Phase Plug design for MW65xx
Be patient, I've got more modding to do. Mine and yours.
Looks like a 4th set of M7's are about complete.
It's now clear why there are so many closet-modders here.
Don't take experimental gene therapies from known eugenicists. -
So curious, were the voice coils burnt or bad in any way?
Another set of 6510's showed up with magnet shift. One so bad it severed the coil lead wire (on left). I was able to scrape the dust cap glue away, lift the wire up and over enough to get it repaired with fine tip soldering iron and Cardas Quad...
Saved from the heap or trash-Bay...
Back 100% Concentric...
Post edited by xschop onDon't take experimental gene therapies from known eugenicists. -
Never posted this. Here's a fast way to remove a factory glued magnet without breaking it. Use exactly 0.500" alloy bar and gently wedge for pressure. Takes only 1 to 1.5min heating and you'll hear a distinct snap (Loc-Tite release). Let cool and pull magnet off by hand....
W/all the skill of a brain surgeon… you’re the man Rob😊Samsung 60" QN65Q7FAMFXZA QLED, Outlaw Audio 976 Pre/Pro, Samsung BDP, Amazon Firestick, Phillips CD Changer
*all connected w/Premiere ICs
4 dedicated 20A feeds; APC H15; 5 Furman Miniport 20s -
Cant remember the thread but someone just recently asked how to accomplish this exact problem.
This particular driver was not mag- shifted but was too far out of concentricty for my taste. So set up on mag jig and punched pole-piece out and magnet stayed attached to base plate.Don't take experimental gene therapies from known eugenicists. -
Ever since I jb welded the magnets on my SDA’s there’s something that has bothered my ocd grey matter…….
I keep pondering whether I should have centered the magnets, of my MW’s, then do the jb weld gig!
Would there be a noticeable difference in performance?
Is there a negative to jb welding the magnets in place if they’ve shifted a tad but haven’t gotten to the point of the voice coil scraping.
May be over thinking things but this is the stupid things a very anal/perfectionist deals with!
What I've gathered on here is if you do the "push test" and things check out, you are good-to-go. Mine all checked out, so they are now set for eternity where they were at the time I J-B Weld-ed them (hopefully).
Brian
One-owner Polk Audio RTA 15TL speakers refreshed w/ Sonicap, Vishay/Mills and Cardas components by "pitdogg2," "xschop" billet tweeter plates and BH5 | Stereo REL Acoustics T/5x subwoofers w/ Bassline Blue cables | Rogue Audio Cronus Magnum III integrated tube amp | Technics SL-1210G turntable w/ Ortofon 2M Black LVB 250 MM cart | Teac VRDS-701T CD transport | LampizatOr Baltic 4 tube DAC | Nordost & DH Labs cables/interconnects | APC H15 Power Conditioner | GIK Acoustics room treatments | Degritter RCM -
Until your coils start rubbing on the baseplates due to the off-kilter pull of the mag flux gap. Your 6510's
and 6511's are critical.
See the 0.020" plastic shim wedged between the coil spud/jig and baseplate above? I have not found an out-of-concentric driver yet where the coil was not also relaxed/set too close to the base-plate, sometimes lightly rubbing. I use a hot air gun or blow dryer to heat and relax the coil away from the base plate ID to fix.Don't take experimental gene therapies from known eugenicists. -
Aaaah, I see.
Will sleep better tonight that I did good. -
7075 material finally showed up for the next phase of the phase-plug journey... Focus rings... 1.375 OD x 1.125 ID
MW-6516 focus rings...
I was reading this yesterday and found it interesting:
https://speakerwizard.co.uk/driver-ts-parameters-xmax/
George / NJ
Onkyo A-8017 integrated
iFi nano iDSD DAC
iPurifier3
iDefender w/ iPower PS
Very interesting phenomenon I observed. When I dropped the ring down into the VC gap, it went at about 1/3 speed of gravity.
Very cool. The same thing happens if you drop a magnet down a copper pipe (or aluminum).George / NJ
iFi nano iDSD DAC
iPurifier3
It is discussed in this quora chat:
https://www.quora.com/Are-copper-and-aluminum-though-not-magnetic-affected-by-magnetic-fieldsGeorge / NJ
iFi nano iDSD DAC
iPurifier3
After lower area of Red Loc-Tite dries, I'll seep more Loc-Tite into the top between interstitial area of alloy ring and magnet,. I left @ .007 clearance for glue.
BTW I confirmed on this extra set of 6516's that their magnets are different from all other MWs....
1.30" ID
3.425"OD
0.540" thick
Today I've been listening to a set of bone-stock 6516's in the right channel and this set with focus-rings only before I cut the caps off and phase plug.
So far by ear I can say that the rings improve bass and mid-base speed/transition.
I've been moving the balance knob from left to right and they certainly are cleaner sounding all around.
I switched speakers L-R and listened carefully to same tracks.
I also did a blind test and wife picked out the ringed set as "better sounding voices"
I don't hear any diminished output on the ringed set either compared to the un-ringed set.Don't take experimental gene therapies from known eugenicists. -
Now to phase-plug the ringed set...
Ready for some fresh gaskets...
Already have some bass-heavy tracks that cannot bottom out or distort these at even the highest volumes.
The bone-stock drivers are bottoming out and distorting voices at accompanying bass notes.
Ironic that E-40's track Sideways, makes the stock MWs oscillate off axis at high SPL. The ringed, now ring/plugged drivers stay straight as an arrow on axis and the voices don't distort at all.
Interesting how women can hear changes in the rig (supposedly women have greater hearing sensitivity, particularly high frequency). I was trying out a silver interconnect once, and had not mentioned it to my wife. She casually passed through the room, made a face and said "what did you do to it"? -
But she doesn't understand why I'm always listening to the same tracks/songs when tinkering with them.🤔
She's just happy I don't build 500hp deathtraps anymore.Don't take experimental gene therapies from known eugenicists. -
I knew heavy steering when I got to drive a 79 whale tail and a fully-manual, base model beater Chevy S-10.
Not much difference in ride nor feel on either below 25mph =PThe Thrifty Setups in Mah House Big thrifty stereo in the basement w/ my custom SDA-1C (built with help from kind forum members) * Beautiful 1966 MCM GE console upgraded w/ Bluetooth, Dual turntable, and Paradigm speakers in family room * Swanky 1980 Realistic system and great TEAC eq with dancing colored lights in the living room * custom 5B on a system for my Dad * Ye Olde college stereo in the garage -
Getting a jump on the right channel conversion.
Found a very fast a thorough way of butyl mating the drivers whilst the magnets are off for realignment and ring insertion...
More factory offset magnets I wouldn't trust anyway...
Ohhhhhhh. Nice.The Thrifty Setups in Mah House Big thrifty stereo in the basement w/ my custom SDA-1C (built with help from kind forum members) * Beautiful 1966 MCM GE console upgraded w/ Bluetooth, Dual turntable, and Paradigm speakers in family room * Swanky 1980 Realistic system and great TEAC eq with dancing colored lights in the living room * custom 5B on a system for my Dad * Ye Olde college stereo in the garage
