RTI Tweeters
toolbelt
toolbelt Posts: 124
edited September 2023 in DIY, Mods & Tweaks
As a fun project, I am replacing blown tweeters (RD0690-1) in my spare RTI4's (in addition to replacing a blown crossover resistor and blown driver). Based on specs and faceplate fit, I've narrowed it down to 3 choices;
-Peerless OC25SC65-04
-Eminence SD28
-Dayton ND25FN-4
All will require minimum faceplate alteration (slight enlargement of dome opening). All have similar sensitivity, Ohmage and power handling. The Eminence is about 30% more expensive. The Dayton looks to have better heat control but has a listed low end of only 2500Hz, compared to 1300Hz and 1500Hz for the other two (although Dayton's graph seems to show them handling 1400Hz). They all top out at 20Khz. The RTI4's crossover at 1900Hz.
Does anybody have experience with either of those 3 tweeters, or perhaps additional options not listed? Value wise, I can't justify repairing these speakers, so I'm doing it just for kicks. All in, it will cost around $100 Cdn. Any thoughts?
Polk RTIA3 Fronts
Polk CSIA4 Center
Polk PSW Sub
Pioneer VSX-521-K AVR
And a friendly Labrador Retriever
«13
Answers
    F1nut Posts: 51,685
    You can buy RD0690-1 tweeters on eBay.
  • Yes, but when factoring in shipping and exchange rates, many of them would run me $100 ea.....used.
    Polk RTIA3 Fronts
    Polk CSIA4 Center
    Polk PSW Sub
    xschop Posts: 5,075
    At those prices, you could try the Daytons and the Peerless.
  • xschop wrote: »
    The cost I quoted includes a used woofer and new resistor, as well as the tweeters, which will run around $30 ea including shipping.
    Polk RTIA3 Fronts
    Polk CSIA4 Center
    Polk PSW Sub
    F1nut Posts: 51,685
    toolbelt wrote: »
    So what, you would have the correct tweeter and not some...well, it might be close, which might actually not be.
    xschop Posts: 5,075
    All vintage Polk parts are now a crapshoot at any forum/swap-meet/cheapbay.
  • xschop wrote: »
    True. That's why I'm going the aftermarket route, which may or may not be an upgrade, although I read Polk was using Vifa tweeters at some point, which I believe has some association with Peerless. The RTI's were rated up to 26,000Hz, and neither of these replacements is rated at more than 20Khz, but I don't see that as a factor. Polk keeps their driver specs pretty close to their vests, so the only knowns are the Ohm rating and physical size.
    Polk RTIA3 Fronts
    Polk CSIA4 Center
    Polk PSW Sub
    F1nut Posts: 51,685
    Buying used audio anything could be considered a crap shoot, but buying non-OEM is ALWAYS a crap shoot.
  • F1nut wrote: »
    It's a crap shoot only if my goal is to maintain the authenticity of my RTI's. It's a crap shoot buying Chinese aftermarket components. Dayton and Eminence have a good reputation, and Peerless is not an unknown source either. While replacing with aftermarket components will definitely change the RTI's performance, it might be for the better. As I stated at the beginning, this is just a hobby rebuild of speakers I don't even need. As an added bonus, I'm learning a lot about speaker components as I go. :)
    Polk RTIA3 Fronts
    Polk CSIA4 Center
    Polk PSW Sub
  • Why not use the links to that Tuan Tran guy I sent you a month or so back? He has the correct tweeters for like, idk, $30/ea?
    My gear:
    • Onyko TX-NR656
    • RT3000p L&R
    • CS1000p Center
    • RT35 Side
    • RT35 Rear
    F1nut Posts: 51,685
    You can lead a horse to water, but...
  • ChrisD06 wrote: »
    Actually I did get the RTI4 woofer he had, but when I ordered it, he only had one of the two tweeters left. So rather than chasing down another one, I decided that, for the same price, I would just order new. But as you had previously mentioned, his packaging is amazingly secure. I also told him about your referral and sent him a link of our forum discussion.
