Squeezebox Touch Wifi Just... Disappeared
Hi, all.
I've been using an SBT's wifi for about ten years now to access the music library stored on my MacPro's hard drive. Suddenly, today, the music stopped.
I tried a factory reset on the SBT, tried unplugging it, unplugging the wifi router, everything I can think of. When I reboot the SBT I choose a language and then only get an ethernet option. Its as if the unit doesn't even support wifi connectivity.
Is it time to replace the unit? I need something to stream this library to my hifi system. If it's time to replace the SBT, any recommendations on a good contemporary option?
Thanks so very much -
- Isaac Asimov
Hi-Fi
Cabling by Groneberg
Visuals
  • Hermitism
    Hermitism Posts: 4,343
    @msg owns 43 Squeezeboxes. I would consider him a Squeezebox expert.
  • stangman67
    stangman67 Posts: 2,330
    Hermitism wrote: »
    I demand a picture of all 43
  • stretchl
    stretchl Posts: 1,334
    Looking forward to hearing from MSG. In the meantime, I ordered a Wiim Pro Plus. Sounds like an interesting little device. If the UI is as intuitive as the reviews indicate, that in and of itself will be a huge step up from the SBT. What a nightmare that was.
    Any idea how the internal DACs compare? Just based on the passage of time, I'd suspect the Wiim's would be superior to an unmodded SBT, yes?
    - Isaac Asimov
    Hi-Fi
    Visuals
  • Gardenstater
    It seems to me there are some connectivity diagnostics in the SBT menu but my memory needs refreshing. I use the ethernet cable in the hopes of getting better quality. I'll check mine out this weekend if I get a chance.
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • Emlyn
    Emlyn Posts: 4,887
    Mine still work over Wifi. That's the only connection I've ever used. My router has two bandwidth options but I usually stick with the lower option.
    A couple years ago I had to go back to running the Logitech Media Server program from my PC because my Synology NAS stopped supporting it. The PC pulls music data from the NAS though.
    I no longer use either of my Squeezebox units through a separate DAC because I'm only using them with AV receivers. Both are using their analog outputs and sound fine where I have them mostly running FLAC files nowadays.
  • rooftop59
    rooftop59 Posts: 8,120
    @stretchl have you tried rolling back the firmware? I run enhanced audio output (EAC) on all mine, which enables audio out through USB and usb and coax are up to 24/192. But it requires a slightly older firmware than the last one logitech released. Google it and it’s easily accessible.
    Game Room 5.1.4:
    Bedroom 2.1
  • stretchl
    Thanks, Roof. I’ll look into that.
    I did to a factory reset, for what it was worth.
    I didn’t update the firmware myself, though, before the wifi capability disappeared. And don’t know how it would’ve done so automatically, as it was on connected to the Internet, only to my Mac using the Logitech Media Server.
    - Isaac Asimov
    Hi-Fi
    Visuals
  • Gardenstater
    Always helps to give as much info. as possible. What firmware are you running and what version of Logitech Media Server?
    Did the internet company make any changes to your service?
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • rooftop59
    stretchl wrote: »
    Other thing I will say is that even on the used market at say $100-150 a pop, I really don’t think there is anything on the market that can compete with the SBT at that price, especially with EAC and an external power supply. Turning off Wi-Fi and using an an Ethernet connection will improve it a bit more, and an external DAC really ramp things up. I would look for another used one if I were you. They are regularly on the bay.
    Now my Arcam sa30 definitely beats the SBT on sound quality, so now I only use the SBT on the main rig when I want to sync it with the outdoor tunes. But of course the arcam costs significantly more…
    Game Room 5.1.4:
    Bedroom 2.1
    msg Posts: 10,581
    Sorry guys, been a bit tied up this week. My first thought was firmware as well.
    I think LMS automatically pushes out new firmware when LMS is updated. I don't recall whether LMS installs updates by default or only notifies. Mine is set to notify when LMS updates are available, and if I opt to install, or separately download and install, as mentioned, I believe the 43 SBTs get new firmware updates.
    I was meaning to poke around some about this on the slimdevices forum, but haven't had a chance.
    I was just loosely wondering if there might be a duplicate IP on your network causing the SBT to think wifi isn't available, but I've not seen anything to support this causing this sort of behavior. I agree, it does sound like the SBT isn't seeing the wifi hardware.
    I agree with above recs on gathering the LMS and SBT versions.
    Strange issue to start up out of the blue.
  • Gardenstater
    On your SBT screen in the main menu, go to Settings/Advanced/Networking/Choose Network.
