Hyperclean Auto Detailing supplies, I have a Promo code for you guys.
mantis
mantis Posts: 17,312
Hello everyone,
As some of you know I am now a Hyperclean distributor . Also most of you know I have been testing many different brands over the years I have been in here and when I landed on Hyperclean, I basically put the brakes on trying anything else.
So if you would like to try some of the very best detailing supplies I have ever used , I'm gonna save you 10% off your order with a promo code designed for me.
Promo code is mantis10
If you have any questions about any product you would like to try out, please hit me up or post it on this thread.6nuh8hz6mla0.jpeg
. Here is some of my personal collection.
Dan
  • mantis
    Here is a link to the online store.
    Check it out
    https://hypercleanstore.com/
    Dan
  • bcwsrt
    bcwsrt Posts: 2,362
    Thanks for doing this. I may have to try a few things … once my existing Adam’s supply dwindles.
    Brian
    One-owner Polk Audio RTA 15TL speakers refreshed w/ Sonicap, Vishay/Mills and Cardas components by "pitdogg2," "xschop" billet tweeter plates and BH5 | Stereo REL Acoustics T/5x subwoofers w/ Bassline Blue cables | Rogue Audio Cronus Magnum III integrated tube amp | Technics SL-1210G turntable w/ Ortofon 2M Black LVB 250 MM cart | Teac VRDS-701T CD transport | LampizatOr Baltic 4 tube DAC | Nordost & DH Labs cables/interconnects | APC H15 Power Conditioner | GIK Acoustics room treatments | Degritter RCM
  • mantis
    Kex wrote: »
    What’s better than the promo code, IMHO, is your advice @mantis. It’s priceless.
    How does this work, though, if you’re a distributor? How do we order from you? Is using your code enough for you to get credit for the sale?
    The products, I’m sure, are excellent, but you are the one adding the expert knowledge here to understand how to use them. That is the true magic.
    Thanks for the kind words. To answer your question , just use my promo code mantis10 and I get credit for the sale. If you lived local to me, I could supply you with whatever you needed.
    This is a hobby forum and as you know detailing is one of my hobbies. Sharing tips tricks and technics I enjoy just like audio video related.
    Dan
  • mantis
    bcwsrt wrote: »
    As you might already know, I’m a huge Adams Polishes supporter. They make excellent products. I’ve been using their stuff for many years.
    Dan
    Clipdat Posts: 13,078
    Do they offer a leather conditioner?
  • mantis
    edited June 2023
    Clipdat wrote: »
    No , Not yet.They have leather cleaner, that would be their interior cleaner in Revive.
    Dan
  • mantis
    edited June 2023
    I was messing around with their Waterless/ rinseless wash which is called ECO ONE.
    I currently been using Adam's polishes waterless wash and CS3 for many years.
    These kinds of products are wonderful especially if you have a garage queen like I do. There is no need to break out the pressure washer, car shampoo, wheel and tire cleaners and all that fun stuff when your car is slightly dusty. I don't drive my car that much , weekends I take it out if the weather is good and have some fun. I do local runs and the wife and I will occasionally take it one a overnight stay IF I feel we are going somewhere where I can park it safe and there is no rain in the forecast.
    Anyway Waterless wash products are also great for bird droppings and fresh bugs on the front end mirrors and windshield. It really helps maintain your cars finish and keeps it fresh looking all the time.
    Whats really nice and next level with ECO ONE from Hyperclean is it's more like CS3 from Adam's where it also has protection in it. Silky smooth cleaning and leaves a protective top coat on whatever your current paint protection layer is. I don't know if it's good enough to be a stand alone protection layer, I'm assuming it would last maybe a few weeks stand alone but if you have a garage queen and it doesn't see that much dirt weather or grime, I'm willing to bet it would be a perfect one step solution, which is how I currently am using it. I'm very impressed with this product as I have never found anything better than Adams Polishes CS3 up until now.
    Dan
    msg Posts: 10,450
    Hey Dan, I'd like to start from scratch. I need to strip everything, and probably clay bar.
    Which products would you recommend as a package and process?
  • mantis
    Hello msg,
    So you want to start fresh and get your ride clean and protected. I'm gonna lay down a outline and mention each product to use. You can use this as a guide and asks any questions about any steps if I'm not detailed enough, pun intended LOL.
