SRT control center question
The control center of my SRT system will no longer go to wide mode. When I push the button, it clicks back to normal mode. Before I dig it out, is there an internal fuse or something that could be the culprit?
  • JayCee
    JayCee Posts: 1,509
    NormM wrote: »
    @ESavinon might be able to assist.
    Speakers: Polk1.2tl's (Uber Mods) Pre/Amp/DAC: PS Audio BHK Signature & 250, DirectStream Cables/IC's: MIT S1Bi-Wire/S1 Balanced +Avel Lindberg 1000VA "Dreadnought" Power Conditioner: PS Audio P15 Power Plant Power Cords: Core Power Technologies Gold, DH Labs Power Plus DIY w/Neotech NC-P301 & P311ends Streaming: Roon ROCK on wifi'd NUC, TP-Link WAP, & Uptone EtherREGEN, AfterDark, Emperor Double Crown Clock, Black Modernize LPS, PS Audio AirLens⟿Ω☯☥☮⟿🔊♩♪♫♬♩♪♫♬♩♪♫♬
  • ESavinon
    ESavinon Posts: 3,067
    Unfortunately, no.
    Once the SRT SDA control module goes bad, there is no way of repairing this.
    The SDA control feature is controlled by a dedicated IC which is custom made for this controller.
    None are available. Try to get a replacement SRT controller on Ebay.
    Ed
    SRT For Life; SDA Forever!
    The SRT SEISMIC System:
    Four main satellite speakers, six powered subs, two dedicated for LFE channel, two center speakers for over/under screen placement and three Control Centers. Amaze your friends, terrorize your neighbors, seize the audio bragging rights for your state. Go ahead, buy it; you only go around once.
    F1nut Posts: 51,763
    Hi Ed
  • NormM
    NormM Posts: 10
    Thank you for the responses. Its not what I was hoping to hear but sometimes the truth hurts
  • mantis
    mantis Posts: 17,378
    It's really old technology , I would actually be surprised if Polk could fix it themsleves. Hopefully you can find one or 2 of them around Ebay
    Dan
  • NormM
    NormM Posts: 10
    I checked Ebay and didn't find one but it leads me to a question. If I just throw a jumper wire on the speaker binding posts, will it allow me to use the full array, although I'll lose the phase deal? I'm just thinking out loud, but don't want to damage them either.
    pitdogg2 Posts: 27,045
    NormM wrote: »
    Put a search up on eBay to notify you. They pop up from time to time.
  • ESavinon
    Hi Ed
    Hi Jesse!
  • ESavinon
    mantis wrote: »
    Polk is not able to fix it. I had that same issue. I solved it by buying the last new SRT controller they had.
  • ESavinon
    NormM wrote: »
    NO Jumpers! You can damage the crossovers.
  • ESavinon
    edited April 2023
    Put a search on Hifi Shark. You'll find one eventually.
  • NormM
    NormM Posts: 10
    Thanks again everyone. I bought these new and hate to think of them as boat anchors without the controller. Now that I know the controllers are irreparable, I will look for a replacement controller
  • SeleniumFalcon
    SeleniumFalcon Posts: 4,307
    I checked with the engineer who worked on the SRT controller and asked him if there were any parts used that were unobtainable and he said not. There's nothing preventing one from being repaired.
    Will Polk repair them?
    txcoastal1 Posts: 13,512
    The issue is if the problem is chip related, their would be no way of repairing/replacing that chip.
  • ESavinon
    NormM wrote: »
    They're far from being "boat anchors".
    The SRT controllers serve 3 functions.
    1. Crossover.
    2. SDA controller.
    3. Transformer for monoblock amplifier compatibility.
    Ed.
  • ESavinon
    txcoastal1 wrote: »
    I spoke to the man himself (Matt Polk) about my issue with the SRT controller and he said they did not have any extra IC controllers at hq at that time. My only recourse was to buy a new controller. I ended up buying their last remaining controller.
    Ed.
  • ESavinon
    I still have that controller with the dead SDA chip. If you find a way of getting it repaired, I will certainly have mine repaired as well.
    Ed.
  • SeleniumFalcon
    In general terms the only situation where a piece of electronics is not capable of being repaired would be if it used erasable programmable read-only memory (EPROM) integrated circuits. And even in that case there are dedicated enthusiasts who even figure out how to repeat the memory circuit and build new ones. The Revox A700, for example, has such a determined following that they can now be completely repaired. The SRT controller doesn't contain anything out of the ordinary, routine power supply, common integrated circuits and transistors. Granted if the AC transformer was shorted out or the isolation transformer were kaput then it would be a pain to repair, not impossible, but challenging. Polk is now searching for the schematic drawings.
    No, Polk is not able to offer service.
    SCompRacer Posts: 9,112
    edited April 2023
    Ed, IF you could get a replacement chip, you can use my hot air rework station. :)
  • SeleniumFalcon
    I now have the schematic drawings, there's a boatload of ICs, but none of them seem to be difficult to find. If anybody needs them I'd be happy to send.
    Toolfan66 Posts: 18,054
    WOW!!!! That is super cool, and a game changer it seems..
  • SeleniumFalcon
    If someone has a broken controller and wants to send it to me, I'll be happy to explore its innards and see if I can figure it out. Can't never tell, I might get lucky.
  • SeleniumFalcon
    edited April 2023
    "The control center of my SRT system will no longer go to wide mode
    This seems to be controlled by a relay, RL1. It could be a defective relay, or a problem with the voltage that activates it. Or, the push button that triggers the voltage, that engages the relay. Fairly easy to test.
    heiney9 Posts: 25,432
    Ken is the best. So glad you continue to hang around here even though you've been retired for awhile now.
  • NormM
    NormM Posts: 10
    I am a neophyte when it comes to this
    Norm
  • SeleniumFalcon
    If you have a general audio repair shop where you live you might be able to bring the controller to them. I'd be happy to send them the schematics, they should be very able to check the relay and see why it's not engaging. All in all a fairly simple thing to look into.
  • daddyjt
    daddyjt Posts: 3,079
    I have seen many relays fail at the ~30 year mark, especially if they are handling speaker level voltages. The contacts become oxidized and corroded, and eventually fail to contact and pass signal. Many that are in the process of failing will engage as the voltage increases, but this is a sure sign that it is well on its way to failure.
    ― Aleksandr Solzhenitsyn
  • Hi all,
    I’m new to the forum, and apologize in advance for reviving this nearly 2 year old thread, but it seemed like the most appropriate place for this question.
    I have a new-to-me SRT system, and the SDA control center is causing the subwoofer drivers to emit 60hz hum. Tested it with my processor direct to the sub, and no hum. I want to open up the Control Center and see if I can find the problem.
    As such, I’d like to respectfully request a copy of the schematic from @SeleniumFalcon or anyone who received a copy of the schematic from this thread. Thanks in advance for any help!
    (Also, while I welcome any troubleshooting ideas or assistance, please know I’ve already tried swapping RCA cables, switching power outlets, and making sure the processor, sub amps and SDA control center are on the same circuit)
    Thank you!
    F1nut Posts: 51,763
    edited January 2025
    Welcome to Club Polk. Sorry, I can't help with the issue.
    You might try reaching out to the SRT King, ESavinon.
