Polk L800 speakers - SPL below 100 Hz dropped about 6db.
nooshinjohn wrote: »nooshinjohn wrote: »txcoastal1 wrote: »So other than testing the sound using software what is your next step to troubleshoot and get issue repaired?
Polk will send someone here to test the spearkers next week. Thanks.
The L800 speakers are covered by warranty.
I would be very interested in knowing what they find, and shocked they are sending a live human to do the work. Is it law where you live that makes them do this?
That's how warranty works here in New Zealand, I was extremely shocked when someone suggested me to repair the speakers by myself.
In New Zealand, we simply get a replacement or full refund. We never repair anything under warranty by ourselves.
I post my issues here to seek tech support from Polk US directly to see if I can resolve this issue in another way.
It was me that made the suggestion. In the U.S. Polk sends us the failed parts and we put them back together.
Oh, why? Polk Audio is an USA company, right? You are supposed to get better service in the USA, isn't it? -
I don't really care what you said, unless you work for Polk Audio, do you work for Polk Audio?
Thanks.
No. Do you work for Polk Audio? -
It is the easiest way to do things over here.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
No. -
Cool. Glad we cleared that up.
Shocked to see some strange guy call my post "elaborate troll".
Don't sweat it honestly. We've had some fly by's that were only here to sling mud and insult the brand with sometimes very fictitious problems just see see us try and diagnosis a problem that was never there to begin with. They would then crawl over to another forum and go " Hey guys check this out LOL"
Had it been me instead of testing to over and over, I would have taken out the XO and after Scott made the inductor comment and looked over it as best I could. no amount of testing you did was ever going to fix the problem. You knew there was a problem so the constant testing wasn't going to fix the problem, you were just reafffirming a problem you already knew you had. Personally Scotts inductor or XO problem is where my money is at. I'm in the camp that the problem happened before you aquired the set and just took time to rear it's head. Who knows it could be as simple as they had a hard shipping and something came loose or broke a solder joint.
If it were me and the tone control adjustments weren't doing anything I'd disconnect every cable and reconnect just the integrated to the speakers using a single simple source component like a CD player then see how it sounds. I'd also remove the granite(?) slabs from beneath the speakers and take those rubber feet off.
Why hasn't this suggestion/advice been followed?
I said it clearly in my post, My Dell laptop connected to Rotel RA-1597 MK2, then RA-1597MK2 connect to the L800 speakers. Isn't that simply enough?
I am here to seek support from Polk Team. So I followed suggestion of Scott Orth. -
Indeed. I am not at all convinced that there's anything wrong with them (other than, perhaps, being a bad match for the room) -- and/or that their LF performance changed "suddenly".
If the latter -- and as I suggested in (IIRC) the first reply* to the original query, on 31 October -- turn off any and all DSP/EQ; reset any and all electronics to 'factory defaults' and see how they do.
_____________
* actually posted as an EDIT to my reply, on the same day:EDIT: Are you using any DSP/EQ? If so, what happens to the LF response if you turn it off?
mhardy6647 wrote: »If it were me and the tone control adjustments weren't doing anything I'd disconnect every cable and reconnect just the integrated to the speakers using a single simple source component like a CD player then see how it sounds. I'd also remove the granite(?) slabs from beneath the speakers and take those rubber feet off.
_____________
The Rotel RA-1592MK2 has been re-set to Factory Defaults many times. I don't use DSP/EQ when testing. Thanks. -
Not really, because it doesn't rule out the source (PC) as a potential culprit.
The key is that the symptom happened to both speakers simultaneously. That would be extremely unlikely that both crossovers would experience simultaneous parts/solder joint failure.
Do you have any other source other than the PC laptop that you could use? A fixed line-level source like a CD player would be a logical choice for this.
nooshinjohn wrote: »nooshinjohn wrote: »nooshinjohn wrote: »txcoastal1 wrote: »So other than testing the sound using software what is your next step to troubleshoot and get issue repaired?
Thanks, that's easiest way for Polk Audio, not easiest way for end customers. I hope Polk Audio will improve customer support in the future. -
NZ market is much smaller for everything compared to US. Products would not be cost effective if Polk had in home service.
