L900 modules
Milito
Milito Posts: 2,003
Anyone have these? I'm thinking about getting them for my L600's.
I'm running L600's and L400 center channel and two Polk speakers in the ceiling as back surround speakers.
Will they help or is it a waste of money?
    pitdogg2 Posts: 27,686
    it you want atmos they will be better than nothing.
  • Milito
    Milito Posts: 2,003
    edited December 2022
    Just thinking with the sale if they improved the sound that much for movies, not for music.
    Can get them for $269 a pair right now.
    Pretty reasonable price.
    nooshinjohn Posts: 26,087
    Milito wrote: »
    For the price, adding them is no brainer.
  • Emlyn
    Emlyn Posts: 4,888
    I have them in L800s. As stated above they're better than not having them. They do work well and add to the home theater experience without much outlay. The ideal for Atmos is two sets of height speakers in the ceiling for panning of audio front to rear.
  • JayCee
    JayCee Posts: 1,509
    L900 PSA just in case someone misses it in the other thread. Read before ordering:
    https://forum.polkaudio.com/discussion/comment/2709077/#Comment_2709077
    Speakers: Polk1.2tl's (Uber Mods) Pre/Amp/DAC: PS Audio PMG Signature Pre, BHK Signature 250, PMG Signature 512 Cables/IC's: MIT S1Bi-Wire/S1 Balanced +Avel Lindberg 1000VA "Dreadnought" Power Conditioner: PS Audio P15 Power Plant Power Cords: Core Power Technologies Gold, DH Labs Power Plus DIY w/Neotech NC-P301 & P311ends Streaming: Roon ROCK on wifi'd NUC, TP-Link WAP, & Uptone EtherREGEN, AfterDark, Emperor Double Crown Clock, Black Modernize LPS⟿Ω☯☥☮⟿🔊♩♪♫♬♩♪♫♬♩♪♫♬
  • Milito
    Milito Posts: 2,003
    Ordered a pair, thanks to all for the input.
  • LegendaryDan
    Milito wrote: »
    Where did you find L900s for $269 a pair???
    txcoastal1 Posts: 13,519
    Milito wrote: »
    Polk Forum member family sale...ended Monday. Stick around and welcome to Club Polk
    https://forum.polkaudio.com/discussion/197660/50-year-anniversary-sale-up-to-50-off-only-for-polk-forum-members#latest
  • Milito
    Milito Posts: 2,003
    I Hooked up my L900's to my L600 with my Yamaha RX-A2070. Now the Yamaha won't recognize my L600's, no sound. The sound is working on L900's. I checked connections and everything is as it was before I added the L900's. The L600's were working fine before I added the L900's.
    In the Yamaha setup menu my mains can't be activated. I have family over so I don't have time right now to check further. Any ideas?
    In 2 channel mode running thru my Musical Fidelity M6si, the L600's worked fine.
  • Emlyn
    Emlyn Posts: 4,888
    Strange. Could possibly be a setting in the receiver where the height channels are used to "biamp" the mains?
    Gonna ask a st up id question...but you did run a seperate pair of cables to the L600's for the 900's??
  • Milito
    Milito Posts: 2,003
    Yes I did, lol doesn't hurt to ask though as I have done some stupid things in the past like everyone else.
    I haven't ever seen any setting in the receiver to biamp the mains, but I'll look again. There is, but that didn't help.
  • Emlyn
    Emlyn Posts: 4,888
    On the 2070 it looks like the L900 should be used as the Front Presence speakers which connect to the speaker jacks on the right side of the rear panel looking at it from the rear. Those are also the outputs labeled Extra and could be used as Zone 2 or Biamp outputs too. The main speakers should run normally if they remain connected to the main speaker outputs.
    There may be some setting I am unaware of in the menu to direct the sound to specific outputs in an unusual way. I don’t know why the mains would not play normally given no connections changed for those. Maybe the L900s are running as Zone 2? Just a wild guess.
  • Milito
    Milito Posts: 2,003
    I've got them running as front presence speakers. When I have more time I'm going to double check everything again Monday after all the family leaves.
    I just thought it would be a 30 minute operation, install the speakers and go upstairs in the attic and grab some cable. I had trouble getting the cover plate out on top of the left speaker, it took probably 20 minutes for that as I didn't want to damage the top of the speaker. It was way too tight a fit.
    I connected the cable in what I thought was the front presence connection and the L900 worked fin,. but not the L600's. I disconnected the L900's and the L600's still didn't work. Hopefully I missed something.
    I am running the L600's connected to my M6si, would that be an issue instead of them running off the Yamaha? I have been running my L400 off the Yamaha center channel connection. I have the HT/AUX setting for HT activated.
  • Milito
    Milito Posts: 2,003
    Really weird, my main speakers (L600's) started working correctly a few days ago. I hadn't changed a thing on them as I haven't had the time to do anything with family being here.
    msg Posts: 10,594
    Warm up time?
  • Milito
    Milito Posts: 2,003
    I'm going with #1, ghosts as it had ample warm up time and I hadn't been drinking.
