Suggestions for L/R/C for Home Theater
EndersShadow
I’m hoping to be in a position in the next few months to finally upscale my fronts. I am not looking to buy yet, just get suggestions on what to listen to/look for.
It’s been quite a few years since I sold my LSi system and moved to just stereo as a stopgap.
Budget for L/R/C is prob ~1200 all said and done. Suggestions can include stuff that can be had used for around that price point.
Im open to towers or bookies for left and right but will need a horizontal center. Can’t be ridiculously huge but I’ve been running SDA 2As and skinnier def techs so they can be within that range.
I’ve got more than enough power on tap for low ohm or low efficiency speakers…. But would prefer to have something higher efficiency and 8 ohms.
For ht?
I would check out the older Def tech stuff, you can have a whole 7.1 setup with a receiver from the Facebook marketplace for 700 lol- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
For ht?
My concerns there are the def tech amps in their towers. High failure rate, but you are right. I see stuff there all the time.
I know @mantis loves his STS towers.
I won’t be ever going 7.1 as I’d need to install in ceiling and given my setup it would still be a bad idea as the sides and rears would be within inches of each other."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
You can sell what you don't need.
The amps can be repaired- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
KEF Q100, or Q300 (larger bookies), all the way around. Bring a large sealed powered sub for quick/powerful lows.
Done!
For HT, these things seem to disappear and are utterly seamless with surround-sound panning; great with movie dialogue and slam in ♠️.CD Players: Sony CDP-211; Sony DVP-S9000ES; Sony UDP-X800M2 (x2); Cambridge Audio CXC
Cables: Tripp-lite 14ga. PCs, Blue Jeans Cable ICs, Philips PXT1000 ICs; Kimber Kable DV30 coaxial ICs; Canare L-4E6S XLR ICs; Kimber Kable 8PR & 8TC speaker cables. -
Could also pick up some used Goldenears. Some triton 5’s on Audiophile swap and shop for 600 in Florida right now. Goldenears are awesome in a HT environment2 Channel in my home attic/bar/man cave
2 Channel Focal Kanta 3 I Modwright SWL9.0 Anniversary Pre I Modwright PH9.0X I Modwright KWA-150SE I VPI Prime Signature w/ Soundsmith Zephyr MIMC I Lumin U2 Mini I North Star Designs Intenso DAC I Audience OHNO ICs/Audience Furutech FP-S55N and FP-S032N Power Cables/Acoustic Zen Satori I Isotek Sirius -
I have ST Towers not STS. They had 2 different models back then of the ST models , The STS is the smaller version of my ST tower and the STS was a newer speaker in the line up. They came out after the ST did.EndersShadow wrote: »For ht?
Yes the amps have high failure rate, I had to replace both mine . I even picked up some crossovers just in case they failed , so I got new crossovers for all 5 of my speakers LOL. Mental? Yup.
Dan
I'd like to get pictures and damsons of your room. Speakers we want vs the speakers we should have for our living space are usually 2 different things.
The used market is good IF you can find Gems. That's what's hard. When I was trying to pic up a nice pair of RT16's , people just don't take care of their stuff like I do. I try to keep everything I own in like new condition, not to resell but I like it to be like new all the time. Why people scratch and damage their gear so badly is beyond me.
Anyway , I can absolutely help you with choices when your ready. Shame you don't live closer to me I just moved a Full Paradigm 5 channel Studio system which was crazy awesome.Dan
Try and get in on this....
https://forum.polkaudio.com/discussion/198070/help-us-shape-the-future-of-polk/p1
If you get picked to participate, the R700 might be a way to go.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
Depending on the size of his room , the distance from his seating area , for floor standers the R500 or 600 also could be a excellent choice.nooshinjohn wrote: »Try and get in on this....
Dan
Dimensions and layout. Only thing that’s different is that I have a big ottoman on the right side of the couch now and no subs up front.
Some more recent front stage pics (before moving in the def tech BP2002, which were never meant to be permanent).
Have a set of Def Tech BP9040 surrounds going in as stopgap for the time being too….
EndersShadow wrote: »I’m hoping to be in a position in the next few months to finally upscale my fronts. I am not looking to buy yet, just get suggestions on what to listen to/look for.
https://www.chanemusiccinema.com/700-series.html
https://www.powersoundaudio.com/
https://www.jtrspeakers.com/
https://procella.audio/ -
Nevermind lol just saw your budget
JBL studio 530
Kef Q150
Monoprice B6
Emotiva -
KEF Q350's all across the front. Or Q250 for center. Fantastic performance for the money. Well within your budget.
pearsall001 wrote: »KEF Q350's all across the front. Or Q250 for center. Fantastic performance for the money. Well within your budget.
Will look into those. The price is right in line.
No issue using one of the 350s long ways right?
Any thoughts on the 350 v 550 (since I’d need stands a way for the 350s)?"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
I bought a pair of q100 when they came out a decade ago and assuming they are the same as they were then... I'm just not sure you would be to thrilled for a HT or gaming. The q100 really had a difficult time with volume and bass. Really an underwhelming experience overall. I would gof rot he Polk reserve series any day overthat.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
EndersShadow wrote: »pearsall001 wrote: »KEF Q350's all across the front. Or Q250 for center. Fantastic performance for the money. Well within your budget.
