Post a picture... any picture
17457467487507511153
  • daddyjt
    daddyjt Posts: 3,166
    ― Aleksandr Solzhenitsyn
    Tony M Posts: 11,808
    I would like a poster of that. :D ^^^^^^^^
    edited July 2022
    Poster of that too. :D:D:D ^^^^^^^ :D:D:D
    SCompRacer Posts: 9,131
    edited July 2022
    mhardy6647 Posts: 35,327
    ^^^ My a$$ -- I just laughed it right on off. I must pack it in ice and head straight'way to the ER. Perhaps it can be reattached.
  • soundfreak1
    soundfreak1 Posts: 3,414
    SCompRacer wrote: »
    Sounds like my very last interview... just before I retired!
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
    edited July 2022
    Now that you brought it up, that is how I retired last October. :D Tried to get some issues resolved that resulted in a high stress environment for me, but not the four younger guys that couldn't or wouldn't do the job. It ended in eff you, I'm retiring and left.
    edited July 2022
    I am always pro-retirement. :)
    My very last day of RFT work ended with an emergency strategy meeting of a "task force" I'd been part of, about... something important ;) ... that started at 3pm on a rainy (!) January Friday and ended somewhere after 6pm. I lugged my last couple of boxes of residual cr@p from my office out to the car in an empty, dark parking lot in the cold, wet gloom and headed up to NH. Not really quite the way I expected my last day to go. :p
    The next morning was much more pleasant. B)
    Meanwhile, the clouds to the south a bit after sunset tonight.
    txcoastal1 Posts: 13,519
    Wish we had clouds here🥲🥵🥵
    msg Posts: 10,506
    edited July 2022
    Post edited by msg on
  • sucks2beme
    sucks2beme Posts: 5,693
    SCompRacer wrote: »
    They called me the day after I retired for an emergency meeting to troubleshoot
    a major issue at 6pm. They let a vendor convince them the problem wasn't theirs.
    It was. Since they have had issues getting good help. That was last year. They called
    a couple weeks ago to ask if I'd come back part time. NO!!!!!
    I will still answer questions if the right person calls. If I have my phone
    with me. Which is never. That's liberating. From on call 24/7 to leaving my
    cell in the charger 99% of the time.
    edited July 2022
    sucks2beme wrote: »
    They called me the day after I retired for an emergency meeting......
    Just wow...
    I still get calls from a couple of guys there. Mostly electrical issues. Before I left two of the guys were diagnosing an intermittent start issue. It was towed in daily five days straight. I told my manager I won't fix it, they have to learn.
    They replaced both batteries, starter, cables, ignition switch, solenoids. So I downloaded the schematics for them. They looked them over and decided to bypass a problem circuit.
    It solved the start problem but created another. You could start the truck in drive and reverse. They bypassed the faulty neutral safe switch.
    Then there was the ABS issue. "It has to be a wire harness. I replaced the ABS sensor and it still won't read LF wheel." It had a bad wheel bearing. They had it raised on a lift to change the sensor but never checked for loose bearing.
    I could go on for hours.
    oops, I forgot one. This one had me guffawing.
  • NotaSuv
    NotaSuv Posts: 3,871
    edited July 2022
    So, I just learned that the verb enjoin has two, essentially opposite, meanings, not unlike the verb cleave.
    So, I suppose that this can only mean one thing: if one's cleaving is enjoined -- it's gonna be pretty darned hard to figure out what that means.
  • Nightfall
    Nightfall Posts: 10,083
    afterburnt wrote: »
    Village Idiot of Club Polk
  • tonyp063
    tonyp063 Posts: 1,142
    Mark,
    Haven't I told you not to try to divide by zero again?
    nooshinjohn Posts: 26,030
