LPS for Router?
Dr_Wu
Primarily for streaming Qobuz to etherRegen switch (Supra Cat8) to Lumin U2 Mini (AQ Vodka/RAL Prophecy on order) to Chord Qutest (AQ Carbon digital coax/RAL on order). Streamer supplied by SBooster PS; Qutest supplied by Teradak LPS. All plugged to PS Audio regenerator.
I'm thinking that powering the router with its wall-wart might be holding me back. Would like to hear what any of you who've been through this have to say. Thanks!
I am in the same search as you sir.
https://forum.polkaudio.com/discussion/197631/lps-linear-power-supplies-a-discussion#latest
Sorry brother. Let me shut this down and add my post to your thread.
Naw man, you are good.
I don't want to steal your thunder.
Rock on with yo' bad self. I'm just here for the ride....
I got no thunder - none!
If any admin/mod spots this, this thread can be closed. Thanks, and apologies for the bother. -
I achieved better sound and video quality running my network gear with better power supplies.
https://forum.polkaudio.com/discussion/comment/2511598
https://forum.polkaudio.com/discussion/comment/2586738
Proud and loyal citizen of the Digital Domain and Solid State Country! -
Certainly worth a try and the cost is relatively small. Thanks, Ray, and Happy Holidays!
@DarqueKnight have you tried nicer DC cables? Just curious
I found those upgraded teradak DC cables were literally 20 awg wire with a slight twist in tech flex... Upgraded cable brought a darker background for sure- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Yes! I replaced the stock DC cables of all my TeraDak LPSs with DC cables from Ghent Audio. The Ghent
cables were made from Canare 4S8G star quad cable. I replaced the Ghent cables with DIY cables that I made from VH Audio's VQuad Cu21 star quad cable.
When I ordered a Farad Super3 LPS for my EtherREGEN switch, I opted for Farad's Level 2 upgrade DC cable (solid silver). I also ordered a Ghent DC cable for the Super3 to compare to the Farad upgrade cable. I kept the Farad cable.
nice! well worth the investment for sure- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
