3801 remote codes???
juice21
juice21 Posts: 1,866
edited May 2002 in Electronics
my manual doesn't seem to have the remote codes to enable my denon remote to control my other components, can anyone out there with a denon help me out??? either post back or email me direct, i will let you know what i need more specifically. thanks!
Post edited by juice21 on
  • jcaut
    jcaut Posts: 1,849
    edited May 2002
    I think I can help. I have a seperate sheet that lists the remote codes. You can let me know what you need, or I'll scan the whole thing and e-mail it to you.
    Jason
  • jcaut
    jcaut Posts: 1,849
    edited May 2002
    Well, I can't figure out any way to attach files, if I e-mail you via the "e-mail" function of this forum.
  • jcaut
    jcaut Posts: 1,849
    edited May 2002
  • juice21
    edited May 2002
  • jcaut
    jcaut Posts: 1,849
    edited May 2002
    I sent it to you. Hope that helps!
    Jason
  • juice21
    edited May 2002
    thanks man! i appreciate it...
  • mantis
    mantis Posts: 17,629
    edited May 2002
    Hey Juice,
    good luck with that remote.I haven't used mine since I owned it.I tried it out the first night I got it and then right back in the box it went..........enter the Pronto.........the truely affortable universal remote control.
    I built a killer avr3801 setup on it, if you get a pronto I will e-mail you my Pronto file,It will come with all Ir intact...........2nd zone as well.
    I was going to use it in my bedroom(the Denon remote)but is very limited(as Most are)as what you can do with it.
    Dan
  • juice21
    edited May 2002
    yeah, i've been playing with it the last couple of nights, and ugghhh... i am not liking it. i do have an AV Producer 8 that i will probably continue to use, just alot of 'learning' to program on the remote. thanks for the offer on the pronto file. if i get one, i'll definitely be letting you know...
  • jeberhart
    jeberhart Posts: 69
    edited May 2002
    Once again, I'm with Mantis. I had a lot of objections to the 3801 remote, so I got a used Sony universal -- don't have it in front of me, so don't know model, but it's a great big old wide, silvery, ugly-looking cuss. Who cares, though? It works great.
  • goingganzo
    goingganzo Posts: 2,793
    edited May 2002
    i have the hk tc 1000 very sweet remote
  • juice21
    edited May 2002
    well, i gave the 3801 remote it's last attempt last nite, and it failed miserably against the av producer 8. looks like it's 'the drawer' for the 3801 remote...
  • mantis
    edited May 2002
    mines been in a box along with all the other remotes.
    to me there is only one remote...........pronto.
    Dan