    Polk RTIA3 Fronts
    Polk CSIA4 Center
    Polk PSW Sub
  • F1nut wrote: »
    Unfortunately, he had already sold one of my puddles. lol
    Polk RTIA3 Fronts
    Polk CSIA4 Center
    Polk PSW Sub
  • toolbelt wrote: »
    I'd personally order the tweeter he has left and then source a second one on Reverb or Ebay.
    toolbelt wrote: »
    Yeah it's pretty astonishing. You could probably throw his packages off of a building and the drivers wouldn't suffer damage LOL.
    toolbelt wrote: »
    He must have been pretty surprised to see that a guy he sold a woofer to recommended him to another guy half way across the country on the internet 😂
    My gear:
    • Onyko TX-NR656
    • RT3000p L&R
    • CS1000p Center
    • RT35 Side
    • RT35 Rear
  • ChrisD06 wrote: »
    toolbelt wrote: »
    toolbelt wrote: »
    toolbelt wrote: »
    His exact words were;
    "Really I did not know that someone recommended me in the Polk audio forum. I thought that I am the man in the movie Cast Away " lol
    Polk RTIA3 Fronts
    Polk CSIA4 Center
    Polk PSW Sub
  • toolbelt wrote: »
    -Eminence SD28
    -Dayton ND25FN-4
    Well I went with the Dayton's (ND25FN-4) and although I thought I would need to slightly modify the faceplate opening for dome clearance, the faceplates actually have a stepped opening which allows for proper clearance of the dome's outer rolled ring. The outer diameter of the Dayton is exactly the same as the Polk original (41mm), and they insert snuggly without having to be forced in. The Dayton, like the original, has a multi-point star heat sink on the magnet which is exactly the same (diameter, number of points, thickness) as the Polk. The thickness of the locking nubs are the exact same, allowing for push and turn mounting with the faceplate's clasps. It's basically an exact clone of the Polk, although Dayton makes no mention of Polk applications in their spec sheets. The rated wattage and frequency range should pair nicely with the Polk crossover, and the 90 db sensitivity should also match well with the Polk woofer. I'm still in the process of repairing the crossover (needs 2.5 ohm 5 watt radial resistor, or equivalent), and then I'll report back with a sound test. It's fairly easy to remove the Polk tweeter from it's faceplate by cutting the thin (RTV like) glue, and twisting it to release the nubs from the clasps.
    Polk RTIA3 Fronts
    Polk CSIA4 Center
    Polk PSW Sub
  • toolbelt wrote: »
    toolbelt wrote: »
    -Eminence SD28
    -Dayton ND25FN-4
    Correction: The faceplate opening does require very modest enlarging of just less than 1/8" in total.
    Polk RTIA3 Fronts
    Polk CSIA4 Center
    Polk PSW Sub
  • gp4jesus
    gp4jesus Posts: 2,016
    toolbelt wrote: »
    toolbelt wrote: »
    -Eminence SD28
    -Dayton ND25FN-4
    PLEASE post some pics. I plan to replace all my RTi A* series tweeters* w/the same driver. Appreciate tips to avoid “re-inventing the wheel.”
    *RTi & RTi A series speakers use the same tweeter
    *all connected w/Premiere ICs
  • gp4jesus wrote: »
    toolbelt wrote: »
    toolbelt wrote: »
    -Eminence SD28
    -Dayton ND25FN-4
    Not sure if the RTI and RTIA's have identical faceplates and tweeter cup size but I will document and take some pics. I will say it is almost impossible to remove the old tweeters without damaging them, but if they're toast already, the process is simply a matter of tracing around the outside edge of the old tweeter with an xacto knife, being careful to stop at each of the 4 plastic clasps holding the 4 tweeter nubs. If your old tweeter has a star-shaped cooling heat sink on its back, you can then use it to rotate the tweeter about 1/8 of a turn to disengage the nubs from under the clasps. I used channel lock pliers to twist mine. The tweeters aren't really "glued in". The sealant is really just to prevent the tweeter from rotating. The plastic clasps are what holds the tweeter in place. The sealant is much like a thin layer of "RTV" like material, and cuts fairly easily. I intend to use hot glue when reinstalling the Daytons. It's not like a tweeter jumps around much while running.
