SRT control center question
NormM
The control center of my SRT system will no longer go to wide mode. When I push the button, it clicks back to normal mode. Before I dig it out, is there an internal fuse or something that could be the culprit?
@ESavinon might be able to assist.➀Speakers: Polk1.2tl's (Uber Mods) ➁Pre/Amp/DAC: PS Audio BHK Signature & 250, DirectStream ➂Cables/IC's: MIT S1Bi-Wire/S1 Balanced +Avel Lindberg 1000VA "Dreadnought" ➃Power Conditioner: PS Audio P15 Power Plant ➄Power Cords: Core Power Technologies Gold, DH Labs Power Plus DIY w/Neotech NC-P301 & P311ends ➅Streaming: Roon ROCK on wifi'd NUC, TP-Link WAP, & Uptone EtherREGEN, AfterDark, Emperor Double Crown Clock, Black Modernize LPS, PS Audio AirLens⟿Ω☯☥☮⟿🔊♩♪♫♬♩♪♫♬♩♪♫♬ -
Unfortunately, no.
Once the SRT SDA control module goes bad, there is no way of repairing this.
The SDA control feature is controlled by a dedicated IC which is custom made for this controller.
None are available. Try to get a replacement SRT controller on Ebay.
EdSRT For Life; SDA Forever!
The SRT SEISMIC System:
Four main satellite speakers, six powered subs, two dedicated for LFE channel, two center speakers for over/under screen placement and three Control Centers. Amaze your friends, terrorize your neighbors, seize the audio bragging rights for your state. Go ahead, buy it; you only go around once. -
Hi EdPolitical Correctness'.........defined
President of Club Polk -
Thank you for the responses. Its not what I was hoping to hear but sometimes the truth hurts
It's really old technology , I would actually be surprised if Polk could fix it themsleves. Hopefully you can find one or 2 of them around EbayDan
I checked Ebay and didn't find one but it leads me to a question. If I just throw a jumper wire on the speaker binding posts, will it allow me to use the full array, although I'll lose the phase deal? I'm just thinking out loud, but don't want to damage them either.
Put a search up on eBay to notify you. They pop up from time to time. -
Polk is not able to fix it. I had that same issue. I solved it by buying the last new SRT controller they had.
NO Jumpers! You can damage the crossovers.SRT For Life; SDA Forever!
Put a search on Hifi Shark. You'll find one eventually.SRT For Life; SDA Forever!
Thanks again everyone. I bought these new and hate to think of them as boat anchors without the controller. Now that I know the controllers are irreparable, I will look for a replacement controller
I checked with the engineer who worked on the SRT controller and asked him if there were any parts used that were unobtainable and he said not. There's nothing preventing one from being repaired.
SeleniumFalcon wrote: »I checked with the engineer who worked on the SRT controller and asked him if there were any parts used that were unobtainable and he said not. There's nothing preventing one from being repaired.
Will Polk repair them? -
The issue is if the problem is chip related, their would be no way of repairing/replacing that chip.2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
They're far from being "boat anchors".
The SRT controllers serve 3 functions.
1. Crossover.
2. SDA controller.
3. Transformer for monoblock amplifier compatibility.
Ed.SRT For Life; SDA Forever!
txcoastal1 wrote: »The issue is if the problem is chip related, their would be no way of repairing/replacing that chip.
I spoke to the man himself (Matt Polk) about my issue with the SRT controller and he said they did not have any extra IC controllers at hq at that time. My only recourse was to buy a new controller. I ended up buying their last remaining controller.
I still have that controller with the dead SDA chip. If you find a way of getting it repaired, I will certainly have mine repaired as well.
In general terms the only situation where a piece of electronics is not capable of being repaired would be if it used erasable programmable read-only memory (EPROM) integrated circuits. And even in that case there are dedicated enthusiasts who even figure out how to repeat the memory circuit and build new ones. The Revox A700, for example, has such a determined following that they can now be completely repaired. The SRT controller doesn't contain anything out of the ordinary, routine power supply, common integrated circuits and transistors. Granted if the AC transformer was shorted out or the isolation transformer were kaput then it would be a pain to repair, not impossible, but challenging. Polk is now searching for the schematic drawings.
No, Polk is not able to offer service. -
Ed, IF you could get a replacement chip, you can use my hot air rework station.Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 *
I now have the schematic drawings, there's a boatload of ICs, but none of them seem to be difficult to find. If anybody needs them I'd be happy to send.
WOW!!!! That is super cool, and a game changer it seems..
If someone has a broken controller and wants to send it to me, I'll be happy to explore its innards and see if I can figure it out. Can't never tell, I might get lucky.
"The control center of my SRT system will no longer go to wide mode
This seems to be controlled by a relay, RL1. It could be a defective relay, or a problem with the voltage that activates it. Or, the push button that triggers the voltage, that engages the relay. Fairly easy to test.
Ken is the best. So glad you continue to hang around here even though you've been retired for awhile now.
H9"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Pangea AC14SE MKII | Legend L600 | BlueSound Node 3 - Tubes add soul! -
SeleniumFalcon wrote: »"The control center of my SRT system will no longer go to wide mode
I am a neophyte when it comes to this
Norm -
If you have a general audio repair shop where you live you might be able to bring the controller to them. I'd be happy to send them the schematics, they should be very able to check the relay and see why it's not engaging. All in all a fairly simple thing to look into.
I have seen many relays fail at the ~30 year mark, especially if they are handling speaker level voltages. The contacts become oxidized and corroded, and eventually fail to contact and pass signal. Many that are in the process of failing will engage as the voltage increases, but this is a sure sign that it is well on its way to failure."Conservative Libertarians love the country, progressive leftists love the government." - Andrew Wilkow
― Aleksandr Solzhenitsyn
