Will the csi-a6 work with my setup
737 Posts: 8
I have a Denon AVRX 3100 W receiver. My front speakers are the Polk T 50s I have a kliptch sub 10, my side and rear speakers are Polk FX 1–a4’s, My question is will the CSIa6 center channel speaker complement my set up.
Answers
    F1nut Posts: 52,164
    It's a fine center, but not a timbre match to your T50's.
  • 737
    737 Posts: 8
    So should i look for a different center channel speaker? Or different front speakers? What would work, or match with my a4’s as i like the looks and sounds of them? Thank you for your comments
    F1nut Posts: 52,164
    edited January 2023
    If you can find a pair of RTiA5, A7 or A9 I would go that route. Any of those would be a perfect match to the CSiA6 and a major step up from the T50.
  • 737
    737 Posts: 8
    edited January 2023
    How about monitor 70 series 2, or rti10’s and would these all work well with my fx1-a4’s ???
    Thank you
    Post edited by 737 on
  • Geoff4rfc
    Geoff4rfc Posts: 3,011
    edited January 2023
    737 wrote: »
    Thank you
    I had the M70's SII for quite a while and sounded best with a ton of power behind them, IMO. The RTi10's are comparable to the A7s would also, IMO, be a step up from the M70's. I would think the CSiA6 and the RTi10's would be a great choice. Also, the FXiA4 is the bi/di pole speaker, right? And yes, all of the above would work well, I've used the FXiA6 with the M70's and the A9's.
  • 737
    737 Posts: 8
    I found a pair of the RTI-A7 and those paired with the csi-A6 and the fx1-A4’s work fantastic together!!! Thanks for all the advice
    F1nut Posts: 52,164
    There ya go
  • rooftop59
    rooftop59 Posts: 8,120
    737 wrote: »
    Bet that’s a banging HT setup. Congrats! Got a sub in the mix? That would definitely take it to the next level!
    Game Room 5.1.4:
    Bedroom 2.1
  • 737
    737 Posts: 8
    Yes have a polk 8 inch sub and a kliptch sub10
    F1nut Posts: 52,164
    edited January 2023
    Time to step up the sub game. Dump those and get one SVS SB4000.
  • rooftop59
    737 wrote: »
    Heck even on SVS PB1000 would up your game considerably… believe me, been there, done that…but if you’re loving what you have then rock on!
    Game Room 5.1.4:
    Bedroom 2.1
  • 737
    737 Posts: 8
    My current setup is a pair of the RTI-A7 and those paired with the csi-A6 and the fx1-A4’s work fantastic together!!! I have two subs a polk 8 inch and a kliptch sub12, going to sell the polk 8 inch sub and look for another! My question is what other subs would pair well with my current setup?
    Thanks for any advice
    F1nut Posts: 52,164
    edited January 2023
    I just told you, sell both subs and get a single SVS SB4000. It'll easily outperform your current subs.
  • 737
    737 Posts: 8
    Thats just out of my price range, what are your thoughts on a kliptch RW-12 as my second sub
  • rooftop59
    737 wrote: »
    Not a great sub. Like I said, even a SVS PB1000 will be a big upgrade over both your subs combined…
    Game Room 5.1.4:
    Bedroom 2.1
  • rebelsoul
    rebelsoul Posts: 782
    Second that svs sb 4000. It is in a whole other level . I had 2 Polk 10 subs at one time and 2 Klipsch 12 inch subs another time and 1 svs sb 4000 blew them away by so much that Polk and Klipsch shouldn't be able to call them subs.
  • mantis
    mantis Posts: 17,611
    If you know anything about SVS, all their Subs are damn good. You should buy the correct size sub or subs to match the size of your room.
    The 4000 isn't better than the 1000, it has more output and IF needed works better in larger rooms. But if you have a small room, the 1000 series is the way to go. Followed by 2000 3000 etc.
    Dan
  • ken brydson
    ken brydson Posts: 9,060
    rooftop59 wrote: »
    737 wrote: »
    Keep an eye on the SVS outlet store. Currently a SB1000 for $499 or a PB2000 for $599. I own the PB2000 and absolutely love it...
    https://www.svsound.com/collections/outlet-specials/outlet-subwoofer
  • rebelsoul
    mantis wrote: »
    I have a 18x14.5 room and the svs was amazing and blended very well with my legacy signature bookselfs
    F1nut Posts: 52,164
    edited January 2023
    Among other things there are significant differences between the SVS drivers.
    The SB1000 Pro
    The SB3000
    The SB4000
    F1nut Posts: 52,164
    For comparison this is the state of the art Velodyne servo controlled driver.
    F1nut Posts: 52,164
    This is Rythmik's servo controlled driver.
    F1nut Posts: 52,164
    The Klipsch RW driver
  • 737
    737 Posts: 8
    Thank you for all the input
    Clipdat Posts: 13,101
    Well done, Jesse.
