :|
  • ChrisD06
    ChrisD06 Posts: 924
    ChrisD06 wrote: »
    I mean it looks nothing like the deck on my house that was completed some years ago however I don't know if it's different for smaller porches like this.
    The lumber looks really small and I've just noticed the posts are directly touching the joists.
    There's a reason I don't muck about with structural stuff
    My gear:
    • Onyko TX-NR656
    • RT3000p L&R
    • CS1000p Center
    • RT35 Side
    • RT35 Rear
    ChrisD06 wrote: »
    Everything starts with a good foundation. This is not.
    2x4's nailed together and stuffed in concrete 6" below grade will be rotting away in a couple of years (if they're lucky). Down spout for the gutters will ensure that.
    2x4's don't have much strength laid flat, even with another one nailed on top of it and the ladder will trap moisture in between further accelerating rot. There is a 2x4 "support" over by the gutter down spout that's not supporting anything.
    The spacing between supports is excessive and would be like walking in an inflatable fun house (at least until something fails)
  • ChrisD06
    ChrisD06 Posts: 924
    audioluvr wrote: »
    ChrisD06 wrote: »
    Holy smokes I didn't even notice those were 2x4s nailed together, I thought those were 4x4s. Didn't see the floating 'support' either.
    I didn't know burying posts wasn't allowed... actually our old deck had that and when it was replaced the guys who did it said it was not even close to being up to code, even for the time it was built. So now I know a reason why...
    Thank you for explaining! 🙏
    My gear:
    • Onyko TX-NR656
    • RT3000p L&R
    • CS1000p Center
    • RT35 Side
    • RT35 Rear
    Hillbilly tire repair....
    msg Posts: 10,452
    Just so everyone knows, Ivan "liked" this post.
