Dead tweeters on one month old R700's
Answers
  • No worries. I remember the JBL's too, my brother had a pair. Give the R700's time, they really do start to open up over time, especially when you give them the juice. The ring tweeters are excellent.
  • mantis
    mantis Posts: 17,313
    So what ever happened here? I didn't see the replacement tweeter replies or did I miss something?
    Dan
  • To clarify my original post back in May, I eventually received replacement tweeters from Polk. Service was quick and painless...I have not had any issues since.
    Happy listening :)
  • jmore64 wrote: »
    I've been listening to the L700's since early spring when they were nearly impossible to get. I actually had to by them each separately from 2 different sources! eBay and Amazon. The pricing was the same for both thankfully, I wasn't paying a mark up.
    So I've had time to listen to them. And maybe it was because the one tweeter was starting to fail that I wasn't too impressed. Not knowing the issue at the time and other things coming up, I wasn't listening much until yesterday when I was doing room correction that the one channel showed no upper range. I heard it but I thought it was just because of room acoustics. (I have a couch to the right side of the speaker that sucks all the higher ranges, hence the room correction) Anyways, low and behold the tweeter was completely dead. I did a little research, came here and that's where we stand. I'll post more after I installed the new tweeter and give an update. Hopefully Polk customer service will get back to me tomorrow and I'll be off to the races.
  • I'm happy to report that my L700's are sounding very well indeed. After replacing the blown tweeter and redoing a full room correction using (ARC), Anthem Room Correction, the sound is much better now. I will be keeping the JBL's off to the side for the time being. I'm able to comfortably play at about 85 - 90 DB sound pressure levels without any distortion. Playing louder than that and it gets stressed. I'm using an old Adcom GFA-555II power amp that has plenty of reserves running through a Anthem MRX 740 multi-channel receiver. I also am set up with a 5.1.2 system with Dolby enabled speakers. I'm currently happy and content, for now. Thank you for all the helpful feed-back.
    txcoastal1 Posts: 13,499
    That's awesome glad you are enjoying the speakers. Just curious when if you have had or done a refresh on that Adcom? It is a 25yo amp. At the least have it tested.
  • I was listening at high volume and my wife says Joe there's smoke coming out of your speaker.
    It was the tweeters in my lsi-25s.
    F1nut Posts: 51,674
  • txcoastal1 wrote: »
    I went and changed out the amp. I picked up a used Parasound Halo A 21+ amp. OH MY GOSH! What a difference. Totally cleaned up the sound. Even at low volumes it is much fuller with all the details intact. I'm now pushing 100+ SPL. I don't need to go any higher, but there was plenty of room still to go. Maybe when I need a good beating I'll try to see where it maxes out.
    It is just so much better sounding with clean effortless power. The Adcom did well, but this is a whole different league.
  • skipshot12
    skipshot12 Posts: 1,786
    ^ Yes, higher power grunt, available current, makes a big difference even at lower volumes.
    It really starts to shine at higher volumes.
    Bi-amping with the right amps adds another oooompf to effortless that sound.
    Enjoy your new amp and new found sound.
  • skipshot12 wrote: »
    Hi, I want to bi-amp my R700 and I'm asking if I need different amp powers for the highs and lows.
    Thank you for helping.
    VR3 Posts: 29,386
    edited February 2023
    Highest quality 2 channel amplifier will out run biamping every single time.
    Biamping without an active crossover before the amplifiers is fruitless plus over complicates everything
    F1nut Posts: 51,674
    Flussgott wrote: »
    skipshot12 wrote: »
    That's a hole you do not want to go down and as mentioned, without the use of active crossovers it is pointless.
  • VR3 wrote: »
    Flussgott wrote: »
    skipshot12 wrote: »
    Many thx for replying. How is active crossover done right?
    Maybe then I go with a Hypex nCore Stereo Amp + one good PreAmp I don’t know yet.
  • VR3 wrote: »
    Maybe this is good for active crossover
    https://www.minidsp.com/products/minidsp-in-a-box/minidsp-flex-eight
    it also brings Dirac with it.
  • jbreezy5
    jbreezy5 Posts: 1,141
    Flussgott wrote: »
    VR3 wrote: »
    Flussgott wrote: »
    skipshot12 wrote: »
    Recommend you re-read the responses already given.