    Try Diagnostics and Network Testing as well.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • stretchl
    Firmware on the SBT is 7.7.3-r16676
    LMS version is 7.7.6
    We switched internet providers several weeks ago but this issue just popped up out of the blue yesterday, or at least I first noticed it yesterday.
    If anyone could point me to where I can download the firmware and tell me how to update it (or roll it back) I'd sure appreciate it. I can't make heads or tails out of the links in the various forums.
    Thanks -
    - Isaac Asimov
    Hi-Fi
    Visuals
  • stretchl
    Soooo.... update.
    I tried what @bikezappa wrote about here: https://forum.polkaudio.com/discussion/198079/squeezebox-lms
    And lo and behold it now seems to be working. No idea what I did right, what I did wrong, or otherwise, but I am now listening to the Stop Making Sense Soundtrack, my goal yesterday. (going to the imax reissue tonight!)
    I'm still going to try the Wiim once it arrives tomorrow to see if I can hear any difference and compare the UI on the iPhone to the iPeng app I currently use. Will be interesting.
    I sure appreciate everyone's contribution and I'm sorry for the unsatisfying resolution. Still a great group of folks here, I see. Sorry I don't visit more often these days, but I'm sincerely grateful for the wealth of knowledge and passion for music here.
    - Isaac Asimov
    Hi-Fi
    Visuals
  • Gardenstater
    Gardenstater Posts: 4,862
    edited September 2023
    Mine is on:
    LMS Ver. # 8.0.0 - 1605892076
    Firmware # 7.8.0-r16754
    I haven't updated either because, you know....if it ain't broke don't fix it
    Firmware is updateable through the main menu on the SBT with my setup anyways. I would definitely do this through an ethernet cable which you should try anyways, if you haven't hooked the SBT up directly to your router yet.
    To update LMS go to the LMS Control Panel on your computer and go to Advanced/Software Updates/Install Update
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • Emlyn
    Emlyn Posts: 4,887
    I'm amazed these things still work so well after all these years.
    msg Posts: 10,581
    I am, as well. I'm really glad they do, and especially still with all of the streaming services. I use them daily, and I think this is mainly possible due to the developers leading the support community.
  • stretchl
    @msg Do you really have 43? How do you use them? What can you share about the internal DAC? What external would be a step up from the internal?
    Thanks -
    - Isaac Asimov
    Hi-Fi
    Visuals
    msg Posts: 10,581
    Haha, no I don't really have 43. I think I have 9 or 10. Only 5 are currently set up for use, and typically only 2 or 3 running. The others were for backups, testing convenience or planned systems for others. In one system, I replaced the SBT with a piCorePlayer - a Raspberry Pi based Squeezeplayer.
    I use Orange Squeeze as the controller for Android, and iPeng for iOS. If I'm working on the computer, I have a dedicated, always-open browser window to LMS, with multiple tabs loaded for Home page, Spotty playlists, LMS playlusts, Local music folder store (flac, old mp3s), and the plug-in What Was That Tune for when I'm using streaming services, like the DI.FM stations/channels, or soma fm. The playback history is logged, and with WWTT, I can easily make notes of tracks I like, like new stuff I haven't heard before.
    When I first got started in audio at this level, I found myself putting systems together for more spaces. At first it was just a couple of IOGEAR Bluetooth receivers, which worked pretty well, but then I got my first SBT, which, I think, was $300 new at the time? The SBT changed everything for me.
    The main reason I bought other SBTs after the second one was the discovery that I could sync them for whole house music in all these different little systems I was obsessively cobbling together.
    I find the internal DAC to work nicely, and the SBT also works well with external ones. I don't have any ultra high resolution media, and have found that one of my favorite combinations is the SBT with Schiit DACs. Even the delta-sigma DACs are pretty good, with their multibit ones a bit nicer. I've tried a few other DACs, nothing high end, and just settled on Schiit.
    One of my favorite setups was a SBT with Schiit Modi and Audioengine HD3 speakers and sub for a desktop system. It was the first time I experienced disappearing speakers, and never again since.
    Do you feel like there is something missing, or a sound characteristic you are looking for that has you thinking about going external?
  • stretchl
    Nothing missing sonically, at all, at least nothing that I know of given my tinnitus and high frequency deafness! :(
    I haven't thought about the SBT, other than using it and adding music to the LMS now and again, until the it went all whacky the other day.
    I use it exclusively to stream Apple Lossless files from my (aging) Mac Pro. I've never, in the nearly ten (?) years that I've had it, even bothered to check out the other things it can do. :o
    Maybe this little hiccup will motivate me. :)
    - Isaac Asimov
    Hi-Fi
    Visuals
    msg Posts: 10,581
    Haha, it might!