    WHEELS TIRES AND FENDER WELL
    - You want to clean your wheels, tires and inner fender wells. You will start by using Hyper Clean FUEGO on the Wheels, it's a Iron remover and wheel cleaner. On the tires and inner fender wells you want to use Hyper clean TRX. let the products dwell for about 1 minute before you clean.
    I suggest a 3.5 gallon bucket for your tires brushes like a fender well brush , Wheel woolie , Tire brush and wheel brush or micro fiber wheel mitt or towel.
    - Clean your fender well first, then move to the barrel of the wheel, use a barrel brush to get into there . Once that's cleaned up move to the face of the wheel. Go around each area with your face brush or a lug nut brush.
    - Clean the tire last, you should get a lot of brown dirt out of the tire. Sometimes you might beed to do it twice as if they are left dirty fo a long time, it really gets in there.
    I suggest a Pressure washer, electric lower then 2000 PSI and around 1.2-1.6 gallons per minute. I like around 1200 PSI which works great with the WHITE tip or even the GREEN one .
    FOAM CANNON
    - Your gonna want Hyperclean Cleanse. This is an effective shampoo that really removes dirt grime and the nasties on your paint. I would use 1 ounce per gallon. I suggest a 3.5 gallon separate bucket , A micro fiber mitt you can get one from the Hyper clean store a Grit guard in the bucket to help keep the dirt away from the paint as much as possible.
    - I would first rinse the entire car down before you foam cannon it. You want a foam cannon that works with Electric Pressure washers. 1 ounce or 2 should be plenty of Hyperclean Cleanse in it and fill the rest with Warm water. Cold works but warm foams much better.
    - Foam the entire car and allow to sit for about 2 minutes. This will help remove some loose dirt and really give you great lubrication for your contact wash.
    - Do not rinse off the foam, use it with your bucket wash. After each panel , really rub your mitt on the grit guard in your bucket to try and remove as much dirt as possible from the mitt. You can also squeeze it out after each panel to remove more dirt before you dunk it into the bucket.
    - Once the entire car is washed , do a really good rinse.
    CLAY BAR
    - Hyperclean makes Synthetic Clay mitt , Your going to use the wash bucket you just used to wash the car. If the water is killed dirty, make a new bucket. Rinse it out and make it the same way you did with the wash step. Your gonna clay with the car wet , each panel using a lot of soapy water. Use the wash mitt to re wash each panel one at a time and clay it. Be gentle as you don't want to mar the paint. Gental strokes and keep lubed.
    - Once each panel is finished , rinse again.
    DECON
    - You want to use your Wheel cleaner from Hyperclean Fuego to remove IRON deposits if there is any. This is a chemical decon step that is the final step to have fully clean paint. You want to spray your car down with Hyperclean Feugo panel by panel and allow it to turn purple. This will happen within the first minute or 2. Don't wait any longer then 3 minutes. If it's clear , just rinse off and your good. If it turns purple , rinse off and if you want you can do a quick fast finial hand wash with the soapy water from the Clay step. You don't need to go crazy here but this is how I do a full strip.
    DRY THE CAR
    - Hyperclean has beautiful drying towels, they have an array of awesome micro fiber towels. You want a Hyperclean ORANGE CRUSH towel or 2 depending on if your drying a car or large truck.
    PROTECTION STEP
    - You have a few options here. You can simply use a cool new technology called SPRAY COAT. Hyperclean Spray coat is a spray on rinse off and dry paint sealant that you will get around 1-3 months of protection. It's crazy technology to spray a few sprays on each panel and then rinse it off with the pressure washer. You will see your car bead up just like if you waxed it. It's awesome.
    - Another option is Hyperclean SLIQ. This is a crazy good Slica Spray sealant. While your car is wet, you can use it as a drying agent. This also adds a layer of protection. Lasts about the same a Spray Coat. It's really nice a few sprays per panel and dry off and your protected. You can use it after the car is dry as well for a deeper stronger coat. Same amount, a few sprays per panel and wipe off. No curing time just like if you where doing windows, just spray on ad wipe off. I suggest for the dry coat use Anchor or Big Bird towels. You will need a few of them to complete the job.
    - Last and best would be a Hyperclean UNO ceramic coating. I think you should fully paint correct your paint before laying a coating down BUT UNO is a 1 year coating that you can put on your cars paint even if you decide not to paint correct. It's like wax on steroids. It's an actual coating you can do yourself. I strongly suggest not applying in the sun, please do it in the shade and follow my instructions or we can have a phone conversation IF you decide to do this step. It's not hard but if you never put a coating on before, this is the perfect coating to do. it's about as hard as a paste wax to apply.