Anyway, have you scheduled an appointment
Good luck with your issue2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
no amount of testing you did was ever going to fix the problem. You knew there was a problem so the constant testing wasn't going to fix the problem, you were just reaffirming a problem you already knew you had. Personally Scotts inductor or XO problem is where my money is at. I'm in the camp that the problem happened before you acquired the set
Kamala, is there a problem...
I do think he stayed at a Holiday Inn at some point. He's qualified to land a 747 on an aircraft carrier after a night there. After two nights, he would be the Chief of Neurosurgery at John's-Hopkins....The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
Yeah, the computer feed's definitely suspect -- given what we know and what we don't.
Basic troubleshooting methodology.
Try a CD player and a redbook CD.
mhardy6647 wrote: »Yeah, the computer feed's definitely suspect -- given what we know and what we don't.
^^^THIS!The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
Let's see the test results with the Focal speakers and same inputs 😉George / NJ
Onkyo A-8017 integrated
iFi nano iDSD DAC
iPurifier3
iDefender w/ iPower PS
I suppose we’re just hardier stock over here in the US - and we know how to use a screwdriver.
I’m pretty sure that we’ll never hear the outcome from the OP - especially when it’s determined to be a source issue.
― Aleksandr Solzhenitsyn -
Gardenstater wrote: »Let's see the test results with the Focal speakers and same inputs 😉
Thanks, just tested Focal for you. The microphone is about 2cm from the woofer of Focal 936. just like how I test Polk L800.
You can see the bass response of Focal 936 is much better, that is just a 6.5 inch woofer.
I will report here if it's determined to be a source issue. All I want is find out what's wrong and fix it. Thanks. -
I want to know exactly what it was that caused the problem. Inquiring minds and all…. Regardless of the outcome, I would encourage you to continue to post and be a part of the group.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
Thanks for the help. -
I fail to see what this test proves other than the Focal speakers having boomier mid-bass. Am I missing something? -
The Focal has huge unnatural bass boost meaning it's either poorly designed or it was done on purpose to appeal to those who like a certain type of music. The fact that you think it is better than the Polk pretty much proves you don't have a clue.Political Correctness'.........defined
President of Club Polk -
This test is a nearfield test for woofer only, the test result shows L800's sub bass is too light when both L800 and Focal 936 have same overall volume.
This test is a nearfield test for woofer only, the test result shows L800's sub bass is too light when both L800 and Focal 936 have same overall volume. Too light sub bass means something is wrong with L800. -
I completely disagree. Your test of the Focal does nothing more than show they are completely different speakers. Your conclusions are no different than if you were to compare a Corvette to a Honda Civic and saying something must be wrong with the latter because it’s slow.
I am beginning to think you need to lay off the eucalyptus leaves.
nooshinjohn wrote: »I completely disagree. Your test of the Focal does nothing more than show they are completely different speakers. Your conclusions are no different than if you were to compare a Corvette to a Honda Civic and saying something must be wrong with the latter because it’s slow.
It also shows that you are not as smart as you think you are…
Ouch. Is this before or after coffee, Marine?!?
What's missing is a before of the Focals under same test conditions to show that they didn't drop, too, but maybe OP knows them well enough to sense whether they're performing the same [shrug]
Isn't it already Choosedee in NZ? Are these fixed yet?
Meanwhile...
I disabled signatures. -
I see a precipitous drop in nearfield response in BOTH speakers starting around 60Hz. Why would that be happening nearfield where room effects are greatly minimized? Is it an effect of a ported speaker? Is the Focal ported at the bottom like the L800? I don't know about Eucalyptus but I would be interested in seeing for the Focal vs Polk at 30cm and 1m like you did with the other tests.
PS: Thanks for the tests. This is interesting no matter what the cause turns out to be.
PPS: World's Fastest Indian is one of my favorite movies lolGeorge / NJ
iFi nano iDSD DAC
iPurifier3
https://www.youtube.com/watch?v=CLVpHJE4qB0
