RTI Tweeters
13»
Answers
  • zvucnik
    zvucnik Posts: 55
    A7 is probably going to be fine with this Dayton tweeter, however the question is will A6 be fine with it as well given its lower crossover point?
    Product Specifications
    Cone / Dome Diameter 1"
    Cutout Diameter 1.34
    Tweeter Type Soft Dome
    Power Handling (RMS) 20 Watts
    Impedance 4Ω
    Frequency Response 2,500 to 20,000Hz
    Sensitivity 90dB 2.83V/1m
    Thiele-Small Parameters
    Resonant Frequency (Fs) 1350Hz
    DC Resistance (Re) 3.2Ω
    Voice Coil Inductance (Le) 0.04mH
    Mechanical Q (Qms) 3.87
    Electromagnetic Q (Qes) 2.61
    Total Q (Qts) 1.56
  • Gardenstater
    Gardenstater Posts: 4,801
    zvucnik wrote: »
    Impedance 4Ω
    Total Q (Qts) 1.56
    I'm thinking probably not. According to the 2nd article I posted, you want a crossover frequency 1-1/2 to 2 octaves above Fs, for a 12dB/octave filter. I think you'd either need to add a notch filter or modify the crossover to 18dB/octave.
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • gp4jesus
    gp4jesus Posts: 2,019
    edited October 2023
    zvucnik wrote: »
    @gp4jesus What about A6?
    l hafta pull my computer from my mouth as I’ve learned along w/anyone following this thread can see I don’t know how to determine which XO components do what
    zvucnik wrote: »
    Did you swap tweeters on yours with daytons?
    I’m sorry to admit I haven’t performed any work on my Dayton/Polk swap in months as an oversized backyard project* (for one person) has consumed most of my time & energy… …but the hardest portion of the current phase of the above* is nearly complete & winter is coming
    side note: the Polk tweeter seems to be ok EXO’d @ 2.2K LR 4th order in my A6 & A7s
    *all connected w/Premiere ICs
    F1nut Posts: 51,944
    Yet another example of the new guy not listening.
  • zvucnik
    zvucnik Posts: 55
    edited October 2023
    so I played with Xsim and replicated, the best I could (without inductor coil values, I used 0.15 mH), CSi A6 crossover to see where is the original actual tweeter crossover frequency.
    Does anyone know the actual values of the inductor coils in the A6?
    Looking at this graph looks to be close to 3000 Hz or am I reading this wrong (tweeter is green curve, red and orange are woofers)?
    Post edited by zvucnik on
  • zvucnik
    zvucnik Posts: 55
    edited October 2023
    found RTiA series schematics: https://forum.polkaudio.com/discussion/198242/rtia-crossover-schematics
    updated A6 Xsim FR with correct inductor core values and it looks like tweeter is crossed over at 2500Hz:
    A6
    A5
    A7
  • ChrisD06
    ChrisD06 Posts: 929
    So is your end plan to just rebuild the crossovers with new values to support the Dayton tweeter?
    My gear:
    • TCL 75QM7K TV
    • Onyko TX-NR656 AVR
    • RT3000p Fronts
    • CS1000p Center
    • RT35 Side Surrounds
    • RT35 Rear Surrounds