    - You want to use Hyperclean's Ceramic coating applicator's. Buy a pack of leveling towels as well and have a few Big Birds for the final wipe
    - You MUST work in small areas no more than a small panel at a time. You apply the coating evenly using a few drops per panel and use THE BOX method. I suggest watching a few YouTube videos before you do this. I can coach you though it but it's easier to get my points across on a phone.
    - You allow one panel at a time to cure which it will turn into a light oil slick. Once this happenes which is around a few minutes, you use a leveling towel softly to evenly remove the oil slick. Once that's off, yo use a big bird towel for your final finish.
    - Repeat this panel by panel around the car , take you time and you will have an incredible durable real ceramic 1 year coating on your car that willl shine line no other and make future washing easy.
    When your ready for this you can PM me and we can have a phone conversation before you spend any money on anything. I would like to know what you where using before so I can set expectations with Hyperclean's products. They are truly world class products and my personal favorite. They are next level stuff and I'm so happy I found them.
    Dan
  • mantis
    Just as a side note, Cleanse is NOT a maintenance car Shampoo, it's not designed to be used after a protection step in the future. It will strip away wax and spray protections.
    What you would want to use is Ceramic Snow or Foam wash. Foam wash is a PH neutral car Shampoo that will not remove your protection. Ceramic Snow will add a layer of protection on top of whatever you decide to use as protection. This would be your first maintenance wash at least 2 weeks after.
    I can build a full maintenance wash Process and product once anyone is ready for that.
    Dan
    msg Posts: 10,450
    Damn, Dan, this is friggin' awesome, thanks! Seriously old skool here with modern car care tech. I can fix just about anything mechanical, have built several engines, and even not too bad at some electrical, but paint, bodywork, and modern care tech? Forget it! Lol
    This gives me a good baseline man, thank you very much for taking the time to detail this out for me! I'm going to copy to Evernote and turn it into a checklist and materials order after solid review.
    I'll give you a shout with any questions before ordering.
  • mantis
    Glad to help my friend.
    Dan
  • vmaxer
    vmaxer Posts: 5,120
    What’s the best way to remove tree sap?
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
    gudnoyez Posts: 8,156
    Hmmm going to have to try the Bug removal products. Living in the Upper Midwest and taking a country ride is fun this time of year but the bugs on the front bumper are almost impossible to remove.
    I got one more free detailing on the new ride until the end of this month, and I will hate the thought of a country road cruise after it's been detailed. How long is the code good for.
  • mantis
    vmaxer wrote: »
    tree sap can be a ****, you can use Fuego as a presoak and pressure wash off. If any remains, you can use ECO ONE with a clay bar. Sap sucks and very hard to remove without damage to the paint. But taking steps can help remove it safely as possible.
    Dan
  • mantis
    gudnoyez wrote: »
    It's my code so feel free to use it all you want. mantis10
    Bug remover from Hyperclean is awesome. Your really gonna like how good it is. Try it out in the 16 ounce first and if you really like it grab a gallon, you'll have it for a long time unless you get mad bugs all spring summer and fall long LOL.
    Dan
    edited July 2023
    Just ordered some stuff but not sure if the promo code worked, at least it didnt show on the e-mail receipt I got.
    Think maybe the auto fill on this stupid phone made a capital M on mantis if I give you my order # can you apply it so you get credit for the sale and I get my discount?
  • mantis
    gudnoyez wrote: »
    Yes pm me your order number , the promo code is mantis10 , unless it's possible to cancel your order and reorder with the proper code, this will give you the discount.
    Dan
    Dan just sent PM
    Got an e-mail recieving my discount even after I entered it wrong thanks Dan thanks Hyperclean.
    I usually used meguiars stuff, but going to switch it up this time.
  • mantis
    gudnoyez wrote: »
    They are an exceptional company and why I like dealing with them. It's not just their products are top notch, the company is also top notch.
    Glad you got your discount.
    Dan
    edited July 2023
    Just got my first order today impressed with the fast delivery and the way it was packaged. I looked at a lot of reviews on the Hyperclean brand all good just made a second order, going to treat my Truck to more than just the usual.cleaning I give it.
  • mantis
    gudnoyez wrote: »
    I'm really glad to be able to offer a nice discount on in my opinion some of the very best products on the market.
    I'm pretty stocked up at the house
    Dan
