Well dang
2
    msg Posts: 10,452
    Is that the speaker cabinet?
    What does potted mean? Trashed?
    Did you have dreams about backpack crossovers last night?
    VR3 Posts: 29,404
    Lol!
    They have external crossovers. They fill them with epoxy to dampen vibrations and to keep their schematics a secret.
    It was a great dream hahaha
    treitz3 Posts: 19,962
    I guess they haven't discovered this new invention called solder yet.
    VR3 Posts: 29,404
    Right? If you notice though they solder the nuts and connectors...
    Ah, I can't see that in the photo. Even when I blow it up, it just looks like mechanical connections.
    VR3 Posts: 29,404
    msg Posts: 10,452
    Neat. Do you have to desolder to get those apart, or do they come apart?
    Do you think that was to prevent backing out or truly a beneficial connectivity add?
    I can't quite tell how the connectors are oriented.
    VR3 Posts: 29,404
    If I had to guess it was to make it as difficult as possible to take them apart. Two of the binding post are loose so... Lol
    Removing those nuts would be extremely tricky considering a desoldering iron wouldn't likely remove any solder between the juts and connector so you would have to keep them hot while removing? Only way I could see doing it short of breaking them off
    Wilson likes to act like speakers are made of pixie dust and unicorn horns.
    The Duette does sound very nice, very nice indeed
    We were always taught that the best electrical connection was both mechanical (physical, mechanical connection) as well as a welded connection (soldered connection in this case).
    VR3 Posts: 29,404
    Indeed, solder is for maintaining a connection, not making it!
    I would love to see what's inside that epoxy! I imagine it is just a Polk rtia3 crossover hot glued to a bigger board
    mhardy6647 Posts: 34,950
    ^^^ Jensen Duette? :|
    I'm guessin'... no. :#
    pitdogg2 Posts: 26,981
    I'm sure there is nothing but Solen and Erse in there......
    txcoastal1 Posts: 13,505
    Stock
    VR3 wrote: »
    Same with Dynaudio C1 and C4, the only way to get them apart is to fork them up
    VR3 Posts: 29,404
    I mean if you look at it with the lights off...
  • newbie308
    newbie308 Posts: 800
    VR3 wrote: »
    If you have to get a lot of solder off of a connection, I have had success with melting the solder with an iron and then blasting it with compressed air. Just aim the air away from anything that you don't want a million tiny beads of solder stuck to, or catch the beads in a damp rag. I'm not suggesting this method for these speakers though 😬
    VR3 Posts: 29,404
    I have a solder vac but there is always a little bit left regardless of method of removal
    Alternatively, a solder sucker would work as well.
    msg Posts: 10,452
    newbie308 wrote: »
    Along these lines, a friend was trying to teach me to solder about ten years ago. He was showing me the "flick" method of cleaning the tip? I don't know if this is a hack method/no-no, but never do this while wearing shorts. In fact, I don't recommend soldering at all if wearing shorts. I soldered with shorts on once... Jusst once.
  • newbie308
    msg wrote: »
    newbie308 wrote: »
    I use a wet sponge to clean the soldering iron tip. I've found that the compressed air method for desoldering freezes the micro beads of solder pretty quickly, unlike flicking a glob of solder off the iron's tip. I've used solder wicks, desoldering irons and solder suckers. Sometimes they work great, but when you are dealing with a lot of solder, they require multiple attempts to get everything.
    msg Posts: 10,452
    I have a couple of different solder suckers, the bulb one and the plunger type. For some reason, I haven't been able to get solder wick to work. I've seen it done in videos and can't get over how clean the solder pads look afterward. I can barely get any solder off with them, but have seen in those vids how they do actually flow the solder up.
    In all fairness, that flick method was due to the fact that a lot of his solder work is as a mobile installer in new construction and he's using a benzo iron. @F1nut recommended one of the Weller soldering stations and Cardas quad. I've been using that combo and have to admit, it makes things a lot easier. I couldn't even get the tip tinned with the basic Weller pencil irons. One time I thought I was getting the hang of it and though I saw solder flowing, feeling kind of excited, but it turns out that it was bits of the tip melting and dripping off. How the hell does that happen you ask? It was because I got frustrated with the dirty tip that wasn't taking a tinning, so I thought it needed to be properly cleaned, and sanded it down with emory cloth. Took the coating right off, lol
    But yeah, having the right tools and materials makes a big difference.