    Would avoid Class D and not be concerned with bi-amping.
  • All right. I’ll do researcheres first.
    But please, just to let me know, way would you avoid Class-D amps.
    Thx.
  • WLDock
    WLDock Posts: 3,073
    Flussgott wrote: »
    Here's a question.... or two.
    1) Would it make sense to spend more money on 4 channels of amplification + active crossover, interconnects, speaker wire to bi-amp the R700 or sell and get the L600 powered by a single 2-ch amp?
    2) Would it make sense to bi-amp the R700 or put extra money towards treating the room, OR better front end gear, and/or better 2 ch amp?
    Bottom line, do the best that you can with placement and room acoustics. Get nice speakers and get a high current 2-ch amp to power them with. This works for most.
    Adding room correction to the mix is not a bad thing to consider if the space has challenges. This might be a more worthwhile rewarding endeavor over buying 4 channels of amplification and running an active system.
    Maybe an all-one-one integrated will work for you???? like the Lyngdorf, Anthem, NAD, Arcam, etc. with built-in streaming, room correction, and class D amplification?
    Again more questions:
    What are the problems?
    Whats lacking in the system?
    What gains are you seeking?
    In the end, who knows how much of a difference these options will make. Find the right balance!
    Therefore, if you want to go down the active crossover rabbit hole and play around with the different Class-D Hypex, Purifi, IcePower, etc. topologies or even run the low end with class D, the upper with class A/B, active room correction, etc. Go right ahead and experiment to deal with your own curiosities. Its your money, time, space, and system.
    Do your research
    Do understand that there are pros and cons to class A, B, AB, C, D, G, H, tube, etc. amplifiers.
    Do experiment over time
    Do report back YOUR findings!
  • jbreezy5
    Flussgott wrote: »
    Thx.
    Not a fan of switching. Some people like class D just fine. I’m not one of them.
    To me, those are designed for cost savings, not sonics.
    mhardy6647 Posts: 34,916
    They're the (near) future -- at least for multichannel.
    https://www.mcintoshlabs.com/products/amplifiers/MI254
    Hypex Ncore amps in this Mac; i.e., at least they used good ones.
    https://www.mcintoshlabs.com/products/home-theater-processors/MHT300
    (I don't think "we" know, yet, whose Class D boards Mac is usin' in this "coming soon" $8k HT receiver)
    Class D amps are definitely getting better, though. I think they sound OK based on my limited (and low-end) experience.
    I'm not crazy about them, either, in full disclosure -- nor switchmode power supplies. Both are electrically efficient, but they generate gobs of RFI ("hash") that has to be dealt with in their environment. And people will still use them to power phenomenally electrically inefficient loudspeakers*, so it's kind of a pyrrhic victory when it's all said and done.
    _________
    * A loudspeaker with sensitivity in the low 80s (dB of SPL at 1 meter for 1 watt electrical input) typically has an efficiency (measured as acoustic power output in watts per watt of electrical power input) of 1 or 2 percent. The other 98 or 99 percent is p!$$ed away as heat. :# So much for using a 90% efficient Class D amp instead of a 40% efficient Class AB amp! ;)
    F1nut Posts: 51,674
    Class D works well for HT, for music not so much.
  • mattyboo
    mattyboo Posts: 1
    I just blew a pair of tweets on a new pair of R700s using a pair of newly refurbished Adcom GFA-555's. I had them running bridged and not biamped, so lack of power was not the issue. LOL when the tweeter blew I literally saw electric flashing behind the soft dome ring. Its sad because the system sounded really good. The Polk's had a three-dimensional sound, for lack of a better term.
    audioluvr Posts: 5,874
    Have the Adcoms tested for DC current
    pitdogg2 Posts: 26,927
    Bridged amps do not like less than 8ohm loads. The R700 drop to 3.5 ohm which is a no go for bridged amps.
    msg Posts: 10,450
    Alright, I'll be that guy - where was the volume knob?
    Why did you bridge the amps? Were you running each as left and right monos, but set each to bridged?
    One of those amps should have run that pair of speakers nicely.
    Just curious.
  • skipshot12
    Just my thoughts but, this sounds like an amp took out a driver….,