    Polk RTIA3 Fronts
    Polk CSIA4 Center
    Polk PSW Sub
  • toolbelt
    toolbelt Posts: 124
    gp4jesus wrote: »
    toolbelt wrote: »
    toolbelt wrote: »
    -Eminence SD28
    -Dayton ND25FN-4
    ok so here was the basic procedure. I cut the old sealant around the perimeter of the back of the old tweeter, and twisted it out from the perimeter clasps. Because the Dayton had a thicker flange than the Polk, you need to cut off the plastic retaining clasps as well. The Polk faceplate mounting hole has a slight bevel around its opening. As the Daytons require a 34MM dome opening, and the Polk faceplate has a 31MM opening, you need to enlarge the faceplate hole by about 3MM, or about the size of the bevel on the original faceplate opening. I used the edge of a utility knife and shaved it. The tweeter cup size of the Dayton is 41MM so its a perfect fit O.D. wise. For added measure, I re-bevelled the faceplate dome opening to ensure that the rolled surround on the tweeter had extra clearance. I then installed the tweeter on the faceplate, and used hot glue to make it air tight. The Dayton tweeter paired well with the OE woofer, and to my untrained ears, reproduces midranges slightly better.d1xw781j2air.jpg
    Polk RTIA3 Fronts
    Polk CSIA4 Center
    Polk PSW Sub
    xschop Posts: 5,075
    Another Dayton-Polk. Looks great too.
  • toolbelt
    toolbelt Posts: 124
    xschop wrote: »
    Actually, at first I thought the black tweeter would look funny as a replacement, But it actually blends well and is balanced by the look of the front port. I haven't really cranked it, but so far, I'm pleased. It may be a db or two more sensitive than the original (or it could be the Mills resistor upgrade) but it has a more crisp sound, while still being warm.
    Polk RTIA3 Fronts
    Polk CSIA4 Center
    Polk PSW Sub
  • ChrisD06
    ChrisD06 Posts: 912
    This is probably one of the best aftermarket mods I've seen purely because of how perfectly it fits with so little modification to the enclosure.
    Looks awesome.
    My gear:
    • Onyko TX-NR656
    • RT3000p L&R
    • CS1000p Center
    • RT35 Side
    • RT35 Rear
  • toolbelt
    toolbelt Posts: 124
    The trickiest part was finding a reputable tweeter that would fit. I was originally going to go with the Eminence SD 28 but Solen was out of stock, and recommended the Dayton instead (which was already on my list of options). The Dayton has the same heat sink as Polk on its back, although I believe they can be transferred over to the Eminence as it appears they have a threaded hole on their rears for that very purpose. It was a fun little project though in the grand scheme, not very cost-effective. They do sound as good or better than new.
    Polk RTIA3 Fronts
    Polk CSIA4 Center
    Polk PSW Sub
  • gp4jesus
    edited October 2023
    Toolbelt: what are the “plastic retaining clasps” I “need to cut off?”
    I’ve removed the Polk tweeter and have done some trimming & sanding to fit the Dayton into the bezel. To me your pics eliminate any doubt we can “exchange” tweeters” between RTi & “A” series w/little if any trouble. Also I assume you used a low-temp hot glue to prevent damage to the new tweeter?
    Consider foaming the magnet shield* and both the inside** and outside of mid’s basket. Pic & link** to follow.
    *undamped they ring like bells.
    **dirt cheap mod I admit requires some patience but well worth the time
    Thanks. Tony
  • gp4jesus
    edited October 2023
  • gp4jesus
    edited October 2023
    xschop wrote: »
    I think it improved the speaker’s appearance. Gonna paint my bezels black to match the black oak finish.
  • toolbelt
    toolbelt Posts: 124
    gp4jesus wrote: »
    Thanks. Tony
    What do the backsides of the A tweeter bezels look like? Same as the I's? Also. wouldn't that insulation affect heat buildup?
    Polk RTIA3 Fronts
    Polk CSIA4 Center
    Polk PSW Sub
    xschop Posts: 5,075
    toolbelt wrote: »
    xschop wrote: »
    And your MW's look just like my TSI's I had to mod, because the dust caps started coming off.
  • gp4jesus
    toolbelt wrote: »
    Yes
    toolbelt wrote: »
    I doubt it. See the vent hole in the shield?