    Still have soldering anxiety, which pretty much makes me avoid those projects, but then once I get started it's fine. One of these days I'm going to rebuild crossovers.
    msg Posts: 10,452
    msg wrote: »
    VR3 wrote: »
    I couldn't tell from looking at the photos on mobile that that enclosure was filled! It wasn't until I saw it on the computer that I noticed the bubbles and irregular surface and then finally understood what you mean.
    I would have thought those crossover components would heat up enclosed in epoxy like that, but I know nothing. Natzing.
    VR3 Posts: 29,404
    Yeah all of the resistors are outside. Inductors and stuff can heat up but usually not much.
    I have a solder vacuum to dealer and it really is amazing. Literally sucks it all up in an instant
  • newbie308
    msg wrote: »
    msg wrote: »
    VR3 wrote: »
    Actually, that potting compound (Stycast) has a specific gravity close to that of water, so it actually helps by transferring the heat into it's thermal mass.
    edited August 2022
    FWIW, I still like, prefer, and use "Bonus Wick" (desoldering braid) for general desoldering and cleanup of, e.g., a through-hole, when needed.
    I will also -- ahem -- cheat when doing repairs of point to point wiring by snipping out the component and making pigtails using the old leads. Don't tell anybody! :#
    This is not, of course, a good idea if you're working on a tuned circuit* nor for something like a grid stopper resistor that needs to be right up close to the socket connection -- but it makes for quick 'n' easy repairs of stuff like interstage capacitors. Did I ever mention that I am preternaturally lazy? B)
    N.B. I wasn't exactly proud of the work I did on that gorgeous 8B -- but I used the components provided by its owner and boy howdy did it sound magnificent once refreshed. Just a superb design and a marvelous amplifier, by the standards of the early 1960s or today's. :)
    Otherwise, there's value in a reworking station if one's serious about doing... rework.
    The other thing to consider is an inductively "heated" soldering tool: the New England gurus buy Metcal stations, often used ones (they're quite 'spensive) -- and swear by them.
    Oh - PS: There is still, IMO value added with a good old soldering gun for heavy-duty desoldering (soldered in can caps, braiding on coaxial cable, that sort of thing). Tim "The Toolman" Taylor wasn't completely off-base about the value of more power (insert gutteral grunt here)! Hot and fast can be easier on the circuit components than worrying something out using a too-small/tool cold pencil iron. :|
    All just my opinions, of course.
    _________________
    * Unless you really know what you're doing, you really don't care, or there's less chance of doing harm than good (which is rarely the case), I really wouldn't ever recommend mucking about with tuned circuits (i.e., RF, oscillators, mixers, IF and MPX sections), full stop. :#
    VR3 Posts: 29,404
    newbie308 wrote: »
    msg wrote: »
    msg wrote: »
    VR3 wrote: »
    great info!
    VR3 Posts: 29,404
    _________________
    This is the desoldering gun I use and it works extremely well and while "expensive" it is not that "expensive" as far as tools go
    https://www.amazon.com/gp/product/B07BFVFMS9/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
  • jdjohn
    jdjohn Posts: 3,334
    ^^^ I've got that same one. Worth every penny!
    msg Posts: 10,452
    VR3 wrote: »
    Hakko, nice. Ern / @ALL212 likes Hakko stuff, too, I think?
    Added to Amazon "Tools" list.
    Not shy about buying quality tools for jobs I'll do regularly or those things I enjoy working on. A reciprocating saw for utility/junk work? Yeah, that'll be Harbor Freight. If it's "unrefined" and I'm expecting it ahead of time, it's okay B)
    VR3 Posts: 29,404
    So I picked up the ANK monoblocks to run with these guys and they sound really, really good. Great imaging, micro details. Great solid center image, good extension beyond the mains on the sides and depth. A big improvement over my cheap integrated ($50) obviously.. Running a cheap little $20 bluetooth dongle which is more than enough for now to interface with the computer.
    But so far very pleased with the sound nearfield. The Wilsons are full range on a desk, no doubt.
    VR3 Posts: 29,404
    Slowly piecing the puzzle together!
    Still have to sand the box top
