Post a picture... any picture
17827837857877881153
    SCompRacer Posts: 9,215
    edited October 2022
    I scored an original equipment stylus overhang gauge for my Mitsubishi LT-5V vertical table. It wasn't absolutely necessary as I knew the dimension from headshell mount edge to stylus tip (50mm). Also, the stylus on linear arms should be at centerline of spindle so, technically, there is no spindle centerline overhang like with a pivoted arm. But it does make cartridge setup easier on the removable headshell. It's also nice to have all the accessories that were provided with the table.
    https://youtu.be/T8OjlcJjSEE
  • schwarcw
    schwarcw Posts: 7,360
    SCompRacer wrote: »
    WOW Richee!!! Very nice to see the table running perfectly. A work of art!
    Are you bringing that table to my house in the trunk of your car? ;)
    Carl
    pitdogg2 Posts: 27,685
    Nice Rich. My buddy had a Mitsubishi vertical table like that. I always liked it and wished I had one.
    edited October 2022
    schwarcw wrote: »
    I'm bringing a Harmon Kardon ST-8! Wait until Ed sends me a nicer cartridge for it, and I'll set up for you. :D
    I brought the Mitsubishi LT-5V upstairs to watch it play rekkids and the strobe LED's were out! I measured voltage, got some low readings for four LED's in series and feared a circuit issue (transistors/resistors). I panicked and got Ken involved as I'm not as sharp as I used to be. He was much nicer than my old bosses, Bruce and Joe (he didn't say stupid richee!) but got me to look wider instead of that narrow minded panic mode.
    I removed and tested the LED's and a couple were bad. I replaced the four 3mm LED's and all is well!
    edited October 2022
    Well maybe we should discuss! :D
    One on epay for $800! :o The local Disc Replay has one for $300. It's boxed up so I couldn't look it over.
    https://www.ebay.com/itm/295240030726
  • agfrost
    agfrost Posts: 2,489
    SCompRacer wrote: »
    Nice. Been looking (not very hard) for one for my LT20 and LT30. Both need a little love to get them running though, and cartridge setup isn't the issue for either!
    Jay
  • BlueBirdMusic
    daddyjt wrote: »
    About driving me crazy. I had an AT&T survey for U-Verse, and I made sure to identify all of the channels that only have ^^^^.
    OMG, I have never seen so many spam emails with ^^^^.
    Harry / Marietta GA
    edited October 2022
    agfrost wrote: »
    Hi Jay! The Technics style gauges are easily obtained although they are 52mm. One can carefully sand/file end or scribe a line at 50mm, if that is the spec.
    The other must haves for linear arms with no VTA adjustment are cartridge shims. Cartridge height varies. The Harmon Kardon ST-8 with Rabco linear arm align tool also had a stylus height incorporated into the stylus align gauge as well. My LT-5V manual provides stylus height off flat surface in the manual (18mm or 11/16"). You add or subtract shims to get proper VTA.
    Ed's ST-8 had a .055" shim on the arm, but three other thickness that were originally supplied are missing. Unless he has that stuff squirreled away in his treasures. :D
    Harmon Kardon ST-8 3D printer gauge from ShapeWays.
    Shims from ebay. These are .015" each x 4. The light color ones are tapered, .0145" to .015."
  • aprazer402
    aprazer402 Posts: 3,451
    NotaSuv wrote: »
    The 1950-1970 era the smell was possibly a combination of cattle and lead smelting.
    No particular odor these days, unless you drive by Warren Buffett's very modest home, you can smell money.
    In 1955 Omaha overtook Chicago as the World's Largest Meatpacking Center.
    Lead was smelted on the riverfront for 125 years.
    https://cumulis.epa.gov/supercpad/cursites/csitinfo.cfm?id=0703481
    txcoastal1 Posts: 13,519
    The 2 worst smelling towns/cities that I have been through
    #1 Silsbee TX...Papermill plant OMG for miles and you cant's get that smell out of your car for another 20 miles.
    #2 Jimmie Dean meat processing out by Lubbock TX
  • soundfreak1
    soundfreak1 Posts: 3,414
    Oh crap I remember that pappermill smell! The smell of HELL!
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
    Tony M Posts: 11,925
    New world record. :o
    Over 1200 lbs.
    treitz3 Posts: 20,239
    Never fall for the bumper sticker....
  • BlueBirdMusic
    I like the description of the way the subwoofer works. This is a picture only - no links.
    Harry / Marietta GA
  • sgmsmg
    sgmsmg Posts: 556
    @BlueBirdMusic :D
    I saw that listing today and had a chuckle as well. They are local to me and often have some fun with their listings.
    Pre: Bryston BR20
    Amp: Buckeye NCx500
    Speakers: Polk L200
    Source: Oppo UDP-205, Bryston BDP-3, Bryston BCD-3, Apple TV, Amazon Fire
    Cables: Wireworld Gold Eclipse 7 Speaker, Wireworld Gold Eclipse 7 XLR, AQ Diamond USB/HDMI
    Power: PS Audio P10 Regenerator, AC12, AC10 and AC5 Cables
    Display: Sony XBR65Z9F
    Pre: Anthem AVM90
    Amps: Buckeye NC502
    Speakers: Polk LSiM 707 (FL/FR), Polk LSiM706 (Center), LSiM 703 (SL/SR/SBL/SBR), Polk 900-LS (Atmos)
    Subwoofers: SVS SB16 x 4
    Source: Oppo UDP-205, Apple TV, Amazon Fire
    Cables: AQ Meteor/Rocket 88, AQ Niagara/Sky
    Power: Torus AVR20, Shunyata Denali, Shunyata Delta, Cullen, PangeaAC9SE Cables
    Display: Sony XBR85Z9G
    This is the Hisashimichi interchange. It's a Japanese highway junction, made with minimum loss to Environment. This is a seriously impressive engineering masterpiece situated in Hachioji, near Tokyo, Japan.
    P.S. - I'd hate to miss the right exit!
  • soundfreak1
    Real nice areodynamics! Reminds me of a brick.
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    The only advertisement a window installer will EVER need....
    The amount of pressure against that is astronomical.
