Starting Out - Legend Series Set-Up Questions
Ok, I just recently retired and relocated back to the U.S. and after years of moving I wanted to start investing in my man cave. This is what I want to go with for the time being:
1) Front Stage - 2xL600 (L&R) and L400 center
2) Rear/Surrounds - I have old Mirage OMD5 that I've been moving around with.
Receiver - Denon - AVR-X4300H (yes, about 5 yrs old and I'll upgrade soon enough).
Questions:
I'm starting with the L600s for now, but when I move in a year to my house I plan to upgrade these to L900s, and move the L600s to the rear. With this in mind I wanted to ask about amps. I'm looking at Emotiva for the extra power and specifically this: a) BasX A3, b) BasX A6.
1) Would both of these be sufficient for the front channels considering that they would be powering L600s and the L400 now, but L900s and L400 later. Second,
2) Would it be be better or would there be a distinct difference between the A3 or bi-wiring the A6?
Thank you for the your assistance and perspective!
  • CottageChz
    Hi, I don’t know a lot about home theater, but one thing that stuck out to me in your post is the comment about switching to L900s for the front. The L900s are drop-in modules that go in the top of the L600, they are not a standalone speaker.
  • apparat
    Yes, you are absolutely correct! I didn't sleep well last night anticipating my purchase and audio bliss. I meant L800s.
    pitdogg2 Posts: 24,635
    Honestly with the kind of money you're already investing, I'd look real hard at a Parasound multi-channel amp.
    F1nut Posts: 49,859
    Agree with the pit. You will need a sub and for HT the SVS subs do well. I prefer a sealed SVS for HT as it is tighter, but if you prefer more boom then go ported.
    msg Posts: 9,515
    apparat wrote: »
    haha, awesome - I know this feeling. I think my first 6 months I got horrible sleep, up late at night, reading, posting, speculating, imagining - just completely obsessed and impatient to get gear in house to get dialed so I could enjoy music again.
    unfortunately, it never ended.
    I started getting better sleep and the obsession died down a little bit, but it took years. and it still rears up at times. you're pretty much hosed. Welcome!
    msg Posts: 9,515
    ...the pit
    lol we're using this moving forward.
  • tophatjohnny
    Let me check with “The Pit” I’ll get back to ya. 🎩
  • apparat
    Ok, I just ordered an Outlaw Audio Amp - 7000x. It puts out 200w at 4ohms all channels. I think that should suffice for now, and it has both RCA and XLR connections. My current receiver only has RCA, but I think I'll be moving to an Emotiva dedicated processor vice a receiver once they get them in-stock again.
  • rooftop59
    rooftop59 Posts: 7,994
    apparat wrote: »
    That amp should do nicely. Congrats!
    I have a Denon AVR-X4200W and I see no reason to upgrade for home theater. It does full 4K with Dolby vision and Dolby Atmos and can run 9.2 with Audyssey XT-32 calibration. Unless you're going 11.2 or 8K, what more do you need exactly?
    Game Room 5.1.4:
    Bedroom 2.1
  • apparat
    rooftop59 wrote: »
    apparat wrote: »
    Not planning on the AVR upgrade immediately. That's down the line. Now, I just found Arendale 1723's and really torn between then and the Legend.
    Looks like a great speaker!
  • apparat
    The Legends or Arendale 1723 or both? ;)
    F1nut Posts: 49,859
    edited September 2023
    So many make the mistake of only looking at wpc and a cheap price.
  • apparat
    Well between Outlaw Audio and Emotiva do you have a preference? :neutral: It's great that you comment, but perspective would be of better value, no?
    apparat wrote: »
    The Arendale 1723 ;)
    msg Posts: 9,515
    Viking64 wrote: »
    Kinda want to see this philum now. My brother says you can stream it on Tubi.
  • invalid
    invalid Posts: 1,292
    apparat wrote: »
    I would buy a used parasound amp before any of those two amps.
    F1nut Posts: 49,859
    invalid wrote: »
    apparat wrote: »
    ^This^ Much better sound quality.
    apparat wrote: »
    For reference, I'm a big Carver fan. I've owned both the TFM25 and TFM45. Both had been recapped and all update bulletins done by a tech very versed in the design and trained by the man himself Bob Carver. Loved them! The TFM45 is rated 375wpc and something like over 500wpc at 4ohms.
    My Aragon 8008bb is rated at 200wpc 8ohm and 400wpc @4ohm. It not only spanked the snot out of the Carver TFM45, it also blew out of the water my Adcom 5802 300wpc @8ohms that is also a HIGHLY regarded amp in its own right.
    So as you see it's not necessarily the WPC per say it is the design of the amp and other things you must take into consideration.
    The Aragon is a very articulating amplifier. You pick up the very small nuances of the music the picks on strings the drumsticks on the drums, the fingers on the pianos about everything that you like about music it excels at without fatigue. If I wanted to I could listen to it for hours at a very robust volume, and not feel like I just walked out of a loud rock concert. Now I will say this if it's a bad recording it also lets you hear how badly it is recorded so it can be a double edged sword.
    The Outlaw is the amp I personally would choose over the Emotiva. I personally have never had the Emotiva tickle my fancy so to speak for 2 channel stereo. I have heard them multiple times at the Axpona show in the big theater room and I think that is where they do excel at. Most not all but most home theater speakers and amps do tend to be tilted towards a brighter sound signature which IMHO is not what I like for music as it can get very ear fatiguing after a short while.
    My .02
  • apparat
    invalid wrote: »
    apparat wrote: »
    Yes, but 3x or more the cost.
  • apparat
    invalid wrote: »
    apparat wrote: »
  • apparat
    apparat wrote: »
    My .02
    Thank you for the explanation and perspective!
  • apparat
    Some you will probably laugh at what I run now (speakers) - It's been years since my last upgrade, but Mirage OMDs. To me they sound good, but I figure there advancements since I started running these.
    F1nut Posts: 49,859
    apparat wrote: »
    invalid wrote: »
    apparat wrote: »
    Yes, but 100x or more better sound.
    apparat wrote: »
    They had some very good speakers back in the day.
  • apparat
    apparat wrote: »
    invalid wrote: »
    apparat wrote: »
    No doubt, but at the moment with the speaker investment it will be outside of my budget for the time being.
    nooshinjohn Posts: 25,135
    apparat wrote: »
    apparat wrote: »
    invalid wrote: »
    apparat wrote: »
    What is the budget?
    That investment we completely understand. It certainly is a big out lay in frog skins.
    msg Posts: 9,515
    invalid wrote: »
    apparat wrote: »
    Another +1 on this option if you're open to second-hand gear.
    If you are building a combo-use system and/or music performance is a consideration, you'll be doing yourself a favor to either spring for the better amp now, or hold off and save a bit more until you can.
    If you just want sound, you might be fine with the other options, but if you think you are or will become critical in system performance, you'll be wasting money going lesser up front. I made this mistake. I get it though, it can be way outside original budget expectations when you start learning more or gain exposure to a different level of gear and performance.
    Buy used, save money and get more system. There's good stuff out there - responsible, and meticulous owners.
