Post a picture... any picture
Ole boot is that a 16 cylinder double overhead cam???Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable -
― Aleksandr Solzhenitsyn -
soundfreak1 wrote: »Ole boot is that a 16 cylinder double overhead cam???
It's actually two straight eight single overhead cams joined together, each with its own crankshaft connected to the other by gears. I looked it up and it appears to have been designed as an aircraft engine and I could find no mention of Bugatti ever putting one in a car, so probably someone just stuffed it into one. -
Love to drive that motor. Not to sure about that suspension though. LOLMain Rig:
MIT exp 1 ic's
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
If I get ambitious, I'll fix the cat's grammatical (or syntactic) faux pas. -
And Robin really needs to change his underwear. It's green!Gustard X26 Pro DAC
Happy 4th ya hacks
Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
^^^ That is in somewhat poor [or, at least, questionable] taste, but it's also hysterical.
(ASR)
I'd pay to see the next 2or 3 frames of film.Main Rig:
MIT exp 1 ic's
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
Holy ADS!Main Rig:
MIT exp 1 ic's
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
That's a nice room. Too bad it's got all those big ads loudspeakers spoilin' the view.
That's a nice wood stove too.
....let's not forget the nice wood stove. 👍Sal Palooza -
