Isoacoustics
mantis
mantis Posts: 17,517
Hello everyone,
As one of the training courses we had a World wide yesterday was Isoacoustics. The GAIA isolation feet for speakers are very impressive. The built quality was top notch. I plan on picking up a set.
They also have other products that I want to explore. I have not been down this path since I left Audiolab back in 2013 so getting back into 2 channel things is fun.
Anyone use any of their products? I'm strongly considering their Subwoofer platforms as well for both of my subs.
Dan
  • Emlyn
    Emlyn Posts: 4,751
    I use Gaia isolation feet on all of my speakers except Magnepans and find them to make a profound difference from bass through midrange. Everything's better defined and punchy. I have tried their isolation feet for electronic components but haven't noticed any significant difference with those yet. Most likely because my two channel gear is already well isolated from vibrations.
  • jbreezy5
    jbreezy5 Posts: 1,141
    Interested to hear more about your experiences with the Gaia feet.
    I had massive vibration problems occurring with my SVS Pro 1000 sub. During big bass passages it was physically bouncing when I used the supplied feet intended to protect hardwood floors, rather than supplied spikes.
    I purchased Pangea Sorbothane feet, and they completely eliminated the unwanted vibrations for $$. These include clear plastic discs to put under the feet to prevent discoloration of the floor.
    Pico feet are for smaller/lightweight gear, and there are “Mega Large” sorbothane feet for similar cost.
    Just an FYI in case the Iso Acoustics sub platform costs more.
  • mantis
    Has anyone tried out the SVS isolation feet? They are much cheaper only $49 vs $199 for the GAIA models. I'm wondering how much of a difference each foot would make vs each other on a subwoofer and a Speaker?
    This is something I'd like to test out.
    Dan
  • jbreezy5
    This convo is opening a can of worms for me.
    Aren’t there several different Iso Acoustics feet for speakers? Or is that equipment?
    @mantis / emlyn - can you clarify this?
    VR3 Posts: 29,456
    I tried the giaa and quickly returned them.
    They dramatically change the sound, whether or not you like it is of course personal preference
  • Milito
    Milito Posts: 2,003
    I tried the SVS feet when I had a HSU sub, they helped with vibration and the bass seemed clearer to me. Well worth the cost.
  • Gardenstater
    Gardenstater Posts: 4,785
    edited April 2023
    Looking at Isoacoustic's tech info. it seems clear that they are mostly dampening devices and have a fairly high resonant frequency (around 270 Hz?) which would tend to alter the sound by emphasizing some frequencies. This wouldn't occur if the resonant frequency was below the audio band (like around 2 Hz or so) which is what Towshend Audio does. Oh and also the Bungee Cords they used were clearly way too stiff as well.
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • Emlyn
    Emlyn Posts: 4,751
    I would stick with the add on SVS feet if the subwoofer sits in a hard surface. They do all that’s needed with a subwoofer. On carpeted floors may be a different story.
  • Emlyn
    Emlyn Posts: 4,751
    Gaia models are designed to match with speakers in different weight ranges. If a speaker is outside the weight range it will crush the isolation/control material rendering it useless. Box speakers tend to be front heavy because of the driver location and front baffle being thicker but I think the feet are designed to accommodate that. Size up if the speaker is near the upper limit on weight. For example L800s require Gaia I rather than Gaia II.
  • mantis
    VR3 wrote: »
    I gotta assume you where use to the way your system sounded and didn't like the change. They isolate the speaker, tighten up the bass and clear up the mid range. Plus with the added height , it gives the Tweeter more room to breath.
    Dan
  • mantis
    Milito wrote: »
    I thought so, they are 1/4 the price of the ISO stuff.
    Dan
  • mantis
    Emlyn wrote: »
    For $50I'm gonna give them a go.
    Dan
  • mantis
    Emlyn wrote: »
    They talked about that in the class. If you go to their website, they have a Tool to help you select the correct feet for your speakers. Pretty cool
    Dan
  • Emlyn
    Emlyn Posts: 4,751
    edited April 2023
    I wouldn’t run an SVS sub on a wood floor without the add on feet. They help stick the subwoofers in place and keep the energy in driver movement rather than in the cabinet.
    FWIW, Isoacoustics makes a line of three models above the Gaia for speakers above 180 lbs or so a piece called Titan. Same concept and design. All of them lift speakers 1 to 3 inches higher than stock feet which can affect ear height to tweeters a bit. I have noticed a handful of high end speaker manufacturers have started including the concept in their speakers.
  • pearsall001
    pearsall001 Posts: 5,306
    Check out Aurelex Subdude isolation platforms. Thet have a few models depending on the application.
    EndersShadow Posts: 17,709
    I believe @marvda1 uses their stuff
  • DaveHo
    DaveHo Posts: 3,582
    I've tried the SVS feet. Actually, they came attached to an sb12 I bought used. On carpet, I felt they limited the sub. All tactile slam was lost. Spikes were much better. I suspect hard floors would be a different story.
  • Gardenstater
    edited April 2023
    Emlyn wrote: »
    This is what they look like on the inside (from the patent). A pair of elastomeric dish shaped cushions connected together. Would have springiness and damping characteristics. These things are like $200, $296, $496 per set of 4 for the III, II, and I.
    Post edited by Gardenstater on
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • jdjohn
    jdjohn Posts: 3,366
    I found the SVS SoundPath Isolation feet to be very beneficial and cost-effective for my SVS sub. They tuned and tightened the bass in a positive way for me. My speakers are on a hardwood floor FWIW.
    Regarding IsoAcoustics products, I've had good results with their ISO-Stands, although I think the Aperta series is the newest version of those types of stands. I've used the ISO-Stands for Polk Monitor 10, as well as other speakers. The speakers need to be properly placed/balanced on the stands, especially if tilted backwards a bit, but the stands can actually support fairly large/heavy speakers. The stands provide excellent...wait for it...isolation :)
  • Milito
    Milito Posts: 2,003
    Mine were used on wood floors.
  • mantis
    DaveHo wrote: »
    I have a feeling you where not use to isolation. I think it's like a full calibration, most people feel they don't have enough bass when they where listening with way to much bass. A calibration like isolation should give you a more natural sound. It did in the demo I had with the Isoacoustics feet on the Focal's.
    Dan
  • jbreezy5
    Emlyn wrote: »
    Pricey feet. Whew!