Due to the concentric integration of the drivers, positioning the speaker on it’s side won’t make any difference.CD Players: Sony CDP-211; Sony DVP-S9000ES; Sony UDP-X800M2 (x2); Cambridge Audio CXC
I love my front stage of def tech clr3000 and PM900, all with built in 10 inch subs. SM350 for surrounds. Got all 5 for about $1000. Can’t imagine besting that for HT for the money…Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
Man that's a steal!!
The PM900 is such an awesome speaker. I bought the "DIY kit" Definitive sold thru their back door ebay store (bajawaverunner) many moons ago. Super fun to put together and man they truly filled the room with incredible bass for a monitor for HT!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Yep I love that I can run my front stage full range and let the monolith 15 inch sub just pick up the .1 and surrounds. In a smallish room it rocks pretty hard…
I remember that eBay store…kinda wish it was still around…Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
Yes indeed you can place a single Q350 on it's side for center duty. Three identical speakers for L/C/R is the way to go.
That's always a dilemma when comparing a monitor vs floorstander... the need for stands for the monitors.
The 550 will give you more vs the 350 but when you factor in the sub/subs & AVR handling the XO (most likely all speakers set to small & 80hz) it becomes a moot point. -
Apples to oranges comparison. They are definitely an updated version compared to a few years ago & the 350 is heads & shoulders above the 150 & especially the older 100 model.
pearsall001 wrote: »I bought a pair of q100 when they came out a decade ago and assuming they are the same as they were then... I'm just not sure you would be to thrilled for a HT or gaming. The q100 really had a difficult time with volume and bass. Really an underwhelming experience overall. I would gof rot he Polk reserve series any day overthat.
If you find measurements beneficial, the below reviews contain them so you may compare the Q300 and Q350 further.
https://hometheaterhifi.com/reviews/speaker/bookshelf/kef-q300-bookshelf-speakers/amp/
https://www.stereophile.com/content/kef-q350-loudspeaker-measurements
The Q300 was designed to have a flatter frequency response than the Q350 (response dips in the upper-midrange and lower high frequencies). This may be less of an issue if you use room calibration on your receiver.
Other considerations between the two:
Q300 - front-ported (larger cabinets; concentric driver is not centered on the front of the cabinet - this means if used as a center channel laid on it’s side, you will have to position the speaker cabinet off-centered for the concentric driver to be centered 😄)
Rear terminals have a weird bi-wire/bi-amp configuration using knobs to connect/disconnect mid/tweeter sections internally (rather than using jumpers).
Likely cheaper on the used market.
Q350 - rear-ported (smaller cabinets; concentric driver is also centered on the front of the cabinet no awkward positioning on the shelf required)
IMO, preferable speaker terminals.
More expensive since still current model..
I haven’t had the pleasure of hearing Polk Reserve yet, but their cabinet construction and crossovers will kick the snot out of the above KEF models. No doubt these will sound entirely different due to driver material selection and not being a concentric design. A bit more $$$.
Might be worth also looking for some used Monitor Audio Silver-1 bookies; really great values and high quality for the $$$.
As everything audio, it all comes down to personal preferences
Good luck with your search.
Ahh...I think you have me confused with the OP.
I'm quite happy w/ my Maggie's. Thank you very much.
I was just offering a suggestion to the OP on his hunt for HT speakers. I had experience with the Q series & found them quite enjoyable.
pearsall001 wrote: »pearsall001 wrote: »I bought a pair of q100 when they came out a decade ago and assuming they are the same as they were then... I'm just not sure you would be to thrilled for a HT or gaming. The q100 really had a difficult time with volume and bass. Really an underwhelming experience overall. I would gof rot he Polk reserve series any day overthat.
Oops, I just forgot to type OPs screen name. You and I both suggested KEFs. I was just trying to help him understand key differences between the two series.CD Players: Sony CDP-211; Sony DVP-S9000ES; Sony UDP-X800M2 (x2); Cambridge Audio CXC
Thanks everyone!
@rooftop59 @VR3 - I ran my def techs large today on a movie and it was a whole different thing.
I had to dial BACK my subs.
I also have one of my 2 surrounds hooked up (other is getting installed tomorrow) and that also took it to a whole different level (haven’t had surrounds in like 5+ years)"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
Awesome!
I will never forget hearing the bp3000 system, bp3000tl, clr3000, bpvx with no separate subwoofer... Insane amounts of bass energy- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Awesome!
Yeah I’m gonna shop around for a cheap center if I can find one.
My CS400i works fine so it will have to be a steal of a price for me to think about it
. "....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
The clr2500 goes for a low price and would be perfect!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
@EndersShadow yea I had the cs8080hd which is basically the newer version of the clr2500 (well it's kinda in between the 2500 and 3000) and there really wasn't a huge drop off with the 8080 compared with the clr3000. Suffice it to say I think you will be VERY impressed with the clr2500...Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
