Billet RD-0194/8 Tweeter Bezels
245
    xschop Posts: 5,427
    Just PM how many.
    Shipping is
    $12/ pair
    $15/ 4ea or more
  • ESavinon
    ESavinon Posts: 3,067
    edited April 2023
    I'm going to need at least 16. (SDA 1.2TL, 3.1TL,1C, CRS+, RTA 15tl) I have to check on other pairs of speakers.
    Ed.
    Post edited by ESavinon on
    SRT For Life; SDA Forever!
    The SRT SEISMIC System:
    Four main satellite speakers, six powered subs, two dedicated for LFE channel, two center speakers for over/under screen placement and three Control Centers. Amaze your friends, terrorize your neighbors, seize the audio bragging rights for your state. Go ahead, buy it; you only go around once.
    xschop Posts: 5,427
    edited April 2023
    ESavinon wrote: »
    Ed.
    Got you down.
    Have a question for you. Besides a larger sound stage presence of 3.1's, do you feel that the 15TLs have the same overall dynamics as the 3.1TL's?
  • ESavinon
    xschop wrote: »
    ESavinon wrote: »
    Ed.
    Got you down.
    I have not made any direct comparisons since they're 2 completely different designs.
    The RTA 15tl based on their D'appolito design would have more dynamic range in my opinion.
    Ed
    xschop Posts: 5,427
    Final call for the year on these.
    msg Posts: 10,479
    Thanks for doing these, Rob. Bit the billet, too. Seems like a great addition to the standard upgrade paths.
    @F1nut - beautiful result with the anodizing. Takes these plates to another level. Could one send an order of plates to your anodizer? What color is that? Hopefully has some pretentiously audiophile-y name, and not just "Dark Grey", which would likely not impart any comparatively improved sonic quality, unlike the guarantee of the former.
    F1nut Posts: 52,032
    Scott, sure anyone could send their plates to the place that did mine. It's the standard black anodizing, but I used a technique invented by another member to remove the tooling marks, which results in the silky smooth appearance.
    F1nut Posts: 52,032
    With flash.
    Without flash.
    Toolfan66 Posts: 18,207
    Maybe when Rob gets these done we can get that tool making it’s rounds so the members that would like to can do the same before they send them off to being anodized.
    I can supply the scotchbrite pads..
    xschop Posts: 5,427
    I ordered an extra 10 plates to machine, including mine. If a set of 1.2's land on this homestead, no promises made. :)
    pitdogg2 Posts: 27,376
    Well I'm waiting for @dromunds to get it to me so I can get @bcwsrt's done and send his and mine up to Chicago to get anodizing done.
    xschop Posts: 5,427
    I told @dromunds to send it to you and ask @Toolfan66 how to use it.
  • dromunds
    dromunds Posts: 10,145
    Soon come. Sent a PM to Toolfan, as soon as I get a reply I’ll be sending ‘er along.
    F1nut Posts: 52,032
    dromunds wrote: »
    I sent you a video. I found that using the Scotch-Brite Type A Very Fine pad was all that was needed. In other words, no need to use the course pad first.
    xschop Posts: 5,427
    I polished one to a near-mirror finish before. Think I used 600 grit sponge pad by hand, then black rouge on buffing wheel.
    Rob,
    I may need two if you have any spares. I may be buying some RTA11T's still up in the air the guy thinks they are worth gold. If we can come to terms....mine, I'll need two please.
    msg Posts: 10,479
    I like the 11Ts.
    msg wrote: »
    I like the 11Ts.
    I'll make them 11tl's.
    xschop Posts: 5,427
    I can make them XS-11TL's ;)
    Got you down for a set.
    I'm still wondering why Polk didn't switch the MWs to 6516's in the 11TLs like they did for the 8TLs.
    edited April 2023
    xschop wrote: »
    Hard pass....
    xschop wrote: »
    Dude I'm betting they knew a thing or two..... Like cabinet volume or port vs passive.....you know small inconsequential things like that...
    Thank you for having me down.
    xschop Posts: 5,427
    I agree, must be bass-related. Out of the box the 6516's produce a better midrange than 6510's.
  • dromunds
    It should arrive to Ivan tomorrow via express.
  • bcwsrt
    bcwsrt Posts: 2,530
    Thanks to both @dromunds and @pitdogg2!
    Brian
    xschop Posts: 5,427
    Started work on these. I now have only 8 plates available.
    xschop Posts: 5,427
    edited July 2023
    Sorry for the delay on these. I've PM'ed everyone that has chimed in for this batch.
    If I haven't replied, let me know
    xschop Posts: 5,427
    I used the same diamond insert on this batch as I did for the seismic ball isolators.
    Very close to mirror finish...
  • Nesmith98
    Nesmith98 Posts: 224
    Nice work. Have you ever thought about machining the "Polk Audio" lettering on these?
    Nesmith98 wrote: »
    Off the top of my head there may be a copyright problem with that.
    xschop Posts: 5,427
    edited July 2023
    ^^^Bingo^^^
    What @VR3 did with his lazer etching for the Monoliths build was the epitome of badging IMO.
