L800 - Single Ended Amp
  • tjcinnamon
    tjcinnamon Posts: 100
    Is it pretty unanimous that the group thinks an Anthem MCA or P series would not reduce the SDA effect?
    F1nut Posts: 49,832
    tjcinnamon wrote: »
    It would be best to contact Anthem to enquire about the topology of their amps.
  • tjcinnamon
    tjcinnamon wrote: »
    I emailed them yesterday and I’m hoping they get back to me. I saw an article about the P2 from 2012 talking about how it was single ended. I’m being extra cautious because I don’t want some vendor to eat the cost of me returning something.
    F1nut Posts: 49,832
    The P2 has single ended and balanced output options.
    F1nut Posts: 49,832
    jaspritvid wrote: »
    The higher end Marantz use hypex so may not be best match but i believe the higher Denon's should be good
    Pure nonsense.
    F1nut Posts: 49,832
    You will need to find out what the topology is. If it is dual differential you cannot use them with the L800.
    txcoastal1 Posts: 13,134
  • TelephoneAudio
    txcoastal1 wrote: »
    That’s input
    The L800 are effected by the speaker amp output
    I’ve put a ticket in with Hypex on this
    F1nut Posts: 49,832
    Chances are if the input is balanced differential, so is the output making the amp incompatible with the L800.
    Out of curiosity please respond as I also found this statement
    Hypex Ncore
    Along with the new level of Class D audio performance, ... input signals floating for a true balanced differential input, utilizing the Hypex Ncore NC1200.
  • TelephoneAudio
    I’m guessing you’re right. Waiting on Hypex for the true true word on this
  • TelephoneAudio
    George from Deer Creek Audio - where I bought Nilai 500 monoblocks has confirmed these ARE compatible with Polk L800! Woot
    - “The Nilai 500 Monoblocks are not bridged internally. They will easily handle your Polk L800 speakers”
    IMHO I would still wait for a response from Hypex
    Many don't understand the topology of the L800. Although they are SDA they are not the same of SDA of the past.
    The amps will not blow up the speakers they just won't always sound correct. I have experienced the L800's and when the amp is wrong the stereo image floats as much as 10' in the room. Sounds crazy.
    F1nut Posts: 49,832
    It's entirely possible to have balanced dual differential inputs and outputs in an amp that is internally single-ended. With the L800 it's the dual differential topology that is the issue.
    nooshinjohn Posts: 25,116
    I would get that in writing before I would connect them to my Polks…
  • TelephoneAudio
    Hypex Sales and Support both confirmed Nilai 500 monoblocks are compatible with L800 via email
  • TelephoneAudio
    Hypex support confirmed the Nilai 500 monoblock is a single ended amplifier.
    I.e. the amp Does-Not have a differential output
    F1nut Posts: 49,832
    You're good to go then.
  • TelephoneAudio
    Yup and shared elsewhere in case others have this niche idea / combo
    Keep us update, we look forward to hearing your results