    Happens to me, as well.
    Like most other owners here, these have been set it and forget it type devices for us all. Most of my use methods were established years ago during the obsessory. Or just some knowledge collected after troubleshooting an upgrade or a host OS issue.
    I do thoroughly enjoy LMS and the SBT. I built most of the collection from previous owners moving to newer platforms. There's a running joke going that I would buy every used SBT listed, and wouldn't stop until I own every SBT on the planet. I missed a few :D
    I'm curious to hear how your Wiim Pro Plus compares. I think someone else recently posted about this streamer. I took a quick look a while back. Looks like a nice option.
  • Gardenstater
    I'm clear as mud as far as what the solution was 🤣but good for you that you fixed it!
    Do you now have different version of firmware and/or LMS? Did you install a patch?
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • stretchl
    I’m a little nervous about updating the LMS. The version I have is stable on my old (2011) Mac Pro. Don’t know if an update would be also.
    But I might try.
    - Isaac Asimov
    Hi-Fi
    Visuals
  • Emlyn
    Emlyn Posts: 4,887
    If everything's working now I wouldn't mess with it at this stage.
    msg Posts: 10,581
    Yeah, unless there's some feature you want from newer versions. I typically try not to update firmware unless I need to. Every once in a while, I'll let it rip with LMS. I have had some issues a few times.
    I wouldn't do it, though, without knowing the "last known good" specifics, and having access to the installers, and/or a system/folder and prefs backup.
    @stretchl, if you don't have a backup set up for your Mac, Carbon Copy Cloner is really good. I think it's only $25. Time Machine works as well, I guess, but I've never used it. IIRC, there were some benefits to CCC that TM doesn't offer.
    With a backup, you could easily revert.
  • stretchl
    Good point, @msg. I have CCC, just haven't backed up in a while. This would be a good time to do it. :)
    Thanks -
    - Isaac Asimov
    Hi-Fi
    Visuals
  • Gardenstater
    stretchl wrote: »
    But I might try.
    OK so you did *not* update LMS and still have the same version.
    Did you update the firmware? Did you install a patch?
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • stretchl
    I followed these instructions re the patch and installed it. Not quite sure if that's what made the difference as I was failing about a bit and not working in a very deliberate or iterative way. (My confession. ;) )
    But it is working now and I'm going to leave well enough alone for the moment. :)
    - Isaac Asimov
    Hi-Fi
    Visuals
  • stretchl
    ps -
    Y'all might also be interested in this, from a reply to one of my troubleshooting posts over at the SlimDevices forum:
    "Also, I would seriously consider replacing the power supply as Ronnie suggested and Anthony attested They are inexpensive. What happens is as they get old, they lose the ability to deliver current, and when the touch demands an increase in current, the voltage can droop. The extent of the droop can be inconsistent, meaning sometimes the unit will work, sometimes not.
    Just thought I would mention that your issue might not be over
    Jim "
    https://forums.slimdevices.com/forum/user-forums/squeezebox-touch/1650154-squeezebox-touch-wifi-just-disappeared
    - Isaac Asimov
    Hi-Fi
    Visuals
    msg Posts: 10,581
    Oh wow, that's interesting. Having had power supplies fail on other equipment before, I ordered a couple of spares for the SBTs from Digikey, or one of those sites, back during the obsessory phase.
    I do have a couple of different upgraded power supplies, but I couldn't say whether they made any difference in my setups. I also do not have any of the SBT internal upgrades. Those were supposed to make a significant difference.
    Anyway, each of the setups that have the better power supplies have all evolved since initially putting them in place, so it might be revealing to swap back to OE for a serious listen.
    Re: consideration for your SBT's power supply - I hadn't considered the possibility of power having an effect on the ability to run Wi-Fi. I wonder if there's anything in the units's logs to indicate failure to power the Wi-Fi adapter, or any other system hints.
    Interesting situation from a worky/troubleshooting perspective. At Nybratw, glad you're back in the music. I know it's silly, but I get a measure of anxiety when something's off with my systems.
    In fact, lol, right now, my Spotty isn't working! It's saying something to do with the API key or something, so I probably just need to reenter stuff. Rarely have any issues. Might just update, like it's beenprompting me to do for weeks... :D
    msg Posts: 10,581
    wha'dya know, just needed to restart LMS service. back in streamy goodness B)
    Did you guys know you can download Squeezeplay and turn your computer into a Squeezebox Player? Available for Windows, OSX, Linux & Solaris, for all you Solaris users out there.
    https://sourceforge.net/projects/lmsclients/files/squeezeplay/
